wiring a procomp billet distributor: 3 wires???? #1385647
02/11/13 05:08 PM
02/11/13 05:08 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
I have a Pro Comp 440 billet distributor like this one:
http://www.competitionracingsupply.com/i...27_procomp.html
It has 3 wires coming out. A red one, a black one and an orange one.
I am gonna wire it using an MSD 6AL ignition.
How should I wire the distributor??? Should I wire it like the schematics that MSD suggests for a Mallory UNilite or 9000 series? Red wire on the dist goes to ignition key, white wire out of the MSD to the orange wire on the distributor, and black wire coming out of the distributor to ground???
Re: wiring a procomp billet distributor: 3 wires???? [Re: domingo] #1385648
02/11/13 05:16 PM
02/11/13 05:16 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
Here is a schematic of the distributor I have.....
I wonder how should I wire this one with an MSD???
http://www.atracingworld.com/NEW-PC8027-CHRYSLER-440-PRO-BILLET-R2R-DISTRIBUTOR.html
Re: wiring a procomp billet distributor: 3 wires???? [Re: domingo] #1385649
02/11/13 06:26 PM
02/11/13 06:26 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
I'd call Procomp it's their distributor
Re: wiring a procomp billet distributor: 3 wires???? [Re: roadhazard] #1385650
02/11/13 06:45 PM
02/11/13 06:45 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
azlready called jegs tecvh line....they said to wire it like a mallory unilite.
Re: wiring a procomp billet distributor: 3 wires???? [Re: domingo] #1385651
02/11/13 06:46 PM
02/11/13 06:46 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
pro comp tech line is non existant, they dont even have downloadeable instructions sheet on theiur website....
Re: wiring a procomp billet distributor: 3 wires???? [Re: domingo] #1385652
02/11/13 06:54 PM
02/11/13 06:54 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
pro comp tech line is non existent, they don't even have downloadable instructions sheet on their website....
Maybe they are too busy copying other companies products to do that .
you didn't get one with it ?
Re: wiring a procomp billet distributor: 3 wires???? [Re: domingo] #1385653
02/11/13 06:57 PM
02/11/13 06:57 PM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
You can't use that one with an MSD ignition - it already has the ignition module built in - wire it just like the diagram. Pro-comp does make one with just the pick-up for MSD type ignitions (2-wire) - but based on my experience they are junk
Re: wiring a procomp billet distributor: 3 wires???? [Re: domingo] #1385654
02/11/13 06:59 PM
02/11/13 06:59 PM
Shelby mi.
JAKE68 Offline
JAKE68  Offline
Shelby mi.
Since you are going to use a out side box I would not run it using those wires. use only the two wires that go to the pickup that way you are bypassing using two ignition boxes. Then you are using the dist. for just the pick up.Or just use the the ignition that is built in it and not the msd. Oh by the way the wires are red 12switched black ground and orange tach lead.
JAKES AUTOMOTIVE
Re: wiring a procomp billet distributor: 3 wires???? [Re: DoubleD] #1385655
02/11/13 07:14 PM
02/11/13 07:14 PM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
RED - is positive 12v switched/key battery feed and (+) side of coil
BLACK - goes to chassis ground (-)
ORANGE - Negative (-) side of coil
Re: wiring a procomp billet distributor: 3 wires???? [Re: DoubleD] #1385656
02/11/13 08:19 PM
02/11/13 08:19 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
I am wiring it like this:
Re: wiring a procomp billet distributor: 3 wires???? [Re: JohnRR] #1385657
02/11/13 08:22 PM
02/11/13 08:22 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
Mopar Performance
Re: wiring a procomp billet distributor: 3 wires???? [Re: DoubleD] #1385658
02/11/13 08:25 PM
02/11/13 08:25 PM
MR_P_BODY Offline
MR_P_BODY  Offline
If you use it this way you cant use the MSD....
that dist has its own amplifier in it.... but you
could do like Jake said... just use the pick up portion
of it then use the MSD...... you really did buy the
wrong dist to use with the MSD
Re: wiring a procomp billet distributor: 3 wires???? [Re: MR_P_BODY] #1385659
02/11/13 08:29 PM
02/11/13 08:29 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
I bought it so long ago I dont remember,,,,,if I were to buy it today Id probably have gone with an MSD dist......oh well.....
Question is how do I wire just the pickup portion of it?????????????
Re: wiring a procomp billet distributor: 3 wires???? [Re: domingo] #1385660
02/11/13 08:40 PM
02/11/13 08:40 PM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
you will have to take it apart - and see if you can grab the two wires from the pick-up - not sure if you can - those things are real cheesy on the inside - post a pic if you can
Re: wiring a procomp billet distributor: 3 wires???? [Re: domingo] #1385661
02/11/13 08:54 PM
02/11/13 08:54 PM
MR_P_BODY Offline
MR_P_BODY  Offline
If the diameter is right I would look at putting in
a stock Mopar dist pick up and plate... might need to
machine the housing on a lathe
Re: wiring a procomp billet distributor: 3 wires???? [Re: MR_P_BODY] #1385662
02/11/13 08:59 PM
02/11/13 08:59 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
I was checking the MSD 6al diagrams and it says that you can hook up a ready to run dist to an MSD, and looks like it is just like the diagram I posted basically...
However there is a "NOTE" that says that the ignition modulke of the distributor will still trigger the MSD.
So it can be done, the question now is: is there a downside to that????
Re: wiring a procomp billet distributor: 3 wires???? [Re: domingo] #1385663
02/11/13 09:04 PM
02/11/13 09:04 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Wire it up that way and see... it might just give the
MSD a real strong signal (from the dist amplifier)
Re: wiring a procomp billet distributor: 3 wires???? [Re: MR_P_BODY] #1385664
02/11/13 09:09 PM
02/11/13 09:09 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
i called the tech line at summit and asked them, and they say that you can hook the ready to run dist to the msd. and that there is absolutely no downside to it.
Now, the thing isthat im actually hooking a PRO CRAP distributor to the msd, so who knows????
:S
DANG I DONT KNOW WHAT i WAS THINKING WHEN i BOUGHT THAT DIST LIKE 6 YEARS AGO OR MORE....
Re: wiring a procomp billet distributor: 3 wires???? [Re: domingo] #1385665
02/11/13 09:26 PM
02/11/13 09:26 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
I wrote to pro the pro comp tech line....
We'll see what they say....and we'll see if they reply!!!
Thanks for the help guys!
Re: wiring a procomp billet distributor: 3 wires???? [Re: domingo] #1385666
02/11/13 10:25 PM
02/11/13 10:25 PM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
Don't want to be the carrier of bad news...
But that ProComp distributor is low quality and poor reliability... Suggest you upgrade to a Mopar, MSD or Mallory..
Just my $0.02..
