All Forged cranks drilled for pilot bushing? #1382707
02/06/13 10:19 PM
02/06/13 10:19 PM
S.I. N.Y.
1MYTGTX Offline OP
1MYTGTX  Offline OP
S.I. N.Y.
Are all Mopar vintage forged cranks drilled for a pilot bushing?
'72 440 with a forged crank....would it be pre drilled for the bushing for the 4 speed trans?
1MYTGTX
Re: All Forged cranks drilled for pilot bushing? [Re: 1MYTGTX] #1382708
02/06/13 10:23 PM
02/06/13 10:23 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
Not all are drilled for the 4 speed bushing
Re: All Forged cranks drilled for pilot bushing? [Re: roadhazard] #1382709
02/06/13 10:29 PM
02/06/13 10:29 PM
McGregor,Iowa 52157
500ciDuster Offline
500ciDuster  Offline
McGregor,Iowa 52157
I did a 451 for a friend and the 440 crank wasn't drilled but had been spot drilled and thats the only one I've ever seen,so it did happen
Re: All Forged cranks drilled for pilot bushing? [Re: roadhazard] #1382710
02/06/13 11:03 PM
02/06/13 11:03 PM
A gulag near you.
JohnRR Offline
JohnRR  Offline
A gulag near you.
, it should be drilled , but may not be finished to size. Napa used to sell an undersize bushing to fit but I bought what I thought was the bushing and it was not. there is a later bushing for dakotas and such that fits the convertor snout register , you may have to trim a little off the end of the input though .
Re: All Forged cranks drilled for pilot bushing? [Re: JohnRR] #1382711
02/06/13 11:22 PM
02/06/13 11:22 PM
Forged cranks for automatic equipped cars would typically have been rough drilled, but not finished machined for a pilot bushing. I think the NAPA bushing for the semi-finished pilot hole is still available, and it's OK in a pinch, but the best solution is either to machine the crank properly or to use the roller bearing mentioned above that fits into where the torque convertor snout would go.
Re: All Forged cranks drilled for pilot bushing? #1382712
02/07/13 08:28 AM
02/07/13 08:28 AM
S.I. N.Y.
1MYTGTX Offline OP
1MYTGTX  Offline OP
S.I. N.Y.
Thanks for the replies all. My pipe dream of converting to an 18 spline 4 speed might be just that....a pipe dream.
Anyone have info/part #'s on these special bushings?
1MYTGTX
Re: All Forged cranks drilled for pilot bushing? [Re: 1MYTGTX] #1382713
02/07/13 08:53 AM
02/07/13 08:53 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
Go to rock auto. vehicle application: Dodge. 1998. Dakota. 5.2 Transmission-Manual. Pilot bushing/bearing.
costs about $10. it's a roller bearing that's inside of a giant bushing so that it fits perfectly into the size of the torque converter hub. allows you to put a manual transmission where an automatic once was, without having to remove crank to finish machine the hole.
(I believe you have to cut about an 1" off the input shaft of the trans? but I'm not sure. I put a TKO transmission behind a big block and didn't cut anything down to make it fit, and that engine was originally an automatic.
**Photobucket sucks**
Re: All Forged cranks drilled for pilot bushing? [Re: 70Cuda383] #1382714
02/07/13 08:57 AM
02/07/13 08:57 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
the stock pilot bearing for any magnum series truck should be the same.
regardless, the parts store monkeys can't look anything up by saying "any magnum engine truck"
here's what the bushing/bearing looks like, and you can see that with a few quick smacks with a rubber mallet, it'll drive it home into the hub for the torque converter where it will sit nice and snug.
(this is a spare 383 I have sitting in my garage, and a new bushing for the 5.9L that's in my dakota)
Re: All Forged cranks drilled for pilot bushing? [Re: 70Cuda383] #1382715
02/07/13 09:16 AM
02/07/13 09:16 AM
AR
70_roadrunner Offline
AR
About 3/4" will need to be taken off the input shaft of the transmission. I just stuck mine in a chop saw without removing it from the transmission. I then put a chamfer on the cut end with a Dumore grinder. I believe the transmission could can still be used with a stock setup.
