Changing thermoquad help needed
#1392404
02/23/13 01:10 PM
02/23/13 01:10 PM
Posts: 915 near New Haven, CT
fireeng
near New Haven, CT
I just received a rebuilt thermoquad from Harms and it has a vacuum tube hook up that my existing TQ doesn't have. Can someone please advise me on where this hooks up? Thanks in advance.
2016 Diesel Ram 3500 Mason Dump 1971 Challenger 2013 Jeep Wrangler 1979 Dodge Ram Power Wagon 400 Mini Pumper My other car is a Fire Truck.
Re: Changing thermoquad help needed
[Re: fireeng]
#1392407
02/23/13 01:34 PM
02/23/13 01:34 PM
RapidRobert
As said it's the bowl vent that originally went to a charcoal canister back in the day for emission purposes so the CC would absorb the vapors that previously were just vented to the atmosphere. Leave it open/as is & you'll be fine. I have put a gas line filter on it to filter any debris that might make its way inside but that was on a dirt track stock car & not sure if it'd be needed in a DD especially as I think the vent valve is only open at idle
[Re: RapidRobert]
#1392408
02/23/13 02:09 PM
02/23/13 02:09 PM
fireeng
near New Haven, CT
Thanks for clearing that up. I do have a 3 nipple breather on pass valve cover that has one opening blocked off. I now have come across another problem with the throttle linkage. The new carb is slightly different and hits on the intake manifold. Here are some pics. I can only post one at a time so bear with me.
[Re: express]
#1392414
02/23/13 03:01 PM
02/23/13 03:01 PM
Posts: 42,714 Spokane Washington
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
I would use one of the thick plastic spacers that were OE on at least some Mopars & also work as a gasket. These are about a 1/4" thick.
I agree, that's what they came with new. If you need one I can send you one no charge ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: express]
#1392417
02/23/13 04:19 PM
02/23/13 04:19 PM
RapidRobert
Since you're alltogether I dont think you'd want to grind/repaint the manifold there on the side. If you're using an open element air cleaner what about a slightly shorter element & Scotts spacer? EDIT or a drop base air cleaner
[Re: fireeng]
#1392419
02/23/13 04:50 PM
02/23/13 04:50 PM
RapidRobert
In the pic it looks like it comes up & hits the stop. I would see what Scott says
