My 6.4 Gen 3 Hemi - Final Update - Dyno Numbers!!
#1382799
02/07/13 12:03 AM
02/07/13 12:03 AM
Posts: 3,871 Smyrna, South Carolina
STEFF
Finally started assembling my 6.4 Gen 3 Hemi. Here's some pics of progress so far: I did NOT want to paint this thing Hemi Orange. Road Runner has Purple in him, so my RR will have Purple in it. I eliminated & plugged the piston squirter holes. Did not like that the squirters block half of the oil feed hole that runs thru the block. Molnar Technologies 3.79 Stroke 4340 Crank Diamond 4.100 Bore Pistons on Molnar Technologies 6.125 H-Beam Rods. Rings are Total Seal 1.5mm Plasma Moly Top, 1.5mm Napier 2nd, 3mm Oil Ring. Got 4 of the Pistons in. 4 to go. More to follow!!! Cam & my Belt Drive Install Next...
Re: My 6.4 Gen 3 Hemi - Assembly In Process!!!!!
[Re: moretoys]
#1382803
02/07/13 03:51 AM
02/07/13 03:51 AM
Triple Threat
Renton Washington
He said why above.
Looks Awesome Steff, can't wait to hear how it runs.
[Re: STEFF]
#1382804
02/07/13 08:27 AM
02/07/13 08:27 AM
Posts: 833 MN
hemidup
MN
With that purple paint and the GM Performance sticker in the background just cost you -30 hp. j/k lol. Good to see you moving forward again ...What compression ratio are you building at?
Jerry Williams.
[Re: hemidup]
#1382806
02/07/13 11:22 AM
02/07/13 11:22 AM
STEFF
30hp? I hope not LOL! Every motor I've ever had has either been Race Hemi Orange or Black. Just needed to change it up...I'm not a traditionalist by any means. (my RR also has a Ford 9" rear and GM Turbo 400 Trans)
Compression ratio: 11.5:1. I'm going to run it on pump premium.
[Re: Labratt]
#1382810
02/07/13 01:02 PM
02/07/13 01:02 PM
Posts: 17,844 S.E. Michigan
ZIPPY
S.E. Michigan
Cool beans. Awaiting the cam tunnel/cam drive setup!! Purple is kool. Same thing here, getting tired of orange so I switched to turquoise
Rich H.
Esse Quam Videri
[Re: ZIPPY]
#1382811
02/07/13 02:06 PM
02/07/13 02:06 PM
Posts: 10,645 Houston, Tx
AlexP
Houston, Tx
[Re: STEFF]
#1382814
02/07/13 03:23 PM
02/07/13 03:23 PM
Posts: 3,410 Belpre,Ohio
CHAPPER
Belpre,Ohio
Any valve spring info..??
If you like drag racing, support your local track.
[Re: hemidup]
#1382818
02/07/13 05:56 PM
02/07/13 05:56 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
what is the rocker ratio? i forgot
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
