1970-71 E-Body Convertibles (Manual Top "Catch") #1390590
02/19/13 10:57 PM
02/19/13 10:57 PM
California, USA
filmsurgeon Offline OP
California, USA
My fender tag indicates that the car originally had a power top. During the earlier "restoration" (2003), the prior owner decided to convert to a manual drop-top (don't know why). Hence, no power top components left. The following description is from an older ebay listing:
'Hold down clamps' were installed onto ALL 1970-71 E body converts with a manual conv. top. These brackets bolt to the top inner wheel well area. All E conv's have 4 holes there. 2 on each side, power top convertible owners may have wondered what these 4 threaded holes were for upon their discovery. When your top frame is in its down position, these clamps will hold frame in place - to keep it from springing up while driving. Power top cars did not require these clamps - the hydraulic system prevents the frame from moving back up once its in its full-down position (unless a motor fails or a hydro line bursts.)"
I am considering going back to a power top, but would need ALL the components (i.e. pump, hoses, cylinders, harness/wiring/fuse, hoses, pump brackets and cylinders), and would be looking at a rough total cost of about $1K (gasp!). I have the "hold down clamps" described in the ebay listing, but the nylon 'catch' on one of them is damaged/worn. BTW - the Parts Catalog calls the part a "Catch". Any thoughts/advice on where I can get a good replacement? Obviously, each one is specific for one side. Any thoughts/advice on keeping the manual set-up over power conversion. I know each has its own pros and cons. BTW - when the listing was on ebay several years ago, the seller was asking $500 for the pair. They were both in good condition. I've attached several pictures. #1 is the ebay seller's photo. #2 and #3 are photos of my pieces (the close-up showing the damage/wear to the nylon where it catches the frame). #4 is a page from the Parts Catalog. #5 is the catch in its proper location (sorry for it being out-of-focus; it's not my photo, or my car). Thanks.
Re: 1970-71 E-Body Convertibles (Manual Top "Catch") [Re: filmsurgeon] #1390591
02/19/13 11:11 PM
02/19/13 11:11 PM
Georgia
magiccuda Offline
magiccuda  Offline
Georgia
I think I remember the 500 dollar listing on ebag. Thought that was way to much. I repaired one of mine buy drilling out the top rivet and using a small machine bolt as a catch works great and no one ever noticed. later I picked up an extra set for mine for less that a hundred some time back on there. They come up on there every once in while, if you keep an eye out you might score some at a reasonable amount, but Im sure it will take awhile.
Re: 1970-71 E-Body Convertibles (Manual Top "Catch") [Re: filmsurgeon] #1390592
02/19/13 11:14 PM
02/19/13 11:14 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Pump, lines & cylinders can be robbed from any K car convertible, I've grabbed complete assys for less than $100... The rear wiring harness from Year One includes that section of the top pump wiring & is less than $200... So you need the section of harness under the dash, Circuit breaker, the switch & bezel... To lower the top with manual tops you have to stop & get out of the car.. Power top you catch a stop light pop the latches & hit a button....
Re: 1970-71 E-Body Convertibles (Manual Top "Catch") [Re: 1_WILD_RT] #1390593
02/19/13 11:44 PM
02/19/13 11:44 PM
Ct, Oxford
340swing Offline
340swing  Offline
Ct, Oxford
Does anybody have a picture of these holes. I'm in the process of restoring a manual top 70 cuda I don't have these catches and don't see the holes on the inner fenders. The car was apart when I got it so I have no reference. Did they all have them or is there a time frame for these (early cars/late cars)
Re: 1970-71 E-Body Convertibles (Manual Top "Catch") [Re: 340swing] #1390594
02/20/13 12:34 AM
02/20/13 12:34 AM
California, USA
California, USA
These are photos of my holes. I don't know that they are the original location as the prior owner of my car (who did the resto-mod "restoration") did a 3" mini-tub. So, maybe he relocated the catch brackets to the support. Pay no attention to the dried adhesive all over the place. It's a long story. Part of the crap job the guy did when he did the resto-mod.
Re: 1970-71 E-Body Convertibles (Manual Top "Catch") [Re: magiccuda] #1390595
02/20/13 03:12 AM
02/20/13 03:12 AM
California, USA
California, USA
I'm considering buying some nylon stock and fabricating one using the one good one I have as a reference model. I'll bet it's not that difficult using a dremel and other misc hand and power tools. If I go this route, I'll post picts of the finished product.
