well, doesn't makes any sense get the Key in ACC and not get ACC power LOL:
Take in mind the ACC position is one step backwards AND The first position forward mounted on column, really JUST unlocks the wheel
![](/ubbthreads/images/graemlins/wink.gif)
. second step sets in RUN... will turn on the BRAKE and OIL light ( if equiped ) on cluster
ACC position ( back ): continuity between red and black
RUN position: Continuity between Red and Blue and Red and Black
Start position: Continuity between Red and yellow, and red and Brown
This test with ballast unplugged
