Re: Chassis question
[Re: quickd100]
#1389989
02/19/13 12:32 AM
02/19/13 12:32 AM
Posts: 52,972 Romeo MI
MR_P_BODY
I put the truck on the scales yesterday and then set up what Bill Shope calls a traction dyno. (Scaled all 4 corners, remove rear scales and block rear tires, hook chain to rear of truck and winch weight off the front axle.) After adjusting the 4-link as much as possible I got it down to 98lbs. from equal loading on the back tires on launch. (If I move the battery I can get it down to 43lbs.) Is this close enough for it to launch straight?Dave
Thats a unknown for your ride... to me thats still high but I deal with a lot lighter cars... most you can do now is try it and find out
[Re: quickd100]
#1389990
02/19/13 12:47 AM
02/19/13 12:47 AM
Posts: 2,125 Byron, NY
W.I.N. Racing
Byron, NY
Scaling just gives you a starting point and a point to reset to. The only real way to find out is to take it to the track and adjust from there.
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
