tire wear question #138737
10/19/08 04:14 PM
10/19/08 04:14 PM
NC USA
71mopardude Offline OP
I don't get it?
I don't get it?
NC USA
my wife hit a deer a couple months ago with her 2000 dodge grand caravan now the drivers side tire has wore out on the inside ( never wore the tires out in anyway b4 the deer) what should i replace the ball joint or the upper strut mount and bearing ??? or any other sugestions?? Thanks
Re: tire wear question [Re: 71mopardude] #138738
10/19/08 04:33 PM
10/19/08 04:33 PM
Kirkland, Washington
Pacnorthcuda Offline
You might just take it in for an alignment. The impact may have just knocked the adjustment out. A good shop will inspect the condition of the ball joints at the same time so you should get information about that at the same time.
Re: tire wear question [Re: Pacnorthcuda] #138739
10/19/08 05:26 PM
10/19/08 05:26 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
The shop will tell you if anything is bent.
