1973 B-Body Trans Cooler Mounting? #1383981
02/09/13 02:41 PM
02/09/13 02:41 PM
dart1962_440 Offline OP
Anyone have pics or a diagram of how the factory trans cooler would mount and install in a 73? Are 71-74 the same?
Thank you
Re: 1973 B-Body Trans Cooler Mounting? [Re: dart1962_440] #1383982
02/10/13 06:23 PM
02/10/13 06:23 PM
Anyone have a service manual picture? I believe it would be in the cooling section.
Re: 1973 B-Body Trans Cooler Mounting? [Re: dart1962_440] #1383983
02/23/13 09:34 PM
02/23/13 09:34 PM
Re: 1973 B-Body Trans Cooler Mounting? [Re: dart1962_440] #1383984
02/23/13 11:23 PM
02/23/13 11:23 PM
Between Houston & Galveston TX
SattyNoCar Offline
SattyNoCar  Offline
I wonder if a '73 WAGON would be different from a 2 door? My wagon has a cooler as part of the tow package.
This is the only pic I have online right now, you can see just part of the mounting....
John
Re: 1973 B-Body Trans Cooler Mounting? [Re: SattyNoCar] #1383985
02/24/13 09:31 AM
02/24/13 09:31 AM
Thanks!
Trying to get an idea of how the lines route in and out of the radiator to the cooler and where the mounting points are. Your picture definitely helps me get started.
Re: 1973 B-Body Trans Cooler Mounting? [Re: dart1962_440] #1383986
02/24/13 12:32 PM
02/24/13 12:32 PM
SattyNoCar Offline
SattyNoCar  Offline
Looking at the factory 1973 service manual only shows pics/diagrams for C-bodies and Imperials. Nothing is shown for B-bodies.
Lacking pics, in a nut shell, the fluid is routed from the trans, thru the radiator, then thru the cooler, and back to the trans. On my wagon, both lines for the added cooler are routed up next to the radiator (between the rad and battery) and over the radiator support. None of the line go under or thru the radiator support.
I hope that made sense.
John
Re: 1973 B-Body Trans Cooler Mounting? [Re: SattyNoCar] #1383987
02/24/13 02:20 PM
02/24/13 02:20 PM
Odd that the b body routing isn't in the FSM. I wonder if the 71, 72 or 74 FSM have them.
Thanks for the description on how the lines run!
Re: 1973 B-Body Trans Cooler Mounting? [Re: dart1962_440] #1383988
02/24/13 02:53 PM
02/24/13 02:53 PM
Conway, SC
T2R9 Offline
T2R9  Offline
Conway, SC
From my 74 Service Manual.
Re: 1973 B-Body Trans Cooler Mounting? [Re: T2R9] #1383989
02/24/13 07:02 PM
02/24/13 07:02 PM
Awesome! Thanks!!
Re: 1973 B-Body Trans Cooler Mounting? [Re: T2R9] #1383990
02/24/13 08:24 PM
02/24/13 08:24 PM
Space Station #5
471Magnum Offline
471Magnum  Offline
Space Station #5
What section/page is that on?
-Jim
I can fix it... my old man is a television repairman.
He's got the ultimate set of tools... I can fix it.
Currently Mopar-less
Re: 1973 B-Body Trans Cooler Mounting? [Re: 471Magnum] #1383991
02/24/13 08:58 PM
02/24/13 08:58 PM
Maybe look in the cooling section.
Re: 1973 B-Body Trans Cooler Mounting? [Re: dart1962_440] #1383992
02/24/13 09:40 PM
02/24/13 09:40 PM
Space Station #5
471Magnum Offline
471Magnum  Offline
Space Station #5
My 71 manual (in section 7) only shows a cooler for Hemi cars (mounted completely differently) and one on for full sized.
Specifically, I'll like to see what the 72 FSM shows.
-Jim
Re: 1973 B-Body Trans Cooler Mounting? [Re: dart1962_440] #1383993
02/24/13 09:42 PM
02/24/13 09:42 PM
Conway, SC
T2R9 Offline
T2R9  Offline
Conway, SC
Yup, cooling section near the end. Can get a page number tomorrow when I am back out in the shop.
Re: 1973 B-Body Trans Cooler Mounting? [Re: T2R9] #1383994
02/28/13 06:54 PM
02/28/13 06:54 PM
Anyone with a 72 service manual to compare with the info posted from other years?
Re: 1973 B-Body Trans Cooler Mounting? [Re: dart1962_440] #1383995
02/28/13 07:13 PM
02/28/13 07:13 PM
Conway, SC
T2R9 Offline
T2R9  Offline
Conway, SC
From my 72 manual. They don't differentiate between models in this manual.
Re: 1973 B-Body Trans Cooler Mounting? [Re: T2R9] #1383996
02/28/13 10:29 PM
02/28/13 10:29 PM
Interesting. Thanks for the info.
