street motor help
#1384668
02/10/13 06:01 PM
02/10/13 06:01 PM
Posts: 106 NY VA USA
GTXbound
NY VA USA
Hey Guys I'am gonna start to build a street motor for my son and need a little help on deciding what route to take . Is 500+ hp doable and live on the street? Here are the specs so far 1973 440 block not decked yet. 2355 TRW pistons 2.061 comp heigt = .020 in the hole edelbrock aluminum rpm's 82cc OOTB. performer rpm intake gasket matched. felpro .039 or .020 steel shims? purple shaft .528 straight up or advanced? steel crank and 6 pack rods. if i deck the block .020 to get zero deck height that will give me a quench in the range of .039 & comp in 10:24 with pump gas. My Questions 1. with the 2355 piston valve reliefs can i run the .528 cam or will ptv be a issue ? 2. Has anyone run a similar combo on the street ? what were the results ? Thanks Guys
Re: street motor help
[Re: GTXbound]
#1384669
02/10/13 06:11 PM
02/10/13 06:11 PM
Posts: 4,318 Prospect, PA
BSB67
Prospect, PA
I highly doubt that there will be a P to V problem, but you HAVE to check.
I have not run a similar combo, but my opinion is that it will run great, but a little short of 500 hp.
[Re: Crizila]
#1384673
02/10/13 07:33 PM
02/10/13 07:33 PM
GTXbound
NY VA USA
Thanks Guys i will defiantly do a ptv when time comes. right now just getting all the parts together i have laying around What about the quench it will be about .059 if i dont deck the block & .039 if i take .020 off? but i will have more ptv. what would you guys do deck or not to deck that is the new question?
[Re: GTXbound]
#1384674
02/10/13 08:11 PM
02/10/13 08:11 PM
Posts: 7,506 Az
Crizila
Az
Deck it first. With a 500 HP streeter you will want a good quench.
Fastest 300
[Re: Crizila]
#1384675
02/11/13 02:32 PM
02/11/13 02:32 PM
dogdays
Ditch the 904 "six-pack" rods, they add mass to an already heavy reciprocating assembly. LYs are better in that they weigh less, use the same rod bolts, which are the most highly stresaed part on the rod. Aftermarket rods are even better, although you should buy the rods before you deck the block for good squish because they are all a hair shorter than OEM rods. Most are 6.760", one set (Manley?) is 6.765, and stock is 6.768.
R.
[Re: dogdays]
#1384676
02/11/13 02:46 PM
02/11/13 02:46 PM
Posts: 3,675 Akron, Ohio U.S.A.
roadhazard
Akron, Ohio U.S.A.
If it were mine I'd prefer the 4 bbl rod over the 6 pack but that's JMO. If your shooting for .040" quench I'd suggest getting the rods center to center equalized (re-sized & new bolts of course). Then measure how far the piston is in the hole. Have the deck cut/squared for the steel shim head gasket and .040" quench. I have no idea on what HP it'll make
[Re: GTXbound]
#1384677
02/11/13 03:28 PM
02/11/13 03:28 PM
Posts: 43,272 Bend,OR USA
Cab_Burge
I have found out the hard way to make sure to check the deck hieght by rocking the piston agianst the cam side of the block and measure the piston on the outside of the block and then rock the piston over against the outside of the block and measure the cam side of the piston top, I use both measurements and go from there I've seen .008 and more differences by measuring that way I use a real thin narrow screwdriver blade to rock the piston back and forth I agree on selling the six pak rods and using a set of LY Make sure and check all eight piston deck hieghts I would shoot for .040 minimum deck hieght now including checking all eight pistons, you may end up with some pistons that are .055 in the hole and some right at .040 but you will be safe using .040 quench Don't be suprised to see some differences on the deck hieghts with stock type rods 500 HP with parts like yours is easy to make, shoot for 10.25 or more compression ratio BTW, 440 motors like and need big carbs, 850 CFM + Don't be suprised to see 510+ HP at 6000 RPM and 550+ Ft. lbs torque at or close to 4000 RPM
[Re: Cab_Burge]
#1384678
02/11/13 09:42 PM
02/11/13 09:42 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
Are you using headers or manifolds with this eng ? I agree with using the lighter LY rods and shooting for zero deck and .039 quench. Myself if I was using headers I would go for a little more cam like maybe step up to the MP .557. Nothing wrong with the .528 in the right combo but if you use exh manifolds and your combo I am not so sure you will be making 500 hp but should be close at the least. Myself I would use the headers and get the extra hp. Good luck , Ron
[Re: 451Mopar]
#1384681
02/12/13 01:49 AM
02/12/13 01:49 AM
GTXbound
NY VA USA
For a few bucks more (&17.79) $409.39 vs. $391.60 (Summit prices), get the light weight LW2355 piston. It's 99 grams lighter (773 vs 872) than the standard L2355 piston, and uses 1/16" rings.
Milling the block to zero deck the pistons, 0.040" head gasket, and 82cc heads is about 10.2:1 compression.
Too late the rotating assembly was balanced and on the shelf
for a while (6pack rods and heavy 2355's) and now just started dusting it off lol.
And just cc the heads tonight and they are 78cc not 82 as i thought
must have been cut some time before i got them...
