Ball joint? #1390043
02/19/13 12:35 AM
02/19/13 12:35 AM
Alexandria,La.
BigTerry Offline OP
BigTerry  Offline OP
Alexandria,La.
What the best way to greases factory joint beside drilling and tapping? grease needle?
Re: Ball joint? [Re: BigTerry] #1390044
02/19/13 12:51 AM
02/19/13 12:51 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
On ? I put the end of the hose from my grease gun onto my zerks and give the grease gun a few pumps. Then repete on the next zerk till I have lubed all of them. I grease the U joints at the same time..
I am truckless..
Re: Ball joint? [Re: 340SHORTY] #1390045
02/19/13 12:57 AM
02/19/13 12:57 AM
Alexandria,La.
BigTerry Offline OP
BigTerry  Offline OP
Alexandria,La.
I have factory ball joints there no grease zerks on them.. it a 08 ram truck!
Re: Ball joint? [Re: BigTerry] #1390046
02/19/13 04:20 AM
02/19/13 04:20 AM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Wait till their bad and grease the new ones
Re: Ball joint? [Re: 76dodgeboy] #1390047
02/20/13 02:23 PM
02/20/13 02:23 PM
SoMd, USA
135sohc Offline
135sohc  Offline
SoMd, USA
If there the same garbage that our 02 had then it wont be too much longer before the boots start to crack and split open.
Re: Ball joint? [Re: 135sohc] #1390048
02/20/13 10:01 PM
02/20/13 10:01 PM
Alexandria,La.
BigTerry Offline OP
BigTerry  Offline OP
Alexandria,La.
I guess I get a needle to grease them! thanks!
Re: Ball joint? [Re: BigTerry] #1390049
02/28/13 08:42 AM
02/28/13 08:42 AM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
That'll just put grease in front of the ball and not behind/inside the joint where it needs to be.
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: Ball joint? [Re: GoodysGotaCuda] #1390050
03/03/13 08:08 PM
03/03/13 08:08 PM
Alexandria,La.
BigTerry Offline OP
BigTerry  Offline OP
Alexandria,La.
if a little get in wouldn't that be good??
Re: Ball joint? [Re: BigTerry] #1390051
03/03/13 09:22 PM
03/03/13 09:22 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Needs to be all around. if just on one side sure its good for that area but the area without is still going to wear faster and cause failure. Basically grease in just inequality spot won't really prolong the life. needs to be pretty much 100% of it affected to work proper
Re: Ball joint? [Re: 76dodgeboy] #1390052
03/03/13 10:39 PM
03/03/13 10:39 PM
Alexandria,La.
BigTerry Offline OP
BigTerry  Offline OP
Alexandria,La.
what do I need to do to prolong the life of my steering components?? I'm don't have the funds to replace items when they do fail... I don't have any issues with anything except some squeaks when I backing up and sometime when I making a turn from a complete stop..
Re: Ball joint? [Re: BigTerry] #1390053
03/03/13 10:49 PM
03/03/13 10:49 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
I inject a little grease in all those fittingless ball joint and tie rod boots with a needle type grease gun. Especially when that boot is looking real flat. Grease may not get to the underside of the ball socket, but it's better than nothing. 2 or 3 times a year here.
Re: Ball joint? [Re: buildanother] #1390054
03/03/13 11:51 PM
03/03/13 11:51 PM
Alexandria,La.
BigTerry Offline OP
BigTerry  Offline OP
Alexandria,La.
that what i was thinking something better then nothing!
Re: Ball joint? [Re: BigTerry] #1390055
03/05/13 09:14 AM
03/05/13 09:14 AM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
you can add your own jerk fittings
http://www.saeproducts.com/thread-forming-grease-fittings.html
magnetize the correct drill bit
by attaching for 24 hours
two super strong button magnets
like the small rare earth ones
that can be bought in a six piece pack at Harbor freight.
http://www.harborfreight.com/10-piece-rare-earth-magnets-67488.html
if you use a slow rpm speed drill
you can even leave the button magnets attached near the tip
If you wish coat the bit with heavy grease to further catch metal or paint shavings.
drill just a little at a time,
then clean and recoat drill
you may also want to magnetize the jerk fitting
to hold onto metal shavings
in my opinion
the threat from metal shavings
is far less than the threat
of water getting in the joints
when it is not packed with grease
DO NOT OVER GREASE
as you can do more damage
blowing out the seal
which will allow water and contaminants in
go slow with the pumps of grease
stop at just a hint of grease coming past the seal
Re: Ball joint? [Re: 360view] #1390056
03/06/13 11:25 PM
03/06/13 11:25 PM
Alexandria,La.
BigTerry Offline OP
BigTerry  Offline OP
Alexandria,La.
that cool! I didn't really want to go there! I will think about it... thanks!