Re: All Forged cranks drilled for pilot bushing? [Re: 70_roadrunner] #1382716
02/07/13 11:21 AM
02/07/13 11:21 AM
Pgh, PA
Bull1tt Offline
Bull1tt  Offline
Pgh, PA
I used one of these in a 383 crank and didn't have to cut the 833 input shaft.
Re: All Forged cranks drilled for pilot bushing? [Re: Bull1tt] #1382717
02/07/13 11:42 AM
02/07/13 11:42 AM
Maud,Tx
maud Offline
maud  Offline
Maud,Tx
I also have had to cut off the input shaft about an inch.
Re: All Forged cranks drilled for pilot bushing? [Re: maud] #1382718
02/07/13 12:03 PM
02/07/13 12:03 PM
A gulag near you.
JohnRR Offline
JohnRR  Offline
A gulag near you.
Depends on how deep the crank is drilled , so need to be cut , some don't
Re: All Forged cranks drilled for pilot bushing? [Re: JohnRR] #1382719
02/07/13 12:08 PM
02/07/13 12:08 PM
Idaho
LaRoy Engines Offline
Idaho
Please, don't cut off the end of the input shaft of an 18 spline hemi transmission. Have the crankshaft properly prepared. In the end, it is however YOUR transmission, do as you will.
Re: All Forged cranks drilled for pilot bushing? [Re: LaRoy Engines] #1382720
02/07/13 12:31 PM
02/07/13 12:31 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
A lot of 18 spline transmissions were used behind Chivvy engines because the crappy Munchie "rock crusher" would destroy itself. These idiots ruin too many input shafts because they HAD to cut them down...
JB Rhinehart, Realist
A-Body's RULE!
Re: All Forged cranks drilled for pilot bushing? [Re: LaRoy Engines] #1382721
02/07/13 12:31 PM
02/07/13 12:31 PM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
I have drilled out a crank installed in a motor twice (383) and I have taken a crank to a GENERAL machine shop to be done properly. The cost at the machine shop was well under $50. Even if I were using the late model bearing I would drill the crank before I cut an input shaft...
Re: All Forged cranks drilled for pilot bushing? [Re: LaRoy Engines] #1382722
02/07/13 01:15 PM
02/07/13 01:15 PM
A gulag near you.
JohnRR Offline
JohnRR  Offline
A gulag near you.
Why ? It's not like he is cutting a ton off ,it would still work in another crank and It's not that expensive to have the end retipped should someone decide they don't want to use the dakota part for some silly reason. The eagle crank in my stroker is not sized properly for the stock Pilot bushing , I'm going to trim my trans , 18 spline A body unit I made and use the dak part ...
Re: All Forged cranks drilled for pilot bushing? [Re: JohnRR] #1382723
02/07/13 03:20 PM
02/07/13 03:20 PM
AR
AR
If doing a 4 speed conversion, you don't want to pull the crank. Just cut the input shaft. If the crank is already out, go ahead and have the crank drilled. On a cast crank, drilling may lead to oil seeping due to porosity in the casting.
Re: All Forged cranks drilled for pilot bushing? [Re: JohnRR] #1382724
02/07/13 06:17 PM
02/07/13 06:17 PM
Idaho
Idaho
Why? Personal frustration with the practice! Of the hemi 4-spd transmissions I own, two have the input shaft cut short and one is cut down to Chevy diameter. Then there are the two 23 spline input shafts cut short. I didn't cut any of them.
Its kinda like the crate motors sent to us to rebuild 'cause the original builders don't know what they are doing or won't take the time or expense to do it right.
Its okay to cut them off your transmission if you want. I'm just pleading that you may reconsider and finish the installation another way.
Re: All Forged cranks drilled for pilot bushing? [Re: LaRoy Engines] #1382725
02/07/13 07:50 PM
02/07/13 07:50 PM
S.I. N.Y.
1MYTGTX Offline OP
1MYTGTX  Offline OP
S.I. N.Y.
Thanks for the detailed info guys.....my dream is coming closer to reality now
1MYTGTX
Re: All Forged cranks drilled for pilot bushing? [Re: 1MYTGTX] #1382726
02/07/13 09:26 PM
02/07/13 09:26 PM
JERSEY
RJS Offline
RJS  Offline
JERSEY
I would assume that roller bearing you guys are showing is a cheap alternative to the roller bearing that Brewers/Passion Mancini would sell???
So Chris you going to swap in a Dana too??
