Re: moparts engine builder, help settle a bet [Re: Crizila] #1388355
02/17/13 12:02 AM
02/17/13 12:02 AM
Desert Tracker
HYPER8oSoNic Offline
Desert Tracker
Hey, you are supposed to guess with the info supplied. Thats why it's called a guess. Any more guesses after my guess based on additional info supplied by the OP DON'T COUNT!!!
MOMMMMEEE!!! My..answer..WAAAHH!! AAAh!!..IT'S NOT RIGHT!!!
classic!!
"Stupidity is Ignorance on Steroids"
"Yeah, it's hopped to over 160" (quote by Kowalski in the movie Vanishing Point 1970 - Cupid Productions)
Re: moparts engine builder, help settle a bet [Re: HYPER8oSoNic] #1388356
02/17/13 12:27 AM
02/17/13 12:27 AM
MR_P_BODY Offline
MR_P_BODY  Offline
What fuel? With open chamber x heads and 10:1 compression...... Uhhhhmmmm 375-400.
Didn't say what fuel, so I going with pump gas premium w/ octane booster to be sure. Fiddle with the cam intake and lobe center angles (degree cam), optimize ignition timing to the combo and make sure the EFFECTIVE cr IS 10 to 1, otherwise with the "advertised" cr level at 10 to 1, you are looking at 50-70hp less (maybe more!) than with EFFECTIVE cr.
I'm sure he is talking the static compression... not
the dynamic ...... JMO
