Re: ZDDP oil analysis results
[Re: 1968RR]
#1388089
08/07/13 05:06 PM
08/07/13 05:06 PM
Posts: 1,285 Pacific NW USA
CompSyn
Pacific NW USA
The American Society for Testing and Materials (ASTM) sets the industry standardized test methods for determining among other things additive elements, wear metals, and contaminates in lubricating oils. In this case, the ASTM D5185 otherwise known as Inductively Coupled Plasma Atomic Emission Spectrometry (ICP-AES) is where zinc and phosphorous content is commonly tested and reported by the industry. To read the ASTM test methodology for (ICP-AES), click on the ASTM D5185 link – HERE
[Re: 1968RR]
#1388090
08/07/13 05:22 PM
08/07/13 05:22 PM
CompSyn
Pacific NW USA
Brad Penn: 1600-1700 ppm
Brad Penn utilizes the ASTM qualified lab, Southwest Research Institute (SwRI), for additive element testing and reporting. There again, SwRI uses the industry standardized test method, ASTM D5185 (ICP), to determine zinc content of lubricant oils.
As such, Penn Grade 1 oils have between 1540-to-1565 ppm zinc content.
For more, click on Brad Penn’s link - HERE
For more on Southwest Research Institute (SwRI), click on the link - HERE
[Re: 1968RR]
#1388091
08/07/13 05:36 PM
08/07/13 05:36 PM
CompSyn
Pacific NW USA
Rotella T: 1200-1300 ppm
The independent watchdog group, Petroleum Quality Institute of America (PQIA), provides information to consumers regarding lubricant quality. As such, PQIA purchases various lubricants at random and sends blind samples to Southwest Research Institute (SwRI) for testing, there again, utilizing the industry standardized test method, ASTM D5185 (ICP).
Here is what PQIA recently reported for Shell Rotella T Triple Protection, SAE 15W-40, API CJ-4/SM.
Phosphorus 965ppm Zinc 1098ppm
For more, click on this link - HERE
[Re: 1968RR]
#1388092
08/07/13 05:44 PM
08/07/13 05:44 PM
CompSyn
Pacific NW USA
Royal Purple: 800-900ppm
Here is what Petroleum Quality Institute of America (PQIA) recently reported for:
Royal Purple Synthetic Oil 5W-30 API SN ILSAC GF-5.
Phosphorus 706ppm Zinc 837ppm
- AND -
Royal Purple, API SL, SAE 10W-30.
Phosphorus 808ppm Zinc 876ppm
[Re: Pacnorthcuda]
#1388093
08/07/13 06:06 PM
08/07/13 06:06 PM
CompSyn
Pacific NW USA
Junky, you raise good points, but keep in mind...DELO oils were not engineered for our flat tapped gasoline V8s. Ive spoken directly with several Chevron engineers (I've purchased over a million gallons of DELO 15w40 over the years) who tell me the zinc in their oil is for the punishment that the small end of the rod endures during the uber high compression of a diesel. The detergent is there to keep soot in suspension.
Gasoline engines have different requirements. Yes, DELO oils ARE good, but for our use, I believe there are better answers.
BTW, did you know Chevron DELO is a synthetic blend (at least technically--thank you Castrol)? It just hasn't been marketed that way. It's about to though---DELO XLE ( as opposed to LE) is just about to hit the streets.
Here is what Petroleum Quality Institute of America (PQIA) recently reported for: Chevron Delo® 400LE SAE 15W-40, API CJ-4/CI-4 Plus/SM.
Phosphorus 1312ppm Zinc 1490ppm
What Chevron engineers? Who did you talk to?
This is what Chevron says right in their Product Data Sheet:
APPLICATIONS
Delo 400 LE SAE 15W-40 is a mixed fleet motor oil recommended for naturally aspirated and turbocharged four-stroke diesel engines and four-stroke gasoline engines in which the API CJ-4 service category and SAE 15W-40 viscosity grade are recommended. It is formulated for engines operating under severe service and a wide range of climatic conditions.
- AND -
Delo 400 LE SAE 15W-40 is approved for: API Service Categories CJ-4, CI-4 PLUS, CI-4, CH-4, SM, SL
Seriously folks, Chevron Delo 400 LE is enginered for "mixed fleet" diesel and gasoline applications, see also API (SM) and (SL). Let's let the diesel detergent myths stop here. It's a Heavy Duty Engine Oil (HDEO) for heavy duty applications.
