Re: Green with envy!
[Re: astjp2]
#1389527
03/08/13 03:26 PM
03/08/13 03:26 PM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
Got the skin from AMD last night, now I need to get it down to the body guy tomarrow. That should be the last piece of sheetmetal I need to buy for this car.
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
[Re: Dartman440]
#1389529
03/17/13 02:10 PM
03/17/13 02:10 PM
astjp2
Utah and Alaska
So I went to treat my K-member bolts in OSPHO, I poured some into a small container, put the bolts in and let them sit for a week. The grease and oils came off and floated to the top and they turned black, but after a week, the acid turned to a green jelly like substance. I tried to wash it off with water and it got most of it but not all of it. I placed some more fresh ospho in it and I am getting ready to pull out the parts now...I will keep you posted. Tim
[Re: astjp2]
#1389530
06/26/13 04:13 PM
06/26/13 04:13 PM
astjp2
Utah and Alaska
I some work from yesterday, boy that hemi barely clears!
[Re: astjp2]
#1389531
06/26/13 04:19 PM
06/26/13 04:19 PM
astjp2
Utah and Alaska
Another of putting in the engine.
[Re: astjp2]
#1389532
06/26/13 04:20 PM
06/26/13 04:20 PM
astjp2
Utah and Alaska
Right valve cover didn't clear....
[Re: astjp2]
#1389534
06/26/13 04:22 PM
06/26/13 04:22 PM
astjp2
Utah and Alaska
Motor got a little dusty in the body shop.
[Re: astjp2]
#1389535
06/26/13 04:22 PM
06/26/13 04:22 PM
astjp2
Utah and Alaska
Trying to get the wheels on!
[Re: astjp2]
#1389536
06/26/13 04:24 PM
06/26/13 04:24 PM
astjp2
Utah and Alaska
On the trailer today, 6/26/2013, over a year and a half since leaving my possession...
[Re: astjp2]
#1389537
06/26/13 04:25 PM
06/26/13 04:25 PM
astjp2
Utah and Alaska
On the road to the house.
[Re: astjp2]
#1389539
06/26/13 04:26 PM
06/26/13 04:26 PM
astjp2
Utah and Alaska
Last one for now. The body lines are great but the spray was something to be desired...at lease she will be a driver...
[Re: astjp2]
#1389542
06/26/13 06:42 PM
06/26/13 06:42 PM
Posts: 21,520 N.E. OHIO, USA
A12
N.E. OHIO, USA
Some work from yesterday, boy that hemi barely clears!
Next time use one of these.........
[Re: astjp2]
#1389544
07/06/13 03:48 PM
07/06/13 03:48 PM
Posts: 1,805 ky hills
thehemikid
ky hills
Almost didn't make it!
Are those Dvorak stands & clamps?
[Re: thehemikid]
#1389545
07/08/13 02:45 AM
07/08/13 02:45 AM
astjp2
Utah and Alaska
Yes, I got them from Mike Chenoweth, I could not get the stock rocker ratio's in so I put in stageV rockers and Dechelles shafts for one expensive set of rockers...Tim
[Re: astjp2]
#1389546
05/30/14 01:43 AM
05/30/14 01:43 AM
astjp2
Utah and Alaska
Well I found a killer deal on some 304 stainless 1/2" tubing for the fuel lines, made by parker. 7.00 for a 20' stick. I think I may have to buy all they have just incase I need to remake them. I suck at bending tubing! Tim Once I have fuel lines installed, I will get a US radiators 4 core triple pass radiator and then do another break in run...Tim
