Page 2 of 3 1 2 3
Re: 440 stroke in a 383. Good idea? Post your combo/opinion [Re: Winchester 73] #1387245
02/14/13 07:07 PM
02/14/13 07:07 PM
ill
dennismopar73 Offline
ill
You can do line bore, that is an option, but for the strengh you normaly will cut the crank!
My 440 crank cost me $100 bucks for the 10 / 10 and another $100 to turn down the counters,
rods resized and new bolts $125 bought new OLD set of venolias 60 over, off ebay for $60 bucks they where brand new just never used!!
the 440 steel crank was laying around so made use of it,
so my rotator I'm in cheap!!
have set of O T B Eddy R P M s , Racer Brown stx 21 Running 10.40s
Re: 440 stroke in a 383. Good idea? Post your combo/opinion [Re: dennismopar73] #1387246
02/14/13 07:24 PM
02/14/13 07:24 PM
Washington State, USA
W
Winchester 73 Offline
W
that stroker sounds cheaper than my 383
Re: 440 stroke in a 383. Good idea? Post your combo/opinion [Re: dennismopar73] #1387247
02/14/13 07:39 PM
02/14/13 07:39 PM
PA
Belvedere500ci Offline OP
PA
dennismopar73,
What are you using for a cam? Flat tappet or Roller? What are your 60 foots? 4
link, Ladder bar car?
1967 Plymouth Belvedere II 383
1968 Plymouth Barracuda 383
2005 Ram 3500 5.9Diesel
1979 Dodge Power Wagon 360
Re: 440 stroke in a 383. Good idea? Post your combo/opinion [Re: Winchester 73] #1387248
02/14/13 07:44 PM
02/14/13 07:44 PM
ill
ill
well it is pretty cheap!!
But Im intot he crank right bought couple 440 that had steel cranks in them which I still have 1 ,
getting them turned is $100 here, and that guy i know will turn down counter s for $100 ,, so, even if you get a crank for say $125 get the rest done cheap your into it cheap, I just reused my rods had them resized and ARPs bolts put in good to go, never bush the rods, because there is no HP there!! and I think it makes them weaker in the stock form,
bore n hone is $125 , boil install freeze plugs another $80
I paid extra for the decking and line hone ,
I have more $ in my heads than I do the whole motor!!
Re: 440 stroke in a 383. Good idea? Post your combo/opinion [Re: dogdays] #1387249
02/15/13 11:47 AM
02/15/13 11:47 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
Mancini Overstock again, 4.15" stroke 383 main Eagle 4340 crank $500. Yeah, it's 10 under on both rods and mains, but so what?
http://chucker54.stores.yahoo.net/384st6bo10ea.html
R.
The problem with that crank is there isn't a rod available to use the common 1.32 shelf stock piston , rod needs to be roughly 6.580. the 4.15 crqank is ok for an RB build but low deck builds the 4.25 crank is a better choice.
Re: 440 stroke in a 383. Good idea? Post your combo/opinion [Re: Winchester 73] #1387250
02/15/13 11:49 AM
02/15/13 11:49 AM
JohnRR Offline
JohnRR  Offline
so nobody line bores?i thaught there was some debate as to it being better than grinding the crank?
anyone using a cast crank?
You can do that with a 400 block , but a 383 has thinner main webbing and it's not a good idea. 440Jim line bored his 400 block out to RB main size for a stronger crank, better main bearing selection and better crank selection at the time he did it .
Re: 440 stroke in a 383. Good idea? Post your combo/opinion [Re: JohnRR] #1387251
02/15/13 12:56 PM
02/15/13 12:56 PM
dogdays Offline
dogdays  Offline
Well, JRR, yer right, save money on that crank and you'll spend it on rods or pistons. Bummer!
Regarding block and crank relative strengths, it seems to me that the stock blocks are failing before the cranks get into trouble. So it seems counterproductive to weaken a block that's already the weak link, in order to protect a crank that, even turned down, is the stronger link.
R.
Re: 440 stroke in a 383. Good idea? Post your combo/opinion [Re: dogdays] #1387252
02/15/13 01:10 PM
02/15/13 01:10 PM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
R.
I agree with this concept. The block obviously gets weaker when you bore the mainline, as the bearing saddle gets closer to the thinner parts of the main webbing. You'd have to show me how a crank gets weaker by cutting the main journals down, though. I could be wrong, but typically a smaller diameter of the same material is going to be stronger than a larger diameter.
In any case, I would suggest that the most cost effective way to build a stout rotating assembly is going to be to find a good forged RB crank and make the modifications there. Add a good set of newer H-beam rods with ARP capscrews (I'm not a fan of using 40 year old stock rods in a performance build), and a set of forged slugs. Makes for a pretty stout rotating assembly at a very reasonable pricetag.
Re: 440 stroke in a 383. Good idea? Post your combo/opinion [Re: StealthWedge67] #1387253
02/15/13 01:25 PM
02/15/13 01:25 PM
dogdays Offline
dogdays  Offline
A smaller diameter is weaker both in bending and torsion, no way around that. And it's not a direct proportion but something like the ratio cubed.
One can use a stronger material but because steel has a relatively constant spring rate (modulus of elasticity) that only means it won't break as easily, it'll still deflect the same amount regardless of the alloy.
