Re: My 6.4 Gen 3 Hemi - Assembly In Process!!!!!
[Re: STEFF]
#1382961
05/21/13 02:46 PM
05/21/13 02:46 PM
Posts: 4,302 Nebraska
72Swinger
Nebraska
Any updates on this beast?
Mopar to the bone!!!
[Re: 72Swinger]
#1382962
05/21/13 05:54 PM
05/21/13 05:54 PM
Posts: 12,129 Cleveland
sunroofgtx
Cleveland
This was an excellent read. I agree on the statement of a lot of 60's and 70's engines for sale. The coil packs tunability factor as well as modern data aquisition will make the tunes dead-on. Steff, thanks for trusting out Gen3 Hemi Stage 2 coil packs. Muscle Motors are putting them on most of their builds.
Join the quickest team in motorsports. Team FireCore. CustomWiresets.com
[Re: sunroofgtx]
#1382963
01/16/14 11:53 PM
01/16/14 11:53 PM
Posts: 3,517 pacific northwest
Stroker Scamp
pacific northwest
did you ever hit the track with this?
footbrake N/A SB 408 Scamp 10.10 @ 132 street/strip 73 Duster 340 street strip 12.79 @ 105
[Re: Stroker Scamp]
#1382964
01/17/14 09:25 PM
01/17/14 09:25 PM
Posts: 2,864 IN
Irun5snd8th
IN
Steff, WOW thats amazing numbers! Thats actually too much horsepower for what I want to do with mine.
AFCO, Rons Fuel Injection sponsored Dodge Challenger
Mention Street Lethal Motorsports
[Re: Stroker Scamp]
#1382965
01/17/14 10:11 PM
01/17/14 10:11 PM
Posts: 3,871 Smyrna, South Carolina
STEFF
With my Family and I moving from Michigan to South Carolina last August, I wasn't able to get out. Too much stuff going on. But, I did drive it on the street a bit.. lots of fun! Tracks open soon down here, so I'm getting excited to finally hit the track.
[Re: Streetwize]
#1382968
01/18/14 09:43 PM
01/18/14 09:43 PM
STEFF
I need to swing by and see it....we usually caravan to Mopars at the Rock in April and we always pit with Chip and Jim Owens, c'mon down, buddy!
Come by any time Bobby. Count me in on your caravan to The Rock!
Hi Wes! I need some pics of that car in your avatar.
[Re: hudsonhornet7x]
#1382970
08/14/14 09:13 AM
08/14/14 09:13 AM
STEFF
I am very impressed with this build. Is there a particular reason you built a g4 block?
Is it stronger than a 5.7 or 6.1?
No specific reason. I originally had a 5.7 block to build but then stumbled into a 6.4 block and went with it.
[Re: STEFF]
#1382972
08/14/14 01:39 PM
08/14/14 01:39 PM
Posts: 1,541 USA
hudsonhornet7x
USA
Thanks for the info. I have been told that a 6.4 was a much stronger block than the 6.1 or 5.7. I have also read conflicting reports on which block is the thickest, and has the best main webs.
Can you shed some light on the subject?
Thanks!
#1382973
08/14/14 07:06 PM
08/14/14 07:06 PM
Posts: 2,776 Ontario Canada
MattW
Ontario Canada
Thanks!
The info I'm getting is that the HellCat used the same 6.4 production block Matt
[Re: MattW]
#1382974
08/15/14 02:40 AM
08/15/14 02:40 AM
Posts: 3,943 Melbourne.....Oz-land
Moparmal
Yep...just a de-stroked 6.4 with forged internals.
67 RO23 clone with 6.1 SRT Hemi and dual quads. Soon to have Drag Pak induction and Throttle body.
#1382975
08/15/14 08:18 AM
08/15/14 08:18 AM
STEFF
Thanks!
It's been awhile since I looked at a 5.7, 6.1 vs. 6.4. I will look at them again tonite and compare the differences.
[Re: TheOtherDodge]
#1382978
08/15/14 02:21 PM
08/15/14 02:21 PM
STEFF
Steff, without having to read all the pages, what ever happend to this motor? Did you ever get it down the track? I am interested because my next project may be a turbo Gen III Hemi to replace my Magnum motor.
I've been driving the wheels off of it. Been too the track a few times with issues that ended the days early. Finally got out and made some passes. Left/ran like a turd. OK, Converter's tight. I removed the converter to get loosened up and noticed the fluid was contaminated with clutch material. I had the converter loosened up and in the mean time, tore in the trans....(Turbo 400) Found the Forward Drum Clutches & Plates were smoked and the Forward Drum had a groove wore into it by one of the teflon Stator Rings, where the drum seals to the Stator on the Front Pump. The Forward Drum was a nice aftermarket Aluminum piece and is now junk. The weird thing is, it never acted like the trans was hurt, on the street.
Going to put the trans back together this weekend and try to get out the next weekend.
