CRAPPPPPPP! 2008 Ram Issues #1389073
02/17/13 02:48 PM
02/17/13 02:48 PM
Cambridge, Ontario, Canada
CUDAJAS Offline OP
CUDAJAS  Offline OP
We were out today...out of town of course, and my 2008 ram's ETC light started flashing and acting up (revs increasing / high idle). Shut it of and restarted it and it seems fine.
So, any thoguths on the issue?
A family member,(a chrysler mechaninc)told us not to drive it and get it checked first.
Jason
Re: CRAPPPPPPP! 2008 Ram Issues [Re: CUDAJAS] #1389074
02/17/13 03:29 PM
02/17/13 03:29 PM
The Tree Offline
The Tree  Offline
I would recommend checking out a RAM Forum and/or RAM complaint forum.
Here's some examples:
http://www.dodgeproblems.com/
2008 specifically -
http://www.edmunds.com/dodge/ram-pickup-1500/2008/consumer-reviews.html
http://www.carcomplaints.com/Dodge/Ram_1500/2008/
That will keep you busy for a while...
Randy
Re: CRAPPPPPPP! 2008 Ram Issues [Re: CUDAJAS] #1389075
02/17/13 04:07 PM
02/17/13 04:07 PM
Northeast
V
VincentVega Offline
VincentVega  Offline
V
Northeast
should be under powertrain warranty. take it right to the dealer.
Looking for 1975 through 1978 B body 4 door sedan sheet metal or parts cars - monaco, fury, coronet. Please let me know
Re: CRAPPPPPPP! 2008 Ram Issues [Re: VincentVega] #1389076
02/17/13 07:23 PM
02/17/13 07:23 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Yea thats the Electronic Throttle Control. First thing to do is have it scanned to see if it set a code and go from there. It controlls the idle speed and the throttle to wide open. When you are pressing the gas you are just moving a sensor that tells the PCM how much gas you want to give it and then the electronic throttle control works it electric motor to put the throttle in the posistion you want. Most will go to a limp in when it has a problem which usually it just runs it at a high idle around 1500 rpm from what I remember. But it may have set a code to help diagnose it. Ron
Re: CRAPPPPPPP! 2008 Ram Issues [Re: 383man] #1389077
02/18/13 09:54 AM
02/18/13 09:54 AM
Port Huron, Michigan
MI_Custumz Offline
MI_Custumz  Offline
I think if you turn the key to run, off, run, off, run within 5 seconds it will give you a code, if it generates a code for that problem.
