Page 2 of 3 1 2 3
Re: 12V.... 16V... 18V.... 24V [Re: Crizila] #1387391
02/15/13 04:46 PM
02/15/13 04:46 PM
Sweet Home Alabama
MRMOPAR622 Offline
MRMOPAR622  Offline
Sweet Home Alabama
Well still happy with my boring plain old 16V XS Power batteries...They work great for me but maybe I need more compression.
I think might have more to do with cu. in. than the CR!
"To Be The Man'You Have Got To Beat The Man" "T/D and Pro-Bracket Racer"
Re: 12V.... 16V... 18V.... 24V [Re: MRMOPAR622] #1387392
02/15/13 08:13 PM
02/15/13 08:13 PM
Sweet Home Alabama
MRMOPAR622 Offline
MRMOPAR622  Offline
Sweet Home Alabama
Here is something that might be of interest.The women that lives next door forgot to turn her parking lights off this morning and run her battery down to low to crank her SUV,to make a long story short & get to the point I pulled her battery out to put a charge on it and preform a test I put it in my red dragster.The 12 volt battery would turn the engine about a 1/2-3/4 round at a time,but when I turned on the electric fan & water pump & tail light the fan & pump sounded like they were running at 1/2 speed or less and the tail light was a little dim.With the 16 volt that is to weak to even turn the engine at all it will run both the water pump & fan at full speed(as far as I can tell from the sound) & the tail light is bright.
Re: 12V.... 16V... 18V.... 24V [Re: MRMOPAR622] #1387393
02/15/13 08:43 PM
02/15/13 08:43 PM
The Swamp
MegaDart Offline
MegaDart  Offline
The Swamp
if it's 15:1cr then I would expect it's a race only setup. 16volt all the way.
If it's street car or only raced occasionally then 12volt.
Don't make it harder than it is...
Re: 12V.... 16V... 18V.... 24V [Re: MegaDart] #1387394
02/15/13 08:50 PM
02/15/13 08:50 PM
Arizona
Chris'sBarracuda Offline
Arizona
This is waaaaaay over complicated..
Chris..
Re: 12V.... 16V... 18V.... 24V [Re: Chris'sBarracuda] #1387395
02/15/13 09:45 PM
02/15/13 09:45 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
UNLAWFUL RACE & ENGINE TECH
I ran an alternater up until 2005. The bearing locked up breaking the belt at 8,000 and took out the water pump wiring during the burn out. The motor had catastrophic failure late in the pass due to overheating. I did not buy another alternator because I ran a 16Volt system and did not need to. The car would have been more overweight with one.
I am planning on installing an alternator as I plan on doing lengthy street drives this year. Not class racing with a low minimum weight so it should not hurt anything.
I don't understand why this thread turned into a debate on whether or not to run an alternator.
Leon
Re: 12V.... 16V... 18V.... 24V [Re: Leon441] #1387396
02/15/13 09:50 PM
02/15/13 09:50 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
Heck its Winter time. We could be talking about "how to paint my Mopar with a paint roller"
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: 12V.... 16V... 18V.... 24V [Re: pittsburghracer] #1387397
02/15/13 10:15 PM
02/15/13 10:15 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Isnt that the truth ... but I still use a spray gun
Re: 12V.... 16V... 18V.... 24V [Re: MR_P_BODY] #1387398
02/15/13 10:31 PM
02/15/13 10:31 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Wagner power painter??
While I can see Don's electronic wizardry kicking in OD... I'd still be thinking of the basics... Do I want to carry two batts in my race car?? Answer for me has been a resounding NO. I have one 12v batt on the car. I have the water pump and fan wired into a four pole plug that I hook up to a separate battery when I hit the pit area for cool down. I also have two good batteries in my tow vehicle which if the need arises, they are ready to go. I do run an alternator, and the wiring for the waterpump getting damaged by an flinging belt is astronomincal (anything can happen!).
