Heater Box Restoration #1389462
02/18/13 01:01 AM
02/18/13 01:01 AM
Russ H. Offline OP
Russ H.  Offline OP
I am re-doing my heater box with a DMT foam/seal kit. The outside fiberglass halves are a bit scratched up and dull looking. Is there a finish that can be applied to bring back the original appearance?
Thank you,
Russ
Re: Heater Box Restoration [Re: Russ H.] #1389463
02/18/13 01:32 AM
02/18/13 01:32 AM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
do a search, there is some spray that others have used, I just can't remember what it was. Tim
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: Heater Box Restoration [Re: astjp2] #1389464
02/18/13 05:01 PM
02/18/13 05:01 PM
west kentucky
gomangoRTSE Offline
gomangoRTSE  Offline
west kentucky
There have been some excellent postings on this subject complete with pics and solid recommendations. I would also appreciate it if someone can repost. Tks
Re: Heater Box Restoration [Re: Russ H.] #1389465
02/18/13 05:33 PM
02/18/13 05:33 PM
North Carolina
cjskotni Offline
cjskotni  Offline
North Carolina
Thank you,
Russ
If you sand blast the case it will clean it up but leave it dulled. You then just spray coat it with Eastwood's Diamond Clear (or really any good clearcoat) and it comes out looking beautiful!
I did this to mine and it looks brand new.
Keep in mind, you will lose your original stampings if you care about that..
Re: Heater Box Restoration [Re: cjskotni] #1389466
02/22/13 12:30 AM
02/22/13 12:30 AM
Missouri
Big_E Offline
Big_E  Offline
Missouri
