Re: 727 internal swap?
[Re: Skeptic]
#1386319
02/12/13 08:18 PM
02/12/13 08:18 PM
Posts: 25,967 Rio Linda, CA
John_Kunkel
Rio Linda, CA
All of the guts from the '79 SB 727 will swap into the '72 BB 727 but it might not be a wise decision. The '72 BB will likely have heavier duty parts (planetaries, clutch count) than the '79 SB.
[Re: Skeptic]
#1386323
02/13/13 01:47 PM
02/13/13 01:47 PM
Posts: 75,092 A Banana Republic near you.
JohnRR
Thanks, John. I put in upgraded red clutches, 4.2 lever and a Cope valve body. This is a street car that will probably get to Willow Springs for the CPW meet. NO drag racing and no slicks, guess I'll take my chances, or put in new planetaries. I don't recall the # of pinions in them, but will soon enough.
Make sure you keep the front planetary with it's output shaft, the spline angle changed in either 75 or 76, and I'm not sure what differences there might be with the interface between the input shaft and the output shaft ...