Re: 1970-71 E-Body Convertibles (Manual Top "Catch") [Re: filmsurgeon] #1390596
02/20/13 08:49 AM
02/20/13 08:49 AM
Ct, Oxford
340swing Offline
340swing  Offline
Ct, Oxford
Thanks for the pics. I do have them they are in the rear cross member. I guess that is something to add to the list. I have never noticed those before. So if anybody has a set pm me.
Re: 1970-71 E-Body Convertibles (Manual Top "Catch") [Re: filmsurgeon] #1390597
02/20/13 11:17 AM
02/20/13 11:17 AM
South, FL
cudaized Offline
cudaized  Offline
South, FL
That has been done before. Take your time. It is not that difficult of job.
1970 `cuda340 convertible 4-speed Rallye Red with Red interior
cudaized.com
1970-71 Plymouth and Dodge E-Body Convertible Registry
ebodyconvertibleregistry.com
Re: 1970-71 E-Body Convertibles (Manual Top "Catch") [Re: cudaized] #1390598
02/20/13 01:27 PM
02/20/13 01:27 PM
California, USA
California, USA
Any ideas where to go for the nylon stock, and am I correct in assuming they are made of nylon?
Re: 1970-71 E-Body Convertibles (Manual Top "Catch") [Re: filmsurgeon] #1390599
02/22/13 05:33 PM
02/22/13 05:33 PM
California, USA
California, USA
Just bought 1 foot of this nylon rectangle bar stock for $25.00 (tax and shipping included). It's 1-1/2" x 1" (same height and width dimensions as the original molded nylon "catch"). Can't wait for it to arrive so I can start shaping a new piece. I'll probably make (2) so I have fresh matching material. Since the length of the "catch" is only 1-3/4", I'll have enough stock for multiple attempts in case I make any shaping mistakes. I'll post pictures when I'm done.
Re: 1970-71 E-Body Convertibles (Manual Top "Catch") [Re: filmsurgeon] #1390600
03/04/13 02:50 AM
03/04/13 02:50 AM
California, USA
California, USA
I thought I'd report back for the benefit of sharing my experience with others. So far, I have received the nylon bar stock (it is actually not as white in color as it appears to be in the pictures; it is more of a "natural" color, which is closer to the 40 year old part); drilled out the 1/8" rivets to separate the nylon "catch" from the spring steel leg; traced the profile of the catch to the new stock. Next will be to start cutting and shaping. I'll continue to take photos to illustrate the process, and post as progress is made. I hope all goes well. Enjoy, and thanks for all the feedback.
Re: 1970-71 E-Body Convertibles (Manual Top "Catch") [Re: filmsurgeon] #1390601
03/23/13 12:04 PM
03/23/13 12:04 PM
MI, Livingston
P
plymth70 Offline
plymth70  Offline
P
MI, Livingston
I have 3d data, Im looking for a shop to make a tool. Will let you know when I have some luck.
Re: 1970-71 E-Body Convertibles (Manual Top "Catch") [Re: plymth70] #1390602
03/23/13 06:33 PM
03/23/13 06:33 PM
California, USA
California, USA
That is VERY COOL! How did you do that? Depending on how soon you can get a shop to machine new pieces, I may end up having to get some from you. A couple of days ago, I began carving a new piece from the nylon bar stock. It was a bit of a learning experience at the start (first attempt to "cut out" the basic shape was not good). I ended up using only a variable speed dremel at its lowest speed with a cutting bit to cut and shape the new piece. It's turned out pretty good so far (I still have to carve out the area where the part is riveted to the spring steel leg). It's taken quite some hours so far, but I think the end results will be most satisfactory. I'll post pictures one I've completed the first piece.
Re: 1970-71 E-Body Convertibles (Manual Top "Catch") [Re: filmsurgeon] #1390603
03/24/13 09:40 AM
03/24/13 09:40 AM
SE PA
cudaize Offline
cudaize  Offline
SE PA
If the nylon can be water jet cut this would probably be the most economical solution. I would look at getting someone to waterjet cut the complex shape and then have the relief for the screws milled in.
