rebuilt distributor #1385492
02/11/13 01:29 PM
02/11/13 01:29 PM
Omaha
road Offline OP
road  Offline OP
Omaha
How freely should the shaft spin after reassembling a distributor. 1973 electronic.
Re: rebuilt distributor [Re: road] #1385493
02/11/13 01:35 PM
02/11/13 01:35 PM
dogdays Offline
dogdays  Offline
An electronic distributor has no points and cam to slow its rotation, so it should be rotatable freely.
R.
Re: rebuilt distributor [Re: road] #1385494
02/11/13 01:43 PM
02/11/13 01:43 PM
If you adjusted the lower end play by adding shims above the plastic collar you'd want the axial play to be .005". www.speedwaymotors.com has a nice kit of 1/2" ID shims for that for cheap. As Dog said it should spin free/no binding
