Serpentine Belt shrinkage? #1389295
02/17/13 09:56 PM
02/17/13 09:56 PM
Sarcoxie, MO, USA
MoPar Jamie Offline OP
Sarcoxie, MO, USA
Hey all,
Been working all afternoon on my Ram Van. Thermostat decided to stick open and as I found out one side on the bottom had broken off. Explains the sudden-ness of it.
Anyway I had to take a lot off down to the main A/C bracket. I put everything back as it should and now the belt is too tight even without the tensioner in the equation.
The belt was on the ground under the van but may have had some sunlight.
Is it possible for the belt to physically shrink? I have the routing right as shown on the sticker on the shroud. I put it on the alt, idler, A/C, and PS pulleys and its aligned. But it only wraps halfway around the crank pulley. Tried to spin the crank but its not far enough to catch and stretch.
So, whats going on here?
This is the last thing other than the computer to go back on before I fill the system.
- MoPar Jamie
1972 Fury III 4dr
1986 D-150 LWB Royal SE
Re: Serpentine Belt shrinkage? [Re: MoPar Jamie] #1389296
02/17/13 10:10 PM
02/17/13 10:10 PM
Star Idaho
67vertman Offline
67vertman  Offline
Star Idaho
The belt won't shrink. You probably have it routed wrong, double check the diagram.
Re: Serpentine Belt shrinkage? [Re: MoPar Jamie] #1389297
02/17/13 10:25 PM
02/17/13 10:25 PM
Winnipeg, MB
sreinheimer Offline
sreinheimer  Offline
Winnipeg, MB
Dont try to put it on the crank last, try the alt last
69 Dodge Charger - first full resto 05 Dodge Magnum R/T
Re: Serpentine Belt shrinkage? [Re: MoPar Jamie] #1389298
02/17/13 10:49 PM
02/17/13 10:49 PM
Harm City Md.
Dan Halen Offline
Dan Halen  Offline
Harm City Md.
Belts will shrink with heat.
I had a Fox body Mustang that I put a new serpentine belt on. It
didn't carry the tension of the old belt so I ordered another...
same thing. I ran it on the car as it was the belt that was called
for. Fast forward 3wks, the smog pump locks up on the interstate. I
pull over due to the smell of burning belt and of course the noise,
I yank the pump and proceed to gut the vanes out of it on the side of
the road. I reinstall the pump, route the belt and wolla!...the
belt fits perfectly now. I never pulled the belt from any other
accessory, just the tensioner and the smog pump.
Re: Serpentine Belt shrinkage? [Re: Dan Halen] #1389299
02/18/13 12:05 AM
02/18/13 12:05 AM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
Ether you have the belt routed wrong or you haven't pulled the tensioner back far enough
Re: Serpentine Belt shrinkage? [Re: rowin4] #1389300
02/18/13 12:33 AM
02/18/13 12:33 AM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
alt or the tensioner should be last to put on..belt wont get smaller...just walk away for awhile and revisit it..
