anybody brake a ujoint and have this problem ??
#138866
10/19/08 08:44 PM
10/19/08 08:44 PM
Posts: 123 long beach,ny
10sec340
long beach,ny
Installed the new 489 unit and the ujoints were different so I bought the conversion one plus new strps and bolt (hardened) Well first blast down the highway hard and Bam broke the 4 bolts clean in the yoke !! Okay all that is no biggie to fix, but......... The drive shaft must have been kicking around real hard and now is stuck in the tranny !!! Tried everything to pull it out,Must have crossed up some splines..... Anybody get one stuck and GET it out ?? Most likely the tail shaft is a gonner !
Tim
real 383 car now 440..
Re: anybody brake a ujoint and have this problem ??
[Re: 10sec340]
#138870
10/19/08 10:46 PM
10/19/08 10:46 PM
thats the sort of story that legends are made from
[Re: 10sec340]
#138871
10/20/08 07:55 AM
10/20/08 07:55 AM
Posts: 1,051 Slidell, La.
doctor_mopar
Slidell, La.
I had a yoke stuck in a 4 speed when a tailshaft bushing went out in the desert, and I drove untill the mainshaft warped ( but I made it to civilazation) . I had to cut off the end of the yoke with the joint in it. I removed the tailshaft housing over the yoke. Then i split the yoke lengthwise and removed it in halves. this was all to no avail, since I then found the mainshaft warped. I wonder if your mainshaft could have bent. this would explain why the yoke will not side out ! Also, don't use the bolts that come in the aftermarket u joint kits, as they do have a knack for breaking. Use the OEM ones. Also did you have the two clips on the u joint caps to keep them square in the yoke ?
------------------------ It doesn't matter what you do.........As long as you look good doing it !
[Re: doctor_mopar]
#138872
10/20/08 09:12 AM
10/20/08 09:12 AM
Posts: 3,449 Gateway to the West.
hemi_harvester
You might have even bigger problems, Check the bellhousing I had the same thing happen once and it broke the trans off the engine! Better check around your bellhousing and starter for cracks. It is also possiable to damage your engine from the vibrations.
There comes a time in life, when you walk away from all the drama & people who create it. You surround yourself with people who make you laugh, forget the bad, and focus on the good.
[Re: Mr.Yuck]
#138874
10/20/08 10:24 PM
10/20/08 10:24 PM
10sec340
long beach,ny
not even going to chance it,plus wanted a better trans anyway, JW trans is getting a call this week.
Yes the clips were in,after checking looks like the ujoint craked down the middle,could be from swinging around but would explain why if so...
[Re: cupcake]
#138876
10/20/08 10:59 PM
10/20/08 10:59 PM
Posts: 155 calif
cupcake
calif
[Re: 10sec340]
#138877
10/21/08 11:39 AM
10/21/08 11:39 AM
doctor_mopar
Slidell, La.
You have to be careful how you orientate a U joint on installation. If the joint has a grease zirk location in the cross, you need to install the joint so the zirk is under compression when the driveshaft is putting the twist to the yoke to turn it. If it is installed in the wrong position, it will tend to split the U joint in half.
[Re: Paul_Fancsali]
#138881
10/23/08 11:51 AM
10/23/08 11:51 AM
10sec340
long beach,ny
Since the drive shart is bent I'm going 1350 on pinion and trans yokes and drive shart ! No more of these problems, Now only have to do the trans over !!
