Page 2 of 7 1 2 3 4 5 6 7
Re: out with old headers [Re: FastmOp] #1385202
02/14/13 12:33 AM
02/14/13 12:33 AM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
Your car is going to pick up big numbers
about 200HP guessing on the lite side.
Re: out with old headers [Re: Clanton] #1385203
02/14/13 01:19 AM
02/14/13 01:19 AM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
I would like the flange to be higher but I dont know if it would help the port flow better.
Re: out with old headers [Re: Clanton] #1385204
02/14/13 04:25 AM
02/14/13 04:25 AM
flip it over to see if that raises them If not don't hesitate to use a die grinder to open them up a little, AKA D port them a tiny bit
Re: out with old headers [Re: Cab_Burge] #1385205
02/14/13 11:05 AM
02/14/13 11:05 AM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
Ya the first thing I did was flip them.I was thinking moving the bolt hole down to raise the tubes.
edit:I use a scrap pipe to practice and it is not that hard to hammer form to a square so I will index the center top of the pipe and give it a try.
edit:here is how the pipes will go but the center pipe will loop over and down into the fender.
Re: out with old headers [Re: Clanton] #1385206
02/18/13 09:24 PM
02/18/13 09:24 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
I know this is not much but I did make a little progress.I have to get this together to figure the #7 for going over the steering column so they all lign up going through the fender.
Re: out with old headers [Re: Clanton] #1385207
02/18/13 09:27 PM
02/18/13 09:27 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
I need to stub the 3/5 pipe after the bend over #1 to loop it down into the fender.
Re: out with old headers [Re: Clanton] #1385208
02/19/13 03:00 PM
02/19/13 03:00 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Looks like you are moving along. Did you see my home made clamps I made to hold the tubes together so you can tack weld them. It's just some scrap aluminum and hose clamps but works great.
It gets real tight on the passenger side by the shock tower. That's where I had the most trouble.
Re: out with old headers [Re: FastmOp] #1385209
02/19/13 03:27 PM
02/19/13 03:27 PM
nc
E
earthmover Offline
earthmover  Offline
E
nc
whos kit is that????
Re: out with old headers [Re: earthmover] #1385210
02/19/13 05:35 PM
02/19/13 05:35 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
Thanks guys!The kit is a heddman but for a roadster,I got it just to get started.
Fastmop I will look at yours again for the clamp bands that will be helpfull at this point with checking the exit angle through the fender and past the wheel.I just opened up a hole for the pipes to come through.I see those clamps I have a couple small pieces of exh I was going to split and do the same thing.
Re: out with old headers [Re: Clanton] #1385211
02/19/13 05:50 PM
02/19/13 05:50 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
I am going to have to mock up 4 tubes in the collector to check things out better[exit angle,fit.]
Re: out with old headers [Re: Clanton] #1385212
02/19/13 06:05 PM
02/19/13 06:05 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
The tires on the ground and I turned the wheel all the way to check where the tire would be.I will have to add some room for suspension travel.
add on edit:
Re: out with old headers [Re: Clanton] #1385213
02/19/13 08:26 PM
02/19/13 08:26 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
this is the #1 pipe testing for length,angle of exit.
Re: out with old headers [Re: Clanton] #1385214
02/26/13 02:20 PM
02/26/13 02:20 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
I am thinking of vee banding the #7 header tube to make the headers removable to get past the brake MC and equal length.your thaughts?
Re: out with old headers [Re: Clanton] #1385215
02/28/13 01:09 AM
02/28/13 01:09 AM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
I think I made some progress in the puzzle.
Re: out with old headers [Re: Clanton] #1385216
02/28/13 07:07 AM
02/28/13 07:07 AM
sweden
1Fast340 Offline
1Fast340  Offline
sweden
equal lengths are not allimportant on a blown engine but if you are anyway taking the time,you might aswell go for it!
Vband joints are good when you need a split somewhere however fairly expensive,you could make the joint with flatflanges aswell or a sliptube or you could even if room and angles alow for it use flanges on a sliptube with a regual flatgasket the last version might be overkill but make for a superb seal at a much lower price than the vbands.
looks good this far
Re: out with old headers [Re: Clanton] #1385217
02/28/13 10:09 AM
02/28/13 10:09 AM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
Mike I think your cheating yourself on much needed room with the routing of the #1 tube.
If you brought it "up and over" the shock stud you wouldn't be so tight with tubes #3 & #5.
Not being critical just trying to lend an extra eye
Re: out with old headers [Re: 1Fast340] #1385218
02/28/13 11:07 AM
02/28/13 11:07 AM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
Thanks for the positive feedback guys!The options you listed are very helpfull for the #7 pipe and taking my time on my choices is just my way of learning in the process so I hope you will be patient.Greg the #1 pipe would actualy be longer I believe going over the shock but not by much and is an option but I figured I would try another way to be sure what I wanted to do. I may make the slip joint at the collector to help with taking it all out from time to time but I think that will be the last adjustment to the system that I do.I am going to work on the 5,7 pipe this wk now that I have run some pipe out the fender.
edit:here is a better pic of how they come togather.
Re: out with old headers [Re: Clanton] #1385219
02/28/13 07:16 PM
02/28/13 07:16 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
I am trying!
Re: out with old headers [Re: Clanton] #1385220
02/28/13 07:40 PM
02/28/13 07:40 PM
west palm beach, florida
modelmakerinc Offline
I am sure that is a miserable job, trying to fit all of that in such little space. hats off to you.
I dont know what the other specs are of your engine but it doesnt look like you will be able to remove the valve covers without removing the exhaust. That would really suck when you need to adjust the valves and I dont see how you will access the plugs either.
not trying to but I have considered building headers and never grown the cojones
Exceptional Architectural, Yacht and Automotive scale models. e-mail modelmakerinc@att.net for a portfolio review. www.modelmakerinc.com
Re: out with old headers [Re: modelmakerinc] #1385221
02/28/13 08:43 PM
02/28/13 08:43 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
I made sure I can remove the valve covers.That #5 pipe will be away from the covers more when done.
