12" wheelstand then the tires shimmy when it comes down #1389601
02/18/13 11:58 AM
02/18/13 11:58 AM
Stuttgart, Arkansas
rickseeman Offline OP
Stuttgart, Arkansas
My buddy's 68 Barracuda bracket car does a nice little wheelstand at the launch, but when it comes down, the front tires shimmy for a little bit. Looks bad/dangerous. What do we need to do to fix this? Is this a bump steer issue? Thanks for your help.
2011 Drag Pak Challenger
Re: 12" wheelstand then the tires shimmy when it comes down [Re: rickseeman] #1389602
02/18/13 12:08 PM
02/18/13 12:08 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Stock front end... look at all the parts but I would
think pitman or idler arms
Re: 12" wheelstand then the tires shimmy when it comes down [Re: MR_P_BODY] #1389603
02/18/13 12:14 PM
02/18/13 12:14 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
I agree, had a similar issue and had a idler arm getting loose, it don't take much, so I would check everything.
Re: 12" wheelstand then the tires shimmy when it comes down [Re: dartman366] #1389604
02/18/13 12:40 PM
02/18/13 12:40 PM
Dyno1 Offline
Dyno1  Offline
loose strut rods will also cause this. Dyno
Re: 12" wheelstand then the tires shimmy when it comes down [Re: rickseeman] #1389605
02/18/13 12:44 PM
02/18/13 12:44 PM
MR_P_BODY Offline
MR_P_BODY  Offline
With the stock front end, it could be the toe change
causing it.. you might not even feel a bad part.. it
could be flexing the front end parts and flexing the
weakest point
Re: 12" wheelstand then the tires shimmy when it comes down [Re: Dyno1] #1389606
02/18/13 12:50 PM
02/18/13 12:50 PM
dayton,ohio
ROSSIO Offline
ROSSIO  Offline
dayton,ohio
I have the same thing happen all the time
All my susp.stuff is new and it still happens
I've checked everything,it's all tight and align
Good
1970 DART B1MC N/A 8.86@ [Email]155 3200 lb on 275 DR 5.30 @ 130 1/8
Re: 12" wheelstand then the tires shimmy when it comes down [Re: ROSSIO] #1389607
02/18/13 12:56 PM
02/18/13 12:56 PM
Stuttgart, Arkansas
Stuttgart, Arkansas
One guy told me it was a "bump steer" thing. Like when the front end is off the ground, it has either toe in or out, and when it comes back down it has to straighten up. He thought there was a "bump steer" kit to put on it that would fix it. I hope he is right.
Re: 12" wheelstand then the tires shimmy when it comes down [Re: rickseeman] #1389608
02/18/13 01:11 PM
02/18/13 01:11 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
Yep remeber those days. Video the front wheel and then play it back in slow motion if want to get real nervous. The front wheel steers back and forth a few times. You feel it in the steering wheel.
I reduced it but it was still there. New joints bushings. Equalized the tie rods and centered the wheel. Limited bump travel. This all helped. But, would not get rid of all of it. Probably still had some bump steer.
Replaced front end with tubular stuff and a rack and pinion. Now have zero bump steer and no shimmers.
Note...
Not all aftermarket frontends fix cars some make them worse.
Re: 12" wheelstand then the tires shimmy when it comes down [Re: Leon441] #1389609
02/18/13 03:30 PM
02/18/13 03:30 PM
A shed in England
Tig Offline
Tig  Offline
A shed in England
Check this out
http://www.youtube.com/watch?v=91dmTS-UvDc
We've made it better but it still does it
We have over 7 inches of travel on the front end, it was never designed for that much.
Re: 12" wheelstand then the tires shimmy when it comes down [Re: Tig] #1389610
02/18/13 05:01 PM
02/18/13 05:01 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
Wow scares me !! thats alot
Re: 12" wheelstand then the tires shimmy when it comes down [Re: VernMotor] #1389611
02/18/13 05:04 PM
02/18/13 05:04 PM
The Wet Coast, Canada
megajoltman Offline
megajoltman  Offline
1969 Dart 383/727/D60
CTD Ram 4x4 Mega Cab
Procharged 350Z
Re: 12" wheelstand then the tires shimmy when it comes down [Re: megajoltman] #1389612
02/18/13 05:13 PM
02/18/13 05:13 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
Re: 12" wheelstand then the tires shimmy when it comes down [Re: slantzilla] #1389613
02/18/13 05:26 PM
02/18/13 05:26 PM
Finland
mafo Offline
mafo  Offline
Finland
scary movie
http://www.youtube.com/watch?v=RlZMelhbIrk
skip to 2 min...
