A body to BB K member Question
#1390033
02/19/13 12:10 AM
02/19/13 12:10 AM
Posts: 3,449 Gateway to the West.
hemi_harvester
Using Shoemaker relocation mounts to put a B engine on the A engine A body k-member , anyone know if there are limitation to oil pans ?
There comes a time in life, when you walk away from all the drama & people who create it. You surround yourself with people who make you laugh, forget the bad, and focus on the good.
Re: A body to BB K member Question
[Re: hemi_harvester]
#1390034
02/19/13 12:48 AM
02/19/13 12:48 AM
RapidRobert
I used their BB conversion mounts on a /6 kmember 69 valiant & used a regular shallow BB pan the one with the idler arm indentation & kept the shallow /6 centerlink. The ones that require some trimming of the Kmember pedestal. Perfect fit. Not sure this answers your Q so here's a BTT
[Re: RapidRobert]
#1390039
02/19/13 12:39 PM
02/19/13 12:39 PM
Posts: 18,678 Fresno, CA
Jim_Lusk
Fresno, CA
As to the first responce, there is no such thing as a slant/shallow center link for the late A's. There were two different links, early and late (67-72, 73-76).
Oh OK, one group for 67-72 & another for 73-76, now I got it . iirc the idler/pitman taper was the opposite & the ends turned 90 deg on 73-76 A
The late link has the idler and pitman arm studs pointing down and in line with the tie rod ends. The early link has the studs pointing up with the tie rods about 90 degrees off.
[Re: 69 DART GTS 440]
#1390041
04/09/13 10:29 AM
04/09/13 10:29 AM
Posts: 75,066 U.S.S.A.
JohnRR
U.S.S.A.
This is exactly my issue 440 in 69 Dart GTS ( originallky a 383) . From where can I get these stock 5 qt oil pans with the idler arm indent? Does Schumacher carry them?
the pan is not reproduced , you have to find them used.
Place a want ad in the appropriate section ???