If crankshaft strength were an issue it'd be worth considering. However, the crank, even with smaller journals, seems to be stronger than it needs to be.
R.
Re: 440 stroke in a 383. Good idea? Post your combo/opinion [Re: dogdays] #1387254
02/15/13 01:42 PM
02/15/13 01:42 PM
PA
PA
None this answer my questions. Its going off in a totally different direction. My 383 is all ready, that's the block I'm building. I'm either going to put it back stock stroke or 440 stroke. Who out there has a 431-438?
Re: 440 stroke in a 383. Good idea? Post your combo/opinion [Re: Belvedere500ci] #1387255
02/15/13 01:47 PM
02/15/13 01:47 PM
JohnRR Offline
JohnRR  Offline
I was going to build one and changed my mind and went bigger , 3.9 stroke.
Re: 440 stroke in a 383. Good idea? Post your combo/opinion [Re: StealthWedge67] #1387256
02/15/13 01:50 PM
02/15/13 01:50 PM
JohnRR Offline
JohnRR  Offline
R.
Jim's reasoning was because of overlap of the journal diameters, the longer the stroke the less amount of material in the journals is one straight piece front to rear, kinda makes sense but I don't know what difference it makes structurally ?
Re: 440 stroke in a 383. Good idea? Post your combo/opinion [Re: JohnRR] #1387257
02/15/13 03:28 PM
02/15/13 03:28 PM
dogdays Offline
dogdays  Offline
To the OP, there must be a dozen of these engines on the board and they are significantly stouter feeling than a 383. Do it!
To whoever is worried about crank journal overlap, it has been a concern. It was a real concern for the OEMs especially using cast cranks. Thus you got the 2.81" main size on the 360 and the 2.65" main size on the chevy 400. HOWEVER, seeing that huge bigblockchevy engines are running stock 2.75" mains and 2.200" rod journals with 5.25" strokes and more, with zero journal overlap, it seems the 4340 cranks are strong enough so that doesn't matter as much.
R.
SO, OP, Do it! build that 3.75" stroke 383.
Re: 440 stroke in a 383. Good idea? Post your combo/opinion [Re: Belvedere500ci] #1387258
02/15/13 05:37 PM
02/15/13 05:37 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I believe Mopar Muscle did a 431 a few years back with Eddy RPM heads. I believe its the one they put in a 65 Dodge Coronet and ran 11.70's with it. Ron
Re: 440 stroke in a 383. Good idea? Post your combo/opinion [Re: 383man] #1387259
02/15/13 08:17 PM
02/15/13 08:17 PM
western iowa
Z
Z_Z Offline
Z_Z  Offline
Z
western iowa
I have a 431. Not a ton of racing times with it...last summer I was able to get a best 7.88 8th, 1.78 60ft, at 89mph. Put on a set of indy ez on, has a .570 Ultradyne 251@.050/278. There is alot of tuning to do yet. I run 4 speed and 4.10 dana. I have done nothing but find the weakest link since I put the ez's on it.
Re: 440 stroke in a 383. Good idea? Post your combo/opinion [Re: Belvedere500ci] #1387260
02/15/13 08:50 PM
02/15/13 08:50 PM
Puyallup, WA
Puyallup, WA
I'll say it again:
"The extra stroke will pay big dividends in trying to move a 4-door belvedere, which is a hefty sled to say the least. Bottom line, the 3.75 stroke build will stomp the same 3.38 stroke build every time! and the bigger the car your moving, the bigger the advantage gets"
Re: 440 stroke in a 383. Good idea? Post your combo/opinion [Re: Belvedere500ci] #1387261
02/15/13 09:32 PM
02/15/13 09:32 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Honestly, I've read your original post several times and have not responded because I really don't know what your question is.
"440 stroke in a 383. Good idea?".....Yes.
In the context of your question and the lack of any other information, any response will be of little value. Other than cost, I don't know what there is to evaluate. It's essentially comparing a 440 to a 383. Do you have some specific concern regarding the 431?
Re: 440 stroke in a 383. Good idea? Post your combo/opinion [Re: Belvedere500ci] #1387262
02/15/13 10:25 PM
02/15/13 10:25 PM
Wethersfield,CT
Ray440 Offline
Ray440  Offline
Wethersfield,CT
Here is a 383 stroker build up written by board member AndyF. Maybe this article will answer some of your questions.
http://www.moparmusclemagazine.com/techarticles/mopp_0605_mopar_performance_383_stroker_engine/
1969 Plymouth Road Runner 440 auto
2017 Ram 1500 Quad Cab 5.7 Hemi
Re: 440 stroke in a 383. Good idea? Post your combo/opinion [Re: BSB67] #1387263
02/15/13 11:12 PM
02/15/13 11:12 PM
Cab_Burge Online work
Cab_Burge  Online Work
The 383 bore with the 440 stroke is basically the same as a 426 wedge, correct? OP, go for it The longer stroke motors make more torque, torque is what moves the mass, HP Hence my suggestion on offset stroking the 440 crank to 3.91 or 3.90 stroke
Re: 440 stroke in a 383. Good idea? Post your combo/opinion [Re: Belvedere500ci] #1387264
02/16/13 02:20 AM
02/16/13 02:20 AM
ill
ill
Mine is a 437 love it !! go ahead and do the 440 crank in that 383
Page 2 of 3 1 2 3
