Help me pick my rear tires #1385115
02/10/13 09:31 PM
02/10/13 09:31 PM
southern Idaho
moparcyco Offline OP
southern Idaho
I need help deciding what will look best for my 69 Bee.It currently rides on 15x10 weld pro stars with 295-65-15 drag radials.I like the way this looks.But i'm having a hard time finding a street tire that is close.What do you guys run?The new rims are wheel vintiques steelies 15x10 with 5.5 offset,this is the same as the welds The cars has +1 springs with the offset rubbing should not be an issue.Pictures of some combos would be great.How about the front also it has 15x6 thought 225-70-15s would look good.Here is what it looks like with the welds and bfgs.Want to get it right the first time thanks guys
Re: Help me pick my rear tires [Re: moparcyco] #1385116
02/10/13 09:39 PM
02/10/13 09:39 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
In that size I don't think anyone makes a true rock hard street radial. Just drag radials. I think the closest thing would be the mickey thompson sportsman sr radials, they are available in a variety of sizes. BFG sells their gforce drag radials in 325/50/15 which on a 10" rim is about 28" diameter and 13.25" width from sidewall to sidewall.
Re: Help me pick my rear tires [Re: moparcyco] #1385117
02/10/13 09:40 PM
02/10/13 09:40 PM
Kansas
BEINGmeISaCRIME Offline
Kansas
What about BFG Radial T/A 295/50/15? Same width but you may not like the slightly shorter tire. Hoosier makes some radial tires that have the height and width. On my 70 it has BFG 275/60/15 and they hold up real well.
Re: Help me pick my rear tires [Re: BEINGmeISaCRIME] #1385118
02/10/13 09:52 PM
02/10/13 09:52 PM
southern Idaho
southern Idaho
How much shorter? I think I would rather go slightly skinnier and keep the height.I think my options are few.Was hoping someone had a pic of a combo that looked good.
Is it ok to post pics of other members cars?If not please delete this picture.This is the look I'm after but don't know who's car this is
Re: Help me pick my rear tires [Re: moparcyco] #1385119
02/10/13 10:04 PM
02/10/13 10:04 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
These guys have some nice looking tires http://www.mandhtires.com/
Gus
64 Plymouth Savoy
Dana 60
Re: Help me pick my rear tires [Re: fourgearsavoy] #1385120
02/12/13 12:05 AM
02/12/13 12:05 AM
Northern NJ
68 Sat Offline
68 Sat  Offline
Northern NJ
try these 295/55/15 w 5 1/2 back spacing
1963 Chrysler 300 Pace Setter Convertible 21K mile survivor 1969 Dodge Coronet 500 1956 Desoto Hemi 1955 Chrysler C300
Re: Help me pick my rear tires [Re: 68 Sat] #1385121
02/12/13 01:45 AM
02/12/13 01:45 AM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
These are 275-60-17's on 5.5 b/s wheels. There is no more room. Mastercraft has a newer line out than the Avengers. Sadly these have been discontinued. These measure 11" at the sidewall and almost a full 30" tall. (29.98 spec) You do have to slide the rear back unless you want to trim the front of the 1/4 panel.
...FAFO...
Re: Help me pick my rear tires [Re: skicker] #1385122
02/12/13 02:13 AM
02/12/13 02:13 AM
southern Idaho
southern Idaho
I think I'm going to have to go 275-60-15 that looks good on your car.Coker has a 285-70-15 in a bfg but they want $250 a tire.I,m trying to go away from a drag radial,but keep the look I,m planning on 10 to 15 thousand miles a year if I can swing it.Just not much available in these sizes.
I bought the +1 espo springs right now without everything in the car the tops of the quarters sit way above the tops of the tires just don't want it to look stupid,and waste money.
Re: Help me pick my rear tires [Re: moparcyco] #1385123
02/12/13 11:32 PM
02/12/13 11:32 PM
Orleans, Ontario
moparcanuk Offline
moparcanuk  Offline
Orleans, Ontario
275/60R15 on my 69 GTX.
Re: Help me pick my rear tires [Re: moparcyco] #1385124
02/14/13 11:09 PM
02/14/13 11:09 PM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
I just remembered I also had to use a set of 1 1/2" lowering blocks to get the ride height back down. My car has super-stock springs on it because I knew it would have alot of weight due to the amps and subs being mounted in the trunk. Everything was about an extra 150# and looked fine with regular sized tires on it. When I put these on it looked like it had air shocks all the way up. The 1 1/2 blocks worked great, but you shouldn't need them staying with a 15" wheel.
