Re: Who would you use to pick/grind a cam? big block.
[Re: nd65]
#1386848
02/13/13 12:11 PM
02/13/13 12:11 PM
Posts: 7,274 s.w.fl
bonefish
s.w.fl
[Re: Dunnuck Racing]
#1386850
02/13/13 02:03 PM
02/13/13 02:03 PM
Posts: 2,530 Nunya CA
CR8CRSHR
Nunya CA
I spec my own based on what I have learned on my dyno and at the track. If you want to just make a call and order something Dave Hughes gave me the best grind for a recent shootout I wrote for Mopar Muscle . Keith
Hughes for me too.... ![](/ubbthreads/images/graemlins/Twocents.gif)
[Re: pettyblue440]
#1386854
02/13/13 04:59 PM
02/13/13 04:59 PM
Posts: 3,698 NE Oklahoma
Von
NE Oklahoma
1. Porter 2. Tim @ Bullet 3. Engle A little down the list FBO for a Racer Brown.. A long way down the list (Very near the bottom)...Hughes... No need to go past the first two... ![](/ubbthreads/images/graemlins/Twocents.gif)
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72.
Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
[Re: nd65]
#1386859
02/14/13 11:49 AM
02/14/13 11:49 AM
Posts: 9,892 Weddington, N.C.
Streetwize
Weddington, N.C.
383's are easy to overcam and in that respect they're more like smallblocks, it's not only the proper lift/duration and seperation angle but also the phasing (particularly the intake closing ABDC). You get the combo right and they ![](/ubbthreads/images/graemlins/drive.gif) but if you overcam (or understall/undergear) them and they just about won't fall out of a tree.
[Re: StealthWedge67]
#1386861
02/14/13 02:34 PM
02/14/13 02:34 PM
Posts: 3,916 usa
lewtot184
usa
Can't argue with any of the advice I see here. I run an Engle solid, and have been real happy with the customer service (I've called them a few times with questions) as well as the cam itself.
x2! ![](/ubbthreads/images/graemlins/drive.gif)
[Re: Streetwize]
#1386862
02/14/13 02:39 PM
02/14/13 02:39 PM
Posts: 3,916 usa
lewtot184
usa
been there, done that. you want to mess up a nice running 383? get a big hydraulic cam.
