Re: sb mag belt sytem on a LA block [Re: GO_Fish] #1387872
02/19/13 11:27 PM
02/19/13 11:27 PM
Alton, IL
Dakota_Don Offline OP
Alton, IL
i can use the magnum p/s bracket on the LA right??
Re: sb mag belt sytem on a LA block [Re: BEINGmeISaCRIME] #1387873
02/20/13 09:41 AM
02/20/13 09:41 AM
Bama
BigDawg72 Offline
BigDawg72  Offline
Bama
The edelbrock intake will mount the magnum style thermostat and waterneck eliminating the problem with grinding on the ac compressor (Found this out after the fact).
So an Edelbrock RPM magnum version will clear the A/C? That's what I should have bought to begin with but I thought I could save a few bucks...
Re: sb mag belt sytem on a LA block [Re: Dakota_Don] #1387874
02/20/13 09:49 PM
02/20/13 09:49 PM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
Don't know, have not tried that. You may need some washers on certain bolts to fill the gap between the Magnum bracket and the boss on the LA head.
Scott B. "I'm a self-made man... I started with nothing, and I still have most of it!" 68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph 69 340 GTS stock 14.18@ 95.60 mph 01 5.9L Ram 1500 Quad Cab 4x4 01 3.5L 300M 16.23@ 86.97 mph
Re: sb mag belt sytem on a LA block [Re: GO_Fish] #1387875
02/20/13 09:51 PM
02/20/13 09:51 PM
Alton, IL
Alton, IL
humm so far i haven't go any straight answers if the whole set up will work with out any hitches..