...FAFO...
Re: Help me pick my rear tires [Re: skicker] #1385125
02/15/13 01:26 AM
02/15/13 01:26 AM
Dallas, Texas
bigcountry Offline
bigcountry  Offline
Dallas, Texas
How many miles can you expect to get out of a set of drag radials with regular street use w/o burnouts roughly?
Re: Help me pick my rear tires [Re: bigcountry] #1385126
02/15/13 03:50 AM
02/15/13 03:50 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Dont know but I have been driving on these Hoosier 30 x 9 radial slicks on the street for over 2 years and a few trips to the race track. I would say I have at least 2000 to 3000 miles on them and about 10 passes down the 1/4. They actually handle very good since I have radials up front. No one makes a drag radial in the 30 x 9 size so I just started driving on these slicks and was surprised how well they hold up on the street. Ron
Re: Help me pick my rear tires [Re: 383man] #1385127
02/15/13 11:59 AM
02/15/13 11:59 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
Whats the future hold for the Welds?
I am truckless..
Re: Help me pick my rear tires [Re: 340SHORTY] #1385128
02/15/13 12:37 PM
02/15/13 12:37 PM
K
kielbasa Offline
kielbasa  Offline
K
28x12 Mickey Thompson S/R's......
Re: Help me pick my rear tires [Re: kielbasa] #1385129
02/15/13 01:28 PM
02/15/13 01:28 PM
San Jose,CA
migsBIG Offline
YouTube is my go-to news source
migsBIG  Offline
San Jose,CA
I was looking for a replacment set of tires to replace the 305/60R15 BFG''s radial T/A tires on my 70' barracuda and was turned onto Cooper Cobras radial tires. They ride nicer than the BFG's, don't have the fail rate as those ones, had 295/60R15 sizes a avalible, look good and a pair of them were cheaper by $60 on the pair! I have under 5k miles on a set and don't show any signs of wear yet. Very happy I decided to go with these tires.
Re: Help me pick my rear tires [Re: migsBIG] #1385130
02/15/13 02:47 PM
02/15/13 02:47 PM
Fox River Grove, IL
HotRodRailroader Offline
Fox River Grove, IL
Cant go wrong with a classic size like a 275/60/15. I have Mickey Thompson Indy Profile bias on my car. look super era correct with a killer stance
Re: Help me pick my rear tires [Re: HotRodRailroader] #1385131
02/15/13 07:44 PM
02/15/13 07:44 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
Look into the nitto DR, lot of guys getting 10k + out of them. Mine will probably go at least that. Many say they don't hook as well as other DR but they are WAY better than street tires.
Re: Help me pick my rear tires [Re: ademon] #1385132
02/15/13 08:36 PM
02/15/13 08:36 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
I can't help as I just have measely 255/60-15's on a set of 8.5" rims......I guess this is what NOT to do if I were you as they wouldn't have that big, bad @$$, big rear tire look, especially on a Bee with all of that room in those wheel wells
Re: Help me pick my rear tires [Re: A12] #1385133
02/15/13 08:57 PM
02/15/13 08:57 PM
Eugene, Oregon
Secret Chimp Offline
Eugene, Oregon
Don't get T/As... they're such an old-tech tire. Sure they look kind of cool but that's about all they have going for them.
1967 Dodge Coronet Deluxe station wagon
1.03" T-bars, QA1 arms/rods, Cordoba/GM Metric/Volare brake & knuckle, XHDs, Hellwig rear sway, 318 Magnum w/ air gap, 727, 3.23s
Re: Help me pick my rear tires [Re: Secret Chimp] #1385134
02/15/13 09:25 PM
02/15/13 09:25 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Same tech as any 60-series tire out there.....unless you go to a 55-series or less your're not going to see anything that out-techs a basic radial design. Tread pattern, now that's a different tech all together. Then if you want to talk about how a tire is manufactured then you'll have to start looking at Michelin and some other Euro and Pacific Rim manufactures......but not going on my old American Muscle at this point. Only choices are from Goodyear or Firestone IMO and then you need to read the sidewall to see where they are made
So what is out there with leaps and bounds better tech in a 60-series radial tire?
