Re: 5.7or 6.1
[Re: cudadan]
#1390286
02/19/13 11:54 AM
02/19/13 11:54 AM
Posts: 2,941 GA
roadrunninMark
GA
There is tons of info for this swap. Check out some of our own members write ups: (this from member 808cuda) https://board.moparts.org/ubbthreads/show...e=1#Post3930520 Also, member Daty Rogers has done the swap. If you go over to cuda-challenger.com, they have swaps as well. Bouchillon performance (http://www.bouchillonperformance.com/) or mancini have just about everything you need. Did you finish your A518 swap? 5.7s can be found pretty cheap but 6.1 is a little harder to get. Mark
Re: 5.7or 6.1
[Re: cudadan]
#1390290
02/20/13 09:39 PM
02/20/13 09:39 PM
Posts: 3,998 GO BUCKS !!!!!!!
340RICK
GO BUCKS !!!!!!!
Been thinking about this swap for a while now. Just wondering jow hard it is to put in an e body. Ill be doin all the work myself. Fabing anything i need. What issues have u guys gone through. Possible cost of the project... Any sites for parts or any infonwould be great. Thx
Here is a 6.1 HEMI in my Challenger.
TTi has most of the swap parts its a piece of cake
Re: 5.7or 6.1
[Re: cudadan]
#1390294
02/22/13 09:23 PM
02/22/13 09:23 PM
Posts: 2,941 GA
roadrunninMark
GA
Hey Dan, you should be able to use an existing harness and just use the connections you need. This will save you a lot of money as those "done" harnesses go for around $900. This guy over on cuda-chllenger modified the original harness, plus doing a number of "home brew" stuff like you are planning. Here is the thread.... http://www.cuda-challenger.com/cc/index.php?topic=89416.0I PMd him to see if he finished his spread sheet on how he did everything but haven't heard back yet. Another member his trying to get me his CAD drawing for the 518 trans cross member that he had fabbed up. I can forward you the info once I receive it. Also, once you have the mounts down pat, would you be interested in making a second pair in which I could purchase off of you, or work out some kind of deal for a pair? Thanks
Re: 5.7or 6.1
[Re: cudadan]
#1390297
02/23/13 09:41 PM
02/23/13 09:41 PM
Posts: 1,130 Dayton, Ohio
wldtm
Dayton, Ohio
get that harness and use the PCM master powertrain diagram for a ram 1500 with a 5.7. works perfect.
justin
Interested in having you car wired? Drag car, street car, EFI swap?
PM for details
Re: 5.7or 6.1
[Re: wldtm]
#1390299
02/24/13 02:02 AM
02/24/13 02:02 AM
Posts: 2,617 Stratford nj
cudadan
Stratford nj
justin
Can u send me some more info?. Hkw much lf the harness do i get? Thx
