Re: 4 speed bell housing alignment questions
[Re: moparmedic]
#1392801
02/25/13 11:52 AM
02/25/13 11:52 AM
Posts: 75,282 A gulag near you.
JohnRR
A gulag near you.
I needed several other transmission related items so I just ordered a set of offset pins from Brewers. Hopefully get this thing all lined up and back in the car. It has not been on the road since the early '80s!
Looks like the RobbMC dowels ,I'd put loctite on the set screws for the final assembly.
[Re: Stanton]
#1392803
02/25/13 02:10 PM
02/25/13 02:10 PM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
I would check the parallel of the mating surface of the bellhousing first, I had mine dead nuts at .002 tir and found my bell was not parallel so I had to put in a shim between the block and bell. When I did that, it totally screwed my number and I had to start over again. I tried the lakewoods and wound up drilling and slide hammering them out. I finally just ordered the Robbmc ones and within a short period of time after I got them it was within book spec. Tim
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
[Re: astjp2]
#1392805
02/25/13 02:42 PM
02/25/13 02:42 PM
JohnRR
A gulag near you.
I would have run it up to the machine shop and had them surface it .
Also that brings up a good point , the picture the OP put up shows his dial indicator is not inside the bore of the bellhousing ... at least it looks that way ??? but the picture is small ... if that is the case he isn't really getting an accurate reading...
but probably close enough for a caveman ...
[Re: 67_Satellite]
#1392808
02/25/13 07:54 PM
02/25/13 07:54 PM
Posts: 9,038 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
Because you will be measuring closer to the center of the circle,not .008 off center.It will still be centered l to r the same but the number will be a few thou different
Hmmm ... you're measuring at the widest point and then shifting it up .007". Do you really think the number will be "a few thou" different? I'll bet you the change doesn't show up on the dial indicator!
As for John having it surfaced ... another instance of him needlessly spending someone else's money. Yes, by all means check the runout, but if it is out of whack its easily resolved with shims cut from feeler gauges or pop cans instead of dishing out $100 to have it surfaced.
[Re: JohnRR]
#1392810
02/25/13 08:29 PM
02/25/13 08:29 PM
Posts: 6,257 gulfport, ms, west mi
rowin4
Pop can, beer can, piece of steel roofing , what does it matter if it works. My question as I have never heard of machining the bell housing to be parallel with the block, which surface gets re-surfaced ? the block side or the transmission side. I think a person can micro a project to death trying to get something perfect when there is tolerance that is acceptable .
[Re: JohnRR]
#1392812
02/25/13 11:45 PM
02/25/13 11:45 PM
Posts: 755 Oregon
moparmedic
I could not get my set up adjusted so that the indicator was fully centered in the bore but it is inside the bore. The picture was taken looking slightly down and from the left. The part that contacts the bore is as close to dead center as I could get it. Does the set up not look right?
1968 Coronet 1968 Charger 1966 A100 Pickup 1967 Barracuda 1970 Challenger 1972 Challenger 1973 Barracuda 2021 Ram 2500
[Re: moparmedic]
#1392813
02/26/13 12:07 AM
02/26/13 12:07 AM
Stanton
Don't question me!
Don't question me!
Ontario, Canada
I could not get my set up adjusted so that the indicator was fully inside the bore but the part that contacts the bore is as close to dead center as I could get it. Does the set up not look right?
Your setup is fine. Maybe one in 50 people will have a dial indicator and stand that will actually fit inside that hole! So the indicator is at a slight angle ... big deal, as long as it stays that way throughout the entire travel around the hole it doesn't matter.
And John, the proper surface to machine would be the trans mounting face, not the block face. The main reason being that less material would have to come off but also there would be a good chance of cracking an iron housing if it is taken off the block face.
[Re: Stanton]
#1392814
02/26/13 12:15 AM
02/26/13 12:15 AM
Posts: 755 Oregon
moparmedic
Ok, good,that is kind of what I thought, thanks.
[Re: Stanton]
#1392815
02/26/13 12:20 AM
02/26/13 12:20 AM
rowin4
Yes his set up is correct. A standard size indicator will not fit inside the hole straight up. The surfacing of the bell housing would be easier to do the transmission face only if the block face was flat.
[Re: Cab_Burge]
#1392819
02/26/13 02:00 AM
02/26/13 02:00 AM
Posts: 755 Oregon
moparmedic
The results I got were surprisingly similar to the you tube video link that was attached earlier in this thread. Yes, I zeroed the dial indicator at 12 o-clock and called that zero then took a reading at 3, 6, and 9 o-clock. The you tube video showed taking readings more frequently. http://www.youtube.com/watch?v=tS4H4oImDhE
[Re: moparmedic]
#1392820
02/26/13 02:11 AM
02/26/13 02:11 AM
rowin4
I have always set the indicator to zero at the lowest reading, by doing that you don't have the + and - readings confusing you. I do the 45 degree, use a marker on the bell housing face, take a 360 reading , do a adjustment , do it again and again and again. wish I had a friend to do the wrench cranking