Re: 1970-71 E-Body Convertibles (Manual Top "Catch") [Re: cudaize] #1390604
01/22/14 07:07 PM
01/22/14 07:07 PM
California, USA
California, USA
Hello Everyone. I know it's been a long time since the last post on this topic, but I wanted to report back on the latest progress. I tried many months ago to make a new nylon piece from the nylon bar stock using a dremel and various cutting/carving bits. I got close to finishing one piece, but decided to put the project on the "back burner" so I could work on other stuff the car needed. The carving/cutting was very tedious and time consuming, and VERY messy (nylon shavings everywhere). Toward the end of the year I decided to revisit the project. Someone here posted a 3D image of the piece, and I thought about having my one good piece 3D scanned, and have it "printed" in nylon using a 3D printing service provider. I researched 3D printing, and sourced a small company in the Los Angeles area that provided both scanning and printing. Not all 3D printers can print using nylon (most print using ABS, or similar plastic materials). Anyway, after my approval of the 3D images (see attached), the new pieces were printed, and I received the first pair several weeks ago, but they were slightly smaller in size compared to the original (probably due to cleaning up the 3D scan). I provided caliper measurements of the new and original pieces, and asked if the 3D data file could be manipulated so that the dimensions matched the original. The answer was "Yes". The 3D scan file was adjusted and new pieces were made. I just got them today (see photos of new vs. old pieces). The turnaround was relatively quick; and quite surprisingly, the cost was really not that bad. 3D scan was $25.00, and printing (2) pieces was $13.00 + $10.00 shipping (total = $48.00). I also received the 3D data file (STL format), so I can send this to any 3D printing company and have more pieces made. Let me know if anyone needs some.
Re: 1970-71 E-Body Convertibles (Manual Top "Catch") [Re: filmsurgeon] #1390605
01/22/14 07:36 PM
01/22/14 07:36 PM
South, FL
cudaized Offline
cudaized  Offline
South, FL
Nice job Joseph.
cudaized.com
Re: 1970-71 E-Body Convertibles (Manual Top "Catch") [Re: cudaized] #1390606
01/22/14 10:50 PM
01/22/14 10:50 PM
Ct, Oxford
340swing Offline
340swing  Offline
Ct, Oxford
That is so cool NICE JOB!!! mine are good for now but I will bookmark that one.
Re: 1970-71 E-Body Convertibles (Manual Top "Catch") [Re: filmsurgeon] #1390607
01/22/14 11:14 PM
01/22/14 11:14 PM
Salem
Grizzly Offline
Moparts Proctologist
Grizzly  Offline
Salem
That is very considerate of you to take your own time, hard work and expenses and offer this to us. Thanks very much!
Them 3D printers and digitizing are a freakin' gift to us in the Mopar hobby with all the obsolete parts, inferior reproduction companies, and greedy ebay people that we have to deal with.
Thanks for updating the thread.
Any thoughts on doing the plastic catches for the top of the windshield molding? I have a repro set and they are pure crap.
Mo' Farts
Moderated by "tbagger".
Re: 1970-71 E-Body Convertibles (Manual Top "Catch") [Re: Grizzly] #1390608
01/27/14 06:29 PM
01/27/14 06:29 PM
California, USA
California, USA
I have been contacted by quite a few people (here and on Cuda-Challenger) expressing interest in these new nylon pieces. I will be placing an order soon to have a bunch made after I've figured out how many. In the meantime, I will be getting back to all of you soon with responses to your messages. Thank you for your interest.
BTW - Here are a few photos showing the new nylon catches attached with pop rivets to the spring steel legs. I ended up having to slightly hone out the holes in the new pieces in order to get the 1/8" rivets through. They didn't need much; just held a 1/8" drill bit in hand, and pushed it through while twisting, and then back and forth a few times.
Re: 1970-71 E-Body Convertibles (Manual Top "Catch") [Re: filmsurgeon] #1390609
01/27/14 06:34 PM
01/27/14 06:34 PM
California, USA
California, USA
Got a few questions about these manual top hold down brackets. Does anyone have any info about, (or photos showing) where exactly the brackets mount inside the car? I'm pretty darn certain the previous owner did not mount them in the correct location. He had them bolted to the angled ends of the cross brace, and the drilled holes definitely don't look original. Other evidence that indicates incorrect mounting were the additional "extension" pieces that he used between the bracket and the catch. They don't look original; and from other photos I've seen of complete bracket assemblies, there were no extensions. Also, where did the nylon catch make contact on the convertible top frame to hold it down when it was lowered into the well? Regarding the well liner: Were the brackets mounted with the well liner underneath them, or were there "slits" made into the well liner to allow the spring steel leg to poke through (therefore, the bracket would not be seen from inside the car, only the nylon catch)? It kinda makes sense to me that the entire bracket assembly would be visible from inside the car, hence holes would be made in the well liner for the mounting bolts. Thanks for any help.
