Getting just a little bit more from an 85 Diplomat #1383481
02/08/13 04:23 AM
02/08/13 04:23 AM
Mass
E
Eighty-Five-5th Offline OP
E
Mass
Hi I am a previous user of the forum, I had a 85 5th Ave. It had 148k miles and I never got it to run right, ignition swap, 4bbl swap and all. I recently bought a 85 Diplomat with 84k original miles on it, and the ignition is already swapped for $650! I know I scored. The thing about this car is it has much better performance than my 5th had, so now I'm wondering if I can crack some more potential without ruining my gas mileage. I would like to get the heads milled, or buy a set, any reccomendations? I have a D4B intake already, I also have valve covers to dress it up. My question is what can I do to get this car right around the 250hp/325 ft lbs area, without ruing my mpgs. The car has the 727 with the really high gears in the rear (2:26's or something). I wouldn't mind keeping it a 2 bbl, what is a cam recommendation for some low end grunt, and a little highway fun? Any ideas?
Re: Getting just a little bit more from an 85 Diplomat [Re: Eighty-Five-5th] #1383482
02/08/13 06:18 AM
02/08/13 06:18 AM
Washington State, USA
W
Winchester 73 Offline
W
my list of stuff id do -in order
weight loss(you could get 500lbs out in a weekend without trying)
exhaust
swapmeet carb/intake
gears (dakota rearend swap)
od tranny
Re: Getting just a little bit more from an 85 Diplomat [Re: Eighty-Five-5th] #1383483
02/08/13 10:32 AM
02/08/13 10:32 AM
Az
Crizila Offline
Crizila  Offline
Az
Indy sells sm blk heads for around $499. They are all ready to go with 1.88 / 1.60 valves. Pocket port them and mill them and bolt them on. Dump the 2brl for a TQ. Find a 9 1/4" diff from a 75-9 Cordoba ( or truck as mentioned ). There are still plenty in the bone yards, many with 3.23 gears. Check with Hughes on a cam, but I would go with a HEH1019AL - or the 1523 if you can run a 3.55 gear. Cheap headers and dual 2 1/4" exhaust would be nice. Easy 14 second car with those mods.
Fastest 300
Re: Getting just a little bit more from an 85 Diplomat [Re: Eighty-Five-5th] #1383484
02/08/13 12:35 PM
02/08/13 12:35 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I dont know if you drive it mainly in the city or out
on the e-way the most.. but a set of 3.23 or 3.55 would
actually give you better mileage in the city(you
dont have to press the pedal as hard to get it rolling)
Re: Getting just a little bit more from an 85 Diplomat [Re: Crizila] #1383485
02/08/13 02:00 PM
02/08/13 02:00 PM
Mass
E
E
Mass
Honestly I don't want to lose the way it rides on the highway, and I am not able to do the axle swap or tranny swap right away. I bought the car for $650 and I need to get a little while out of it without dumping too much $ into it. Right now I'm just freshening everything up with gaskets, probably a new water pump but I don't have the money to swap to a 4bbl yet. I have the D4B intake, but I'd like to sell it in favor of one that will let me keep my Air Compressor. The reason I mention a cam is because I'd like to do it while the water pump is being done, along with a timing chain/gears. Should I wait until I have a carb for it? The only reason I'm a little against the gear ratio is because this car is a ball on the highway, it passes everything INCLUDING GAS STATIONS (everyone is freaking out about the storm). As it is right now I'd say the car deffinetly gets over 15 mpg, which is insane compared to my 5th Ave. I was considering a 2.94 posi unit from a police car.
Re: Getting just a little bit more from an 85 Diplomat [Re: Crizila] #1383486
02/08/13 06:00 PM
02/08/13 06:00 PM
Indiana
Fury Fan Offline
Fury Fan  Offline
Indiana
75-9 Dobas have 8 1/4 axles (at least mine did, and it had a 400.) And don't hte 9 1/4 truck axles have durability issues?
If you're going to swap heads, look for -302s (small chambers for CR and good ports for swirl) which are good for about 250hp or go with Magnum heads for more power and MPG (research teh mods required).
i fyour engine is an 85 IIRC it'll have a rolelr cam. Research posts by Patrick for cam recommendations (and other good M-body knowledge).
Do you truly have a 727 in your '85? If so, consider swapping for an 80-newer 904 as it will have deeper 1st-2nd gears (2.74/1.54 vs 2.45/1.45) and that's the equivalent of deeper rearend gears *plus* it's lighter and absorbs less power than a 727 (you'll need a longer driveshaft but that's a JY part from any 904 Dippy).
Re: Getting just a little bit more from an 85 Diplomat [Re: Eighty-Five-5th] #1383487
02/08/13 06:08 PM
02/08/13 06:08 PM
Indiana
Fury Fan Offline
Fury Fan  Offline
Indiana
If you can't afford a carb, have you added up how much a cam is going to cost? That's cam, lifters, springs, timing chian, timing gasket set, intake gasket set. Thats more than a $250 carb.
Although, I've read that the 360 2-V cam is a good upgrade for mild 318s, so you could maybe get a RockAuto regrind of that and your current springs would probably be suitable if you didn't rev it thru the roof.
Re: Getting just a little bit more from an 85 Diplomat [Re: Fury Fan] #1383488
02/09/13 09:00 PM
02/09/13 09:00 PM
Central NC
gch Offline
gch  Offline
Central NC
First thing I would do is replace the muffler with a less restrictive one and address in crimps or crushed pipe areas.Flowmaster makes a nice 2 into 1 y pipe that will outflow the factory one by a ton.Lose the cat or replace it with a high flow one.Maybe have to jet up the carb one size for max performance.
Other than that I would wait until I had the money to do it right.
Rear end swap first and then heads/cam/intake/carb and maybe headers.
