Re: My 6.4 Gen 3 Hemi - Assembly In Process!!!!!
[Re: TonyS451]
#1382922
04/04/13 03:02 PM
04/04/13 03:02 PM
Posts: 232 Lansing, MI
MuscleMike
Lansing, MI
I asked Steff if he wanted us to keep pushing the engine. We could have tried a bigger Dominator, ran synthetic oil, move cam timing, added a vacuum pump and made 15" of vacuum to make more power. We also could have run the water temperture down to 120* and it WOULD have made more power guaranteed! Steff wanted to tune it like he is going to run it in his car so 150* water temp, mineral oil and no vacuum pump is how this was tested. We were all pleasantly surprised! Steff doesn't have and he doesnt want a cage in his car. I am positive it will go fast enough to need one so leaning on the engine any harder was kinda pointless.
[Re: MuscleMike]
#1382923
04/04/13 05:46 PM
04/04/13 05:46 PM
Posts: 20,655 in a cattle trailer down by th...
Guitar Jones
Damn, just damn, I want that recipe. My car is certified to 8.50 and if need be I'll add the extra bars. Simply awesome numbers, you should be proud of that.
[Re: Guitar Jones]
#1382924
04/04/13 06:54 PM
04/04/13 06:54 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
Steff hides bars in his frame rails. Don't let him fool you
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: MuscleMike]
#1382925
04/04/13 06:56 PM
04/04/13 06:56 PM
Posts: 4,255 Canada
WO23Coronet
Canada
So it sounds like they aren't happy/massaged numbers, but with all the tricks you listed above, how much more power would it have made if you we're going for a hero number?
[Re: WO23Coronet]
#1382926
04/04/13 08:31 PM
04/04/13 08:31 PM
Posts: 1,845 Tampa
DusterDave
Tampa
SICK numbers!!! Congrats, Steff!! How many CFM was the engine pulling at peak HP?
Gone to the dark side with an LS3 powered '57 Chevy 210
[Re: sixpackgut]
#1382927
04/04/13 08:58 PM
04/04/13 08:58 PM
Posts: 998 Clinton Township, Michigan
Dartin
HeHeHe..... He's a tricky devil for sure . Congrats on the great numbers. Sean has been giving me little tidbits here and there, been interesting for sure! Good luck with the new bullet AND the move as well!!!
Randy
[Re: Dartin]
#1382928
04/04/13 11:19 PM
04/04/13 11:19 PM
Posts: 226 lino lakes,MN
onebaddakota
lino lakes,MN
These numbers are just amazing. I race a lot with the LSx crowd. I haven't seen any of them making this kind of power short of a big cube LSx motor and aftermarket heads and far bigger cam. Speaking of cams, could you post the specs on it?
10.56 at 125.6, with a 1.43 60 ft.
E85, Hyd. Roller 410 magnum,full exhaust, 3500 race weight.
[Re: STEFF]
#1382929
04/04/13 11:27 PM
04/04/13 11:27 PM
Posts: 3,943 Melbourne.....Oz-land
Moparmal
Steff - Can you explain why you went with a belt driven oil pump instead of the factory unit?
Was it just capacity or is there an issue with the factory pumps?
My Cam/Crank Belt Drive eliminates the factory front cover, so the stock pump no longer can be used. Plus I really like the belt driven pump as you can adust the pressure on the low speed side, on the pump and then adjust the high rpm pressure with the pulley ratio, to really dial it in to the motor. Plus, it looks cool! LoL.
Ok thx!
[Re: MuscleMike]
#1382933
04/05/13 11:05 AM
04/05/13 11:05 AM
Posts: 4,302 Nebraska
72Swinger
Nebraska
I think you have some serious Engine Masters stuff here Mike.
Mopar to the bone!!!
[Re: 72Swinger]
#1382934
04/05/13 11:08 AM
04/05/13 11:08 AM
sixpackgut
Charleston
what are the details on timing?
[Re: sixpackgut]
#1382935
04/05/13 11:39 AM
04/05/13 11:39 AM
Posts: 2,776 Ontario Canada
MattW
Ontario Canada
Been hearing lots that the G3 does like too much timing. Somewhere between 20 and 23
