Re: lock tight on connecting rod bolts
[Re: 68-scatpack-rt]
#1389742
02/21/13 03:27 PM
02/21/13 03:27 PM
Posts: 20,185 PA.
pittsburghracer
"Little"John
"Little"John
PA.
These pretzels are making me thirsty.
[Re: moparmikethree]
#1389746
02/21/13 06:37 PM
02/21/13 06:37 PM
Posts: 75,043 U.S.S.A.
JohnRR
U.S.S.A.
All I wanted to know if it would be added insurance. I figured if you use oil to get the proper torque , lock tight (when wet) would act the same as oil
Nice thought but just because it is a liquid does not mean it is viscious like oil ... or a moly lube ...
[Re: JohnRR]
#1389747
02/21/13 06:44 PM
02/21/13 06:44 PM
Challenger 1
Cincinnati, Ohio
Loctite is a aerobic sp? it cures hard in the absence of air, so it's curing before you can get the hardware tight and will affect the torque. It's not a lube at all, none.
#1389749
02/21/13 09:31 PM
02/21/13 09:31 PM
Posts: 27 Southern Indiana
R/T Lee
Southern Indiana
Just an FYI that might help you. My work sent me to a Loctite seminare. My general ideas about Loctite before this class was usually negative. But now I have a diffrent outlook on the product (when used properly). A couple tips to help you is everything must be clean! And make sure you are using the correct grade/strength. generally blue= normal grade, Red= high strength, green = high grade(bearing retainer). There are hundreads of grades inbetween, this is how I remember. Also, Loctite only bonds to metals that corrode. So Stainless, aluminum won't work. (They make special primers u can spray to work on these metals, but wont work without). As to your original question, it's not neccessary. You can use, I built a 318 with blue on the rod bolts just for the heck of it. And built another sb for a customer (from his request), but usually I use 30w oil. Hope this helps.
NO!! It's not a Nova...
72' Demon 340-727-8 3/4 3.55 69' Charger 440-727-8 3/4 78 Powerwagon 318-727 99' Dakota R/T 5.9 74' Scamp (project) 96' Cherokee 4.0 4x4
#1389751
02/21/13 10:21 PM
02/21/13 10:21 PM
Challenger 1
Cincinnati, Ohio
Of it's everyone worse nightmare come true if a rod bolt/nut were to come loose or not get torque right or enough. Why back when, when I built my first couple motors I remember laying in bed at night thinking to myself, did I torque all those nuts on the rods? Then I couldn't sleep. Then the next day I would check em again even though I had to pull the pan and none were ever loose. Then I got into a routine and do it the same way every time and never stop or mess around when I'm doing the bottom end. I usually am by myself with no interruptions and can almost do it blind. Especially when I was rebuilding brad hemis every week. I rebuilt them I swear 75 or more times and never ever started them at the shop. Always waited until we got the track to fire them and never ever had a bad engine, they always ran killer. I'm pretty proud of that fact. But I remember when loctite hit the market it was never for critical fasteners like rod and main cap bolts/nuts that needed to stretch.
