Valley Tray/Plates #1383590
02/08/13 02:29 PM
02/08/13 02:29 PM
Colorado Springs, Colorado
cool70cuda Offline OP
Has anyone used or know of someone who has used this Valley Plate from Hughes Engines?
http://www.hughesengines.com/Index/produ...mp;partid=24085
Re: Valley Tray/Plates [Re: cool70cuda] #1383591
02/08/13 02:59 PM
02/08/13 02:59 PM
maryland
74yellowduster Offline
maryland
at 440source they have different versions for B and for RB and different for single plane or dual plane
i got the one for my B for a dual plane it fit perfectly
i'm not sure if the one size fits all from hughes will give you problems or not
http://store.440source.com/Valley-Pans-Hold-Down-Bars/products/23/
Re: Valley Tray/Plates [Re: 74yellowduster] #1383592
02/08/13 03:05 PM
02/08/13 03:05 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Yeah but the Hughes piece being a two piece can be installed without removing a head....
Re: Valley Tray/Plates [Re: 1_WILD_RT] #1383593
02/08/13 03:11 PM
02/08/13 03:11 PM
74yellowduster - I got one of the DP one's from 440 source, and it has a .090 gap in the rail area where it has the box for the cross over. There is NO way that will seal up with silicone!
Re: Valley Tray/Plates [Re: 74yellowduster] #1383594
02/08/13 03:45 PM
02/08/13 03:45 PM
This is how the one I got from them looks.
Re: Valley Tray/Plates [Re: cool70cuda] #1383595
02/08/13 03:58 PM
02/08/13 03:58 PM
The Pale Blue Dot
Skeptic Offline
Skeptic  Offline
The Pale Blue Dot
Looks like a defect, did you contact them about a return/exchange?
Re: Valley Tray/Plates [Re: cool70cuda] #1383596
02/08/13 04:01 PM
02/08/13 04:01 PM
Baltimore/Denver
64Post Offline
64Post  Offline
Baltimore/Denver
Mine wound up in the trash can shortly after I bought them. Your results may vary.
Re: Valley Tray/Plates [Re: Skeptic] #1383597
02/08/13 05:28 PM
02/08/13 05:28 PM
I called and talked to them this morning, sent pictures, now waiting for a response.
Re: Valley Tray/Plates [Re: cool70cuda] #1383598
02/08/13 10:26 PM
02/08/13 10:26 PM
Cookeville
Chilort Offline
Will Work For Mopars
Chilort  Offline
Cookeville
I am curious to know how this turns out with the 440Source one. I have dual plane intake and was thinking about installing one of these. Thanks for the pictures!
Re: Valley Tray/Plates [Re: cool70cuda] #1383599
02/08/13 11:20 PM
02/08/13 11:20 PM
GEORGIA
barracuda7199 Offline
GEORGIA
my one piece from hughes leaks when i get tired of it i will be destroying it to get it out from under the head without pulling one! the cover with aluminum heads would probably be fine since they have a straight surface on the bottom of the intake face
Re: Valley Tray/Plates [Re: Skeptic] #1383600
02/09/13 03:24 AM
02/09/13 03:24 AM
Mailed it back today, they are going to send me another one, and check that it doesn't have the curves in the rails. I'll post pic's of the replacement once I get it.