For more, Chevron DELO 400 LE SAE 15W-40 Product Data Sheet at this link - HERE
[Re: dogdays]
#1388094
08/07/13 10:02 PM
08/07/13 10:02 PM
Posts: 441 Uranus
strokerchall
Uranus
Joe Gibbs is another company that says the ultra-high detergent levels in Diesel oils harm the effectiveness of the ZDDP.
R.
i was told this by a guy at NAPA when I bought JOE GIBBS ,my first choice was VR-1 racing oil but he talkled me out of it after i asked if i could ad zinc
[Re: CompSyn]
#1388096
08/07/13 10:25 PM
08/07/13 10:25 PM
Posts: 21,822 Kirkland, Washington
Pacnorthcuda
APPLICATIONS
- AND -
Comp: you DO know that DELO stands for "diesel engine lubricating oil" right? Well now you do. I said they ARE good oils, just very high in detergent for our applications. There are better choices.....ummmm I think you of all would agree with that.
[Re: Pacnorthcuda]
#1388097
08/07/13 11:22 PM
08/07/13 11:22 PM
CompSyn
Pacific NW USA
And now YOU know Chevron actually recommends DELO for API (SM) and (SL) rated gasoline engines. So now you can stop spreading the tripe that it's not well suited for gasoline engines when it's engineered to work equally as well in both diesel and gasoline applications.
Old design carbureted V8s aren't the cleanest running engines as where more robust detergents can actually be a plus. But you're right, DELO is not my first choice in engine oil.
[Re: CompSyn]
#1388098
08/07/13 11:33 PM
08/07/13 11:33 PM
Pacnorthcuda
[quotes. So now you can stop spreading the tripe that it's not well suited for gasoline engines when it's engineered to work equally as well in both diesel and gasoline applications. :
That is flat out wrong. DELO was NOT "engineered to work equally as we'll in both diesel and gasoline applications" it was engineered for diesel applications period. As stated, I've purchased over a million gallons over the last 12 years. PM me for more info. Chevron realized a lucrative secondary market after its introduction and the marketers took over. "Tripe". Give me a freekin break!
[Re: Pacnorthcuda]
#1388099
08/08/13 12:28 AM
08/08/13 12:28 AM
CompSyn
Pacific NW USA
Pac, lots of people use mixed-fleet Heavy Duty Engine Oil (HDEO) in their gasoline powered applications and report stellar Used Oil Analysis reports. Irregardless of what DELO "WAS" twelve years ago, today it's a mixed fleet HDEO and Chevron's Product Data Sheet reflects this. You've decided it's not the first choice for your Muscle Car, that's fine, but HDEO remains a safe, affordable and readily available option for many. Sorry I struck a nerve my friend.
[Re: Yellow Fever]
#1388102
08/08/13 09:13 AM
08/08/13 09:13 AM
Posts: 247 DuPont, Washington
DZJim
DuPont, Washington
I bought the 10 pack of the ZDDPLUS off Ebay and I found this:
http://www.zddplus.com/imgs/ZDDPlusTestResults2.pdf
I'll use that and keep using Rotella.
Looks like the "test report" has been "embellished" a little. Chemist would not take it upon himself to comment upon "...optimum range for high-performance flat tappet engines..." Whole thing strikes me as ad hype...
[Re: strokerchall]
#1388104
08/08/13 11:34 AM
08/08/13 11:34 AM
Posts: 9,436 Blair County,PA
62maxwgn
Blair County,PA
R.
I'm "assuming" Joe Gibb would rather have you buy his oil and I'll bet the guy at NAPA is related to GG,if he said it,it has to be correct !!
I'll stick to my Brad Penn!
[Re: CompSyn]
#1388105
08/08/13 01:15 PM
08/08/13 01:15 PM
Posts: 1,943 San Angelo, Texas, U.S.A.
1968RR
SWRI does good research and is a reputable institute, but ICP-AES simply isn't as accurate as NAA (it's only the "industry standard" because NAA typically requires access to a nuclear reactor). You will literally not find a single paper in a peer-reviewed scientific journal that claims that ICP-AES is a more sensitive method of trace element analysis than NAA.
"When I'm in a slump, I comfort myself by saying if I believe in dinosaurs, then somewhere, they must be believing in me. And if they believe in me, then I can believe in me." - Mookie Wilson
[Re: 1968RR]
#1388106
08/08/13 01:54 PM
08/08/13 01:54 PM
62maxwgn
Blair County,PA
And how minute would be the difference and would it really matter ?