....while I do my burnout with the water pump and fan on, I shut both of them down on my final stage and trip the waterpump as soon as I cross the stripe.... it's served me well and to date i've never had any reprocussions. Basically I'm only powering the fuel pump and ignition on a pass.
Re: 12V.... 16V... 18V.... 24V [Re: J_BODY] #1387399
02/16/13 05:29 AM
02/16/13 05:29 AM
Sunnyvale, CA
Jeepmon Offline OP
Jeepmon  Offline OP
Sunnyvale, CA
J-body... The only problem I was having was cranking the motor over.. if it wasnt done just right, we'd get kickback and aweful screeching/grinding sound.. even with two 12V batteries... fully charged and hooked together..
My first thought was to convert to the 16V system, but I dont have the pocketbook the other members of the B1-aires Boys club have.. so I had to get a little creative..
Re: 12V.... 16V... 18V.... 24V [Re: Jeepmon] #1387400
02/16/13 12:00 PM
02/16/13 12:00 PM
Sweet Home Alabama
MRMOPAR622 Offline
MRMOPAR622  Offline
Sweet Home Alabama
I'm like the others know very little about the batteries,but trying to learn.But a $269.00 16 volt Rock battery will solve your kick back problems on start up.Since going to 16 volts have not had that happen or broke any starters or flywheels,Hmmm that might answer my question on 16 volts vs 12 volts!Most of us can tell anyone what heads,cam,carb,crank,ect-ect,but we don't know Sh*t about batteries.
PS after we get straight on the Batteries,we can always start another post on alternators vs no alternators test session!
Re: 12V.... 16V... 18V.... 24V [Re: MRMOPAR622] #1387401
02/16/13 01:15 PM
02/16/13 01:15 PM
Sunnyvale, CA
Jeepmon Offline OP
Jeepmon  Offline OP
Sunnyvale, CA
Its $269 for the battery.. $200 for the alternator and another $250-ish for the battery charger..
It all boils down to this.. if you have a large CID, high compression motor and only 1 battery.. then a 16V system might be what you need..
But if you run a two battery system, there are simple and cheap alternatives..
Re: 12V.... 16V... 18V.... 24V [Re: Leon441] #1387402
02/16/13 01:40 PM
02/16/13 01:40 PM
gregsdart Offline
gregsdart  Offline
This is for guys wanting to run a 12v system, with no alternater or a constant discharge situation.
This info comes from a chart showing lead acid battery voltage versus draw.
We want to figure the running voltage at two points, WOT at the top end of the run, (highest load during run) and warm cranking voltage when battery is 50 percent discharged, to see whether the ignition will still work and get the car running for the pass.
To calculate the percent of draw in amp hr rating, an example is a 10 amp continuous draw on a 100 amp/hr battery is 10 percent, or stated as c/10. A 5 percent draw would be 5amps on a 100 amp hour battery, etc. Amp/hr rating divided by draw equals c/xx, and then you can check the chart for running voltage. For our purposes, a running voltage at 50 percent discharge on a twelve volt battery is about what I figure is about as low as we can go to figure our capacity for number of runs we can make with a given load and still get back to the pits. Below 50 percent charge, voltage starts to drop much faster.
At 5 percent draw under load the running voltage is 12.3
10 percent, rv is 12.0
20 percent rv is 11.55
33 percent rv is 11.20
You can see how the voltage drops off during running as the load increases, so battery size is very important. I figure I had better not pick a battery with less than 10 times my draw at WOT, which is a water pump and MSD digital seven ignition plus the Deadenbear box. So I need to figure two things, how many passes before the battery will be at or less than 50 percent charge on the return road, and how much battery I need to stay below a 10 percent draw during a run. I will update with the draw of my stuff.
battery chart
http://www.scubaengineer.com/documents/lead_acid_battery_charging_graphs.pdf
Re: 12V.... 16V... 18V.... 24V [Re: gregsdart] #1387403
02/16/13 01:48 PM
02/16/13 01:48 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
So what does two GOOD 12V batteries, a 12V charger and 12V alternator cost?? You point out the total to switch to 16V ignoring the original cost of the 12V stuff. I dont think that is a fair comparison as SOMEONE Paid for the 12V stuff. It's an "upgrade" like anything else on a racear. Do you need 15-1 compression and B1 heads or could you have a racecar with 906 heads and 10-1 compression. Could you have a raceaar with a stock block or do you NEED a World block? IMO you need to make a fair comparison like anything else on a racecar.
