Re: 440 source stealth heads
[Re: 2JcodeChargers]
#1390939
02/20/13 04:27 PM
02/20/13 04:27 PM
dogdays
[Re: 70runner]
#1390941
02/21/13 07:53 AM
02/21/13 07:53 AM
Posts: 21,065 Niles , Ohio
therocks
Niles , Ohio
That and have them checked before you install them.Ive had mine on for 4 years.No problems so far.Rocky
Chrysler Firepower
[Re: kloyiod]
#1390943
02/21/13 01:43 PM
02/21/13 01:43 PM
therocks
Niles , Ohio
As with any performance part its cheap insurance to have them checked.My shop charged me 220 bucks to install new seals as the ones they came with didnt work with my new springs.He provided the seals.Installed the springs new retainers and super locks.Checked all the clearances and height and coil bind.He also backcut the valves as he didnt like them and lapped them in.He even cleaned the ports a bit also.Not bad for under 250 bucks.Rocky
Chrysler Firepower
[Re: kloyiod]
#1390944
02/21/13 01:43 PM
02/21/13 01:43 PM
Posts: 2,530 Nunya CA
CR8CRSHR
Nunya CA
Just follow the directions that come with them and you will be fine, no need to piss your hard earned $$ away to have them checked. They run fine outta the box!
Yes they do... I clearanced the push rods myself, checked to make sure all was seated properly, springs were symmetrical, keepers and locks were on properly, and bolted them up. They work fantastically right out of the box. As mentioned, save your bucks on having your machinist look at them. That is of course unless you are building a race motor then by all means as the tolerances are much more finite. By the way, here is how a 383 sounds with the 440 Source Heads on my 1966 Plymouth Satellite that I just got up and running...
https://www.youtube.com/watch?v=AAs5NqGnUTw
Enjoy....
[Re: kloyiod]
#1390945
02/21/13 01:50 PM
02/21/13 01:50 PM
Posts: 1,456 oklahoma
forphorty
oklahoma
I assume you are being ironic.
[Re: kloyiod]
#1390946
02/21/13 03:26 PM
02/21/13 03:26 PM
Posts: 343 S.E.Mich
drew72
S.E.Mich
Yeah, that works wonders until you find out that someone forgot to clearance the guides or lube the valves before they out them in the heads. I have these problems (just to name a couple) in many different manufacturers heads. When I was inspecting heads, it was 50 bucks for the inspection if nothing was wrong. THAT is cheap insurance.
[Re: kloyiod]
#1390948
02/21/13 05:02 PM
02/21/13 05:02 PM
Posts: 3,300 Northern Indiana
Dunnuck Racing
Northern Indiana
I check every head before I use it. Bolt on out of the box is dangerous no matter who makes it. I have had more than one brand with either bad clearances,missing spring shims,a big chunk of casting flash ready to break off and end up in the oil pan,......the list goes on. Its not being anal,its called proper engine building. Just my Keith
[Re: CR8CRSHR]
#1390950
02/21/13 07:46 PM
02/21/13 07:46 PM
Posts: 5,161 CT
GTX MATT
CT
I would recommend disassembling and checking or having a shop do it if you don't have the tools/know how. I bought a pair around July. I took them apart to check them out. They came with comp 7 degree locks and retainers. Everything was pretty nice, and I hand lapped all of the valves. They produced a nice pattern with minimal lapping. One of the valve faces looked like it was machined funny, but there was nothing wrong with it. I'm not sure how to explain it, but it just had a different look in the center of the face, almost like the machinist stopped, and then re-continued. It was nothing physically different, just cosmetic. Two of the valves were a bit tough to pull out of the guides. The valve stems had decent clearance with the guides. I did not measure valvestem play, as there appeared to be none and my equipment wouldn't be accurate enough to measure .001 or whatever minimal amount there was. That being said they were not too tight, they felt perfect to me. I've run heads with MUCH tighter feeling guides that were fine (with my fingers crossed). The reason that the two valves were tough to pull out of the guides: Aluminum shavings. A fair amount, not one or two shavings, but a collection that was enough to sort of fill in the recession for the lock on the stem by the time the valve was out The shavings did not appear to cause any damage to the guides luckily (I sprayed a lot of oil and was cautious when they didn't want to come out). Also, apparently not all off the shelf head gaskets work with these heads still. I had a pair of the fel pro blues that come in the re-gasket kits (4.41 inch bore) and they overhung into one combustion chamber on each head (I believe it was cylinders 3 and 6 (same chamber on both heads, would orientate as 3 or 6 depending on the bank you installed it on). The ports looked nice, and looked like they had a little bit of cleanup work done after the fact by hand. Nothing drastic, but a little bit of work to clean them up in a few spots. This is just an amateur, wanna be engine builders opinion. Have them checked or check them out yourself. Its not hard if you have a valve spring compressor, and summit has tools to check valve spring height for 50-60 bucks .I believe they have bench "C Clamp" style valve spring compressors for about the same price. The compressor is a nice investment to make. Also, I think it goes without saying, but I had to clearance for 3/8 pushrods. A 5/16 checker pushrod I had was pretty close, but would have been ok. I haven't CC'd the combustion chambers yet, the heads are still off (I've been building this engine for literally 5 months as money and time allows, and my next summit purchase is going to be a burette for CC combustion chambers. I will report those findings eventually.
#1390951
02/21/13 10:29 PM
02/21/13 10:29 PM
Posts: 26 Annapolis, Md
71TrakPak
Annapolis, Md
If I purchased another set, I would still have them checked. Mine are from the second batch sold (had to wait as initial batch sold out quickly) and I had them checked at the machine shop along with all my engine parts. They found 5 valves with hair thin valve to seat contact area. I would not have believed them had I not seen it myself before I ok'd the 3 angle valve job. I would say that they were coming with marginal single angle valve jobs when I purchased mine early on. I'm glad I had them checked. Now if you add what I paid to have them redone and the cost of them then it puts you real close to a set of Eddy's made in USA......
not a sermon, just a thought.
1971 Charger R/T 4spd
[Re: Dunnuck Racing]
#1390952
02/21/13 11:55 PM
02/21/13 11:55 PM
moparpollack
Lil Herman
Lil Herman
85086
X2 when my machinist tore down my new heads 2 valves needed touch up to be seated.
[Re: moparpollack]
#1390953
02/22/13 12:38 AM
02/22/13 12:38 AM
Dunnuck Racing
Northern Indiana
For what its worth,I have seen more issues with Edelbrock heads than Stealth heads. I will be the first to admit that Im not the biggest engine builder around,and see more Edelbrock heads than any other. So it may be the fact that Ive seen more Edelbrock heads to see the problems. This is why I said to inspect ANY head before installing. Just good procedure,but some guys throw rings and bearings in an engine and never check clearances. I wouldn't recommend that either but I have seen guys get away with it. Keith
#1390956
02/22/13 07:49 AM
02/22/13 07:49 AM
therocks
Niles , Ohio
There is a big difference between a Mechanic and a machinist.My machinist was a perfectionist.Ive turned wrenches as a pro for over 30 years.I still brought my stuff to him to do.Lots of stuff Id check but with a good shop Its cheap insurance.Yeah a lot of people jus buy and bolt on.Some get away with it some dont.My buddy bought a hi buck set of heads for his Camaro.Didnt check them and in less than 100 miles had lots of problems.Between bent push rods and having to replace guides he had a lot more than having a shop check them.Rocky
Chrysler Firepower
