12" wheelstand then the tires shimmy when it comes down
#1389601
02/18/13 11:58 AM
02/18/13 11:58 AM
Posts: 2,690 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
My buddy's 68 Barracuda bracket car does a nice little wheelstand at the launch, but when it comes down, the front tires shimmy for a little bit. Looks bad/dangerous. What do we need to do to fix this? Is this a bump steer issue? Thanks for your help.
2011 Drag Pak Challenger
Re: 12" wheelstand then the tires shimmy when it comes down
[Re: MR_P_BODY]
#1389603
02/18/13 12:14 PM
02/18/13 12:14 PM
dartman366
Mt. Vernon, Ohio
Stock front end... look at all the parts but I would think pitman or idler arms
I agree, had a similar issue and had a idler arm getting loose, it don't take much, so I would check everything. ![](/ubbthreads/images/graemlins/coffeetime.gif)
[Re: rickseeman]
#1389605
02/18/13 12:44 PM
02/18/13 12:44 PM
Posts: 52,972 Romeo MI
MR_P_BODY
With the stock front end, it could be the toe change causing it.. you might not even feel a bad part.. it could be flexing the front end parts and flexing the weakest point ![](/ubbthreads/images/graemlins/wave.gif)
[Re: Dyno1]
#1389606
02/18/13 12:50 PM
02/18/13 12:50 PM
Posts: 401 dayton,ohio
ROSSIO
dayton,ohio
I have the same thing happen all the time All my susp.stuff is new and it still happens I've checked everything,it's all tight and align Good ![](/ubbthreads/images/graemlins/Twocents.gif)
1970 DART B1MC N/A
8.86@ [Email]155
3200 lb on 275 DR
5.30 @ 130 1/8
[Re: ROSSIO]
#1389607
02/18/13 12:56 PM
02/18/13 12:56 PM
rickseeman
Stuttgart, Arkansas
One guy told me it was a "bump steer" thing. Like when the front end is off the ground, it has either toe in or out, and when it comes back down it has to straighten up. He thought there was a "bump steer" kit to put on it that would fix it. I hope he is right.
[Re: rickseeman]
#1389608
02/18/13 01:11 PM
02/18/13 01:11 PM
Posts: 4,330 Lynchburg, VA
Leon441
Lynchburg, VA
Yep remeber those days. Video the front wheel and then play it back in slow motion if want to get real nervous. The front wheel steers back and forth a few times. You feel it in the steering wheel.
I reduced it but it was still there. New joints bushings. Equalized the tie rods and centered the wheel. Limited bump travel. This all helped. But, would not get rid of all of it. Probably still had some bump steer.
Replaced front end with tubular stuff and a rack and pinion. Now have zero bump steer and no shimmers.
Note... Not all aftermarket frontends fix cars some make them worse.
[Re: Leon441]
#1389609
02/18/13 03:30 PM
02/18/13 03:30 PM
Posts: 2,937 A shed in England
Tig
A shed in England
Check this out http://www.youtube.com/watch?v=91dmTS-UvDcWe've made it better but it still does it ![](/ubbthreads/images/graemlins/hammer.gif) We have over 7 inches of travel on the front end, it was never designed for that much.
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
[Re: Leon441]
#1389615
02/18/13 06:47 PM
02/18/13 06:47 PM
Tig
A shed in England
We had C/E 3 ways on back then. Now we have Afco d/a's with the BNC valving ![](/ubbthreads/images/graemlins/thumbs.gif) I hear ya on the nitrous hit though, Maybe's we could get to the 1/8th http://www.youtube.com/watch?v=01qA0_3sBZY
[Re: Leon441]
#1389616
02/18/13 06:48 PM
02/18/13 06:48 PM
Posts: 1,495 Shelby mi.
JAKE68
Shelby mi.
Bump steer has a huge affect on that problem but there is something else contributing to it. When the front end is going threw its travel caster is changing big time. When up in air and coming down it could change as much as 5deg. that is why limiting travel helps allot. If you can keep toe change to asclose to 0 as possible it helps. The problem is if you look at the angle of the upper control arm pivot point you will see how that happens. It is hard to change that without like doing a chassis car type front end wich would have the upper control arms pivot level to the pivot the the lower goes threw. So caster does not change. So for most cars to bring it to minimal use the mopar chassisbook guide lines for correcting toe change and that will help allot.
JAKES AUTOMOTIVE
[Re: Tig]
#1389617
02/18/13 06:51 PM
02/18/13 06:51 PM
Posts: 9,893 MI, usa
dvw
MI, usa
I may be wrong but in this case I don't think static bump steer is the issue. There are inches of toe change with almost zero ride height change. Stop/start the video after the return to earth. There's definitely a toe change happening. I think it's a combination of flex , bushing compression and expansion. My bet the number one culprit here are the strut rod bushings. Possibly the control arm bushings as well. Add a little flex and whala. My 2 cents. Doug
[Re: dvw]
#1389619
02/18/13 07:13 PM
02/18/13 07:13 PM
Tig
A shed in England
Not wishing to Hijack the thread but the car has solid strut's with the Heim joints, tubular uca's with Heims, boxed lca's with poly bushes. The idler arm was replaced too. A good set up helped but you can't get away from the physics of the set up. The upper, lower and track rod arms all run through different arcs and pull the wheel every which way through the travel. Limiters help but really just mask the problem we have them too. Only real cure is going to a strut type front suspension I'd guess. In real time, at it's worst, it was a brief shimmy of the steering wheel on touch down. If you watch some of the old Super stock vids on you tube a lot of the mopes do it. I just put it down as inherent but made worse by a poor set up / alignment job. Again apologies to the OP for hijacking but hopefully this helps some.
[Re: Tig]
#1389620
02/18/13 07:21 PM
02/18/13 07:21 PM
Posts: 20,696 in a cattle trailer down by th...
Guitar Jones
I see a lot of the stock front suspension cars doing this not just the mopes. My Duster did it too but wasn't a handling or control concern, it just did it and quit.