-65 Valiant,420", all motor,2700#, dot tires, 8,42 @ 160,2
Re: 12" wheelstand then the tires shimmy when it comes down [Re: Tig] #1389614
02/18/13 06:36 PM
02/18/13 06:36 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
Check this out
Pretty normal TIG. I see the bounce is allowed to let the tire way too far up into the fender IMO. Try a thicker bump stop on the lower control arm if you want to reduce that.
Need a big hit of nitrous about half way through the wheelstand and ride her out. LOL
Leon
Re: 12" wheelstand then the tires shimmy when it comes down [Re: Leon441] #1389615
02/18/13 06:47 PM
02/18/13 06:47 PM
A shed in England
Tig Offline
Tig  Offline
A shed in England
We had C/E 3 ways on back then. Now we have Afco d/a's with the BNC valving
I hear ya on the nitrous hit though, Maybe's we could get to the 1/8th
http://www.youtube.com/watch?v=01qA0_3sBZY
Re: 12" wheelstand then the tires shimmy when it comes down [Re: Leon441] #1389616
02/18/13 06:48 PM
02/18/13 06:48 PM
Shelby mi.
JAKE68 Offline
JAKE68  Offline
Shelby mi.
Bump steer has a huge affect on that problem but there is something else contributing to it. When the front end is going threw its travel caster is changing big time. When up in air and coming down it could change as much as 5deg. that is why limiting travel helps allot. If you can keep toe change to asclose to 0 as possible it helps. The problem is if you look at the angle of the upper control arm pivot point you will see how that happens. It is hard to change that without like doing a chassis car type front end wich would have the upper control arms pivot level to the pivot the the lower goes threw. So caster does not change. So for most cars to bring it to minimal use the mopar chassisbook guide lines for correcting toe change and that will help allot.
JAKES AUTOMOTIVE
Re: 12" wheelstand then the tires shimmy when it comes down [Re: Tig] #1389617
02/18/13 06:51 PM
02/18/13 06:51 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Check this out
I may be wrong but in this case I don't think static bump steer is the issue. There are inches of toe change with almost zero ride height change. Stop/start the video after the return to earth. There's definitely a toe change happening. I think it's a combination of flex , bushing compression and expansion. My bet the number one culprit here are the strut rod bushings. Possibly the control arm bushings as well. Add a little flex and whala. My 2 cents.
Doug
Re: 12" wheelstand then the tires shimmy when it comes down [Re: Leon441] #1389618
02/18/13 07:08 PM
02/18/13 07:08 PM
Long Island, NY
ValiantRich Offline
ValiantRich  Offline
Long Island, NY
I had the same problem with my Valiant. I tried everything you could think of and couldn't stop the tires from shaking. The car was in Ken Kier's shop for a different reason and I mentioned it to him. He checked the whole car and couldn't find anything wrong. He said that when this happens, the only thing to do is put a shock absorber on the steering linkage. He fabricated small brackets and mounted a small motorcycle shock to the centerlink and I never had the problem again.
Re: 12" wheelstand then the tires shimmy when it comes down [Re: dvw] #1389619
02/18/13 07:13 PM
02/18/13 07:13 PM
A shed in England
Tig Offline
Tig  Offline
A shed in England
Check this out
Doug
Not wishing to Hijack the thread but the car has solid strut's with the Heim joints, tubular uca's with Heims, boxed lca's with poly bushes. The idler arm was replaced too. A good set up helped but you can't get away from the physics of the set up. The upper, lower and track rod arms all run through different arcs and pull the wheel every which way through the travel. Limiters help but really just mask the problem we have them too. Only real cure is going to a strut type front suspension I'd guess.
In real time, at it's worst, it was a brief shimmy of the steering wheel on touch down.
If you watch some of the old Super stock vids on you tube a lot of the mopes do it.
I just put it down as inherent but made worse by a poor set up / alignment job.
Again apologies to the OP for hijacking but hopefully this helps some.
Re: 12" wheelstand then the tires shimmy when it comes down [Re: Tig] #1389620
02/18/13 07:21 PM
02/18/13 07:21 PM
Guitar Jones Offline
I see a lot of the stock front suspension cars doing this not just the mopes. My Duster did it too but wasn't a handling or control concern, it just did it and quit.
