Re: How do you get your front end to lift?
[Re: Hey19]
#1383758
02/09/13 12:47 AM
02/09/13 12:47 AM
Posts: 10,011 Frostbitefalls MN (Rocky&Bullw...
gregsdart
Take the front shocks out and see how much resistance you have.You should be able to move it fairly easily. If the front suspension is bound up some where, fixing that should get the front to work. The rear springs may need some attention also. What is the shackle angle at the back? Is there enough travel in the back shackles to allow them to work? Are the springs too high of a spring rate? With the shocks loose at the rear, the rear should move easily also. For a real education on leaf springs, go to an AFCO catalog and read the page on leaf springs. Very enlightening, with much information a lot of folks do not know about what can give you trouble.
[Re: gregsdart]
#1383759
02/09/13 01:36 AM
02/09/13 01:36 AM
Posts: 4,330 Lynchburg, VA
Leon441
Lynchburg, VA
Your control arm bushings may be binding. Take the bolts out and grease them. The lighter the front spring, 6 cyl torsion bars, the more stored energy you have with the car level. You may want to try the race torsion bar.
Your rear tire pressure could have a lot to do with this. My car would leave flat as a pancake with stock suspension. I was told by freinds the car was not spinning. Mounted a set of 28X10.5 slicks on the car with about 11 psi and she picked them up about a foot.
Leon
[Re: Leon441]
#1383760
02/09/13 02:00 AM
02/09/13 02:00 AM
Posts: 1,327 south central,Pa
mopar_to_ya
south central,Pa
Agree with Leon. And; The best thing you can do to a frontend on a Mopar is strutrods with heim ends. It frees up the front end a ton. And put a good set of upper control arms on it. RMS has top shelf products! my
[Re: mopar_to_ya]
#1383761
02/09/13 02:24 AM
02/09/13 02:24 AM
Posts: 9,826 las vegas
70AARcuda
las vegas
http://www.dillingerchassis.com/store/get a set of adjustable upper control arms with heim joints...and a set of adjustable strut rods... changed them out on our 71 dart along with new strange front brakes...car knocked off 2 tenths a couple two weeks ago in Vegas.
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
[Re: Hey19]
#1383762
02/09/13 02:55 AM
02/09/13 02:55 AM
Posts: 1,454 Glendora Ca.
Just-a-dart
Glendora Ca.
The heim joint uppers and strut rods made a huge difference for me. Remember both ends of the car have to work without binding (as Greg said)
You did not say what 90/10s are on the front, they are not all the same. Some take way to much force to extend (like summit brand)
"Just a Bracket car dressed up like a streetcar"
[Re: Todd]
#1383765
02/09/13 11:26 AM
02/09/13 11:26 AM
Posts: 12,204 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
7.10s in the 1/8th is not too shabby. Are you spinning off the line to cause you to want to lift the front? What are you 60ing and what are you trying to get to?
Master, again and still
[Re: DaveRS23]
#1383766
02/09/13 11:36 AM
02/09/13 11:36 AM
Posts: 3,210 robin hood country
deaks
robin hood country
What stops the front end moving around, if the strut rods aren't solid ? Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200# best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft best 60ft 1.36
[Re: Hey19]
#1383768
02/09/13 12:18 PM
02/09/13 12:18 PM
Posts: 226 lino lakes,MN
onebaddakota
lino lakes,MN
The biggest thing that helped me in my nose heavy truck was front end suspension travel coupled with some stored energy via drag springs. I do run cal tracs however. Tom
10.56 at 125.6, with a 1.43 60 ft.
E85, Hyd. Roller 410 magnum,full exhaust, 3500 race weight.
[Re: Hey19]
#1383770
02/09/13 05:15 PM
02/09/13 05:15 PM
Posts: 492 South Jersey, NJ
DragDart360
South Jersey, NJ
Your 60 ft seems a little high, If it's spinning try a little less air pressure. I run 10-11 in mine.
70 Dart Swinger, 2850 lbs SB 408, Bullet roller 264/268 @50 .636 SSDS stage 2 Edelbrock heads, 1 7/8 Headmans, 1050 dominator by Dom, 9.867 @ 133
[Re: DragDart360]
#1383771
02/09/13 06:04 PM
02/09/13 06:04 PM
70AARcuda
las vegas
both of these cars have adjustable upper control arms with heim joints...adjustable strut rods..and CE 90/10 shocks..and they both have light weight strange brakes... http://www.youtube.com/watch?v=mwmkrGoVYg0
Tony
[Re: 70AARcuda]
#1383772
02/09/13 08:48 PM
02/09/13 08:48 PM
Leon441
Lynchburg, VA
Wait a minute back the truck up.
Take a marker and mark your wheel and slick to make sure the tire is not slipping on the wheel. If they are you have two choices. Either glue the beads or install MOROSO or comparable screws. I used sheetmetal one time and broke all eight of them. Beleive it or not this can make a huge difference. I also ran without tubes seemed to help my car back in the day,
Leon
[Re: Leon441]
#1383773
02/09/13 09:33 PM
02/09/13 09:33 PM
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Are you sure you are spinning at the line? I struggled a few years ago right where you are at. I was running 7.10s and really, really wanted a 6 second pass. Turned out, I wasn't spinning. I was hooking okay, I just needed more hit at the line. Called PTC and upped the converter to about 4,000 and BOOM, I knocked a full .10 off the 60 and the E.T. I went from low 1.6s and 7.10s to 1.5 flat and 6.9s. Now I have a lot more trouble hooking up than before.
[Re: Hey19]
#1383775
02/10/13 06:28 AM
02/10/13 06:28 AM
Quicktree
I have a 68 cuda small block with 6 cyl. torsion bars and 90-10 shocks that I race. It runs 7.1" in the 1/8th. I have the bars set so the car is level and it gives no weight transfer at all. It has super stock springs with 80-20 shocks in the back. It just stays flat when it leaves. If I take a hold of the bumper and lift it will raise but it is heavy and is not "loose" by any means. Do you guys have any ideas on getting a stock front end on an a body to work the weight transfer? Thanks
are you having traction issues?
[Re: Quicktree]
#1383776
02/10/13 11:44 AM
02/10/13 11:44 AM
Posts: 684 St. Charles, MO.
Slingshot383
St. Charles, MO.
Bolt 2 sewer lids in the back of the trunk, you'll get lots of weight transfer!
1994 Undercover Chassis 125" altered
stack injected big block, soon blown and injected
Member of The Torque and Recoil Club
