torque convertor slip
#138486
10/18/08 10:35 PM
10/18/08 10:35 PM
Posts: 954 garnett kansas
rhad
garnett kansas
i have never understood exactly what this is,is it the amount of RPMS before it starts to make the wheels move? thanks ![](/ubbthreads/images/graemlins/smilie_help.gif)
Re: torque convertor slip
[Re: dustpan man]
#138488
10/19/08 11:20 AM
10/19/08 11:20 AM
rhad
garnett kansas
maybe i didnt word it right,at the present i dont have a TC,i read about STALL all the time,but i dont understand exactly what it is or how its figured thanks from a geezer dummy! butch ![](/ubbthreads/images/graemlins/smilie_help.gif)
[Re: rhad]
#138494
10/19/08 02:20 PM
10/19/08 02:20 PM
Posts: 21,847 Kirkland, Washington
Pacnorthcuda
i just want to understand what it means when its 2000 stall,or a 3500 stall,etc thanks
The stall speed is determined by firmly applying the brakes and then mashing the throttle. The RPM's will rise to a point and then either just stay there (like at 2500 rpm) or the rear brakes will be overpowered. Consider that the "Stall Speed" You don't do that for more than about 2-3 seconds as you are baking your tranny fluid FAST and can potentially harm the converter if is not built for that kind of abuse. A Higher staller (looser converter) lets the engine rise to its optimum point in the powerband (assuming a hipo engine here) for a much harder launch. But it comes a price--drivability and certainly mpg can suffer.
[Re: Scott Carl]
#138495
10/19/08 04:29 PM
10/19/08 04:29 PM
Posts: 1,233 Eastern North Carolina
cyphre666
Ok, so what is lock-up and how does it figure into all this??
Conventional converters have a percentage of slippage even when fully engaged. The lock up converter still has a stall speed but it takes out the slippage when fully engaged
