Re: 408 stroker whos crank is better scat or eagle?
[Re: drifter]
#1387755
02/14/13 10:56 PM
02/14/13 10:56 PM
Posts: 9,826 las vegas
70AARcuda
las vegas
Use a scat cast crank...there are pictures and post of broken/cracked eagle cast cranks.
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
[Re: drifter]
#1387758
02/14/13 11:26 PM
02/14/13 11:26 PM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
The Scat for sure. The Eagle steel cranks are absolutley fine,( as far as toughness) but different story on the cast stuff.
RIP Monte Smith
[Re: drifter]
#1387760
02/15/13 03:13 PM
02/15/13 03:13 PM
Posts: 3,719 Space Station #5
471Magnum
Space Station #5
Scat for sure if you're going cast. Have it checked before buying bearings though. Mine was pretty tight on the mains.
-Jim
I can fix it... my old man is a television repairman. He's got the ultimate set of tools... I can fix it.
Currently Mopar-less
[Re: Oyvind Mopar]
#1387762
02/15/13 07:43 PM
02/15/13 07:43 PM
Posts: 35 Minot, ND
darndart
Minot, ND
73 Dart Sport 340, 410ci, Indy 360-2 230CNC. 72 Demon 340 4-speed 01 Ram Quad Cab 89 Mustang LX Boss 331,C4,HP76mm turbo, FAST EFI 86 Mustang GT 5.0 AOD 82 Capri RS 306, Fox Lake Stage 1 TW, N41, T5,etc.