Oh yeah K.I.S.S
Re: 12V.... 16V... 18V.... 24V [Re: Jeepmon] #1387404
02/16/13 01:52 PM
02/16/13 01:52 PM
New York
polyspheric Offline
polyspheric  Offline
New York
Mercedes "Dynastart" system used a pair of batteries in series for starting and in parallel when running and charging... 75 years ago.
Boffin Emeritus
Re: 12V.... 16V... 18V.... 24V [Re: gregsdart] #1387405
02/16/13 02:02 PM
02/16/13 02:02 PM
gregsdart Offline
gregsdart  Offline
battery chart
My amperage draw during a run=
MSD 7 7.5 amps
water pump 7.0amps
delay box 1.0 amps
Total constant running amps = 15.5 amps
Momentary draw during staging
transbrake 20 amps?
Re: 12V.... 16V... 18V.... 24V [Re: gregsdart] #1387406
02/16/13 02:24 PM
02/16/13 02:24 PM
PA.
"Little"John
"Little"John
PA.
battery chart
MSD 7 7.5 amps
water pump 7.0amps
delay box 1.0 amps
transbrake 20 amps?
No electric fuel pump or cooling fan?
I forgot about the alcohol.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: 12V.... 16V... 18V.... 24V [Re: Al_Alguire] #1387407
02/16/13 02:52 PM
02/16/13 02:52 PM
Sunnyvale, CA
Jeepmon Offline OP
Jeepmon  Offline OP
Sunnyvale, CA
Oh yeah K.I.S.S
Yeah, you make a good point, as I forgot about the initial costs.. but to answer your question.. about half (if not a little less) than the cost of the 16V equipment..
Re: 12V.... 16V... 18V.... 24V [Re: pittsburghracer] #1387408
02/16/13 05:15 PM
02/16/13 05:15 PM
gregsdart Offline
gregsdart  Offline
The injection and alky let me run without the fan or an electric fuel pump, both which would kick the draw way up. The fan alone doubles the steady draw on the battery. Maybe I should look into a magneto! (kidding)
Re: 12V.... 16V... 18V.... 24V [Re: gregsdart] #1387409
02/16/13 06:56 PM
02/16/13 06:56 PM
communist bloc of new jersey
jamesc Offline
jamesc  Offline
most of the decent sized electric fans are around 13-15 amps, trans brake solenoids are normally 14-15ish (for a transmission specialties type), electric water pumps around 7-8.
i will say that the magnafuel prostar 500 on ricks car is a cement mixer and pulls the most current of any fuel pump i've tested, around 15 amps. the meziere radiator mounted water pump also pulled quite a bit at around 13-14 amps iirc. this car has a 16 volt battery and alternator. all loads were checked with a Fluke i30 hall effect current clamp and Fluke 87v DMM. i haven't checked the MSD digital 7 plus yet and have suspicions about checking ignition draws unless the engine is under a load. i can trigger ignitions to 10k+ RPM but without being loaded i suspect the current draws might be less than when loaded. FWIW the multispark ignitions i've tested all change to single spark around 3000 RPM
Re: 12V.... 16V... 18V.... 24V [Re: jamesc] #1387410
02/17/13 12:05 AM
02/17/13 12:05 AM
gregsdart Offline
gregsdart  Offline
MSD web sight said 1.1 amps per 1,000rpm.
Page 2 of 3 1 2 3
