Re: All Forged cranks drilled for pilot bushing?
[Re: RJS]
#1382727
02/07/13 11:02 PM
02/07/13 11:02 PM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
It's probably the same bearing that Brewers or Mancini sells. what do they charge for it?
The bearing I posted a picture of above, is about $8 on Rock auto, but after shipping would probably be $10-12 to your door.
I think I actually picked mine up at the local advance auto for $12-15...I don't remember exactly how much now (they had to order it in from the Hub, I picked it up the next day)
**Photobucket sucks**
[Re: 70Cuda383]
#1382728
02/08/13 12:04 AM
02/08/13 12:04 AM
Posts: 6,232 JERSEY
RJS
JERSEY
[Re: RJS]
#1382729
02/08/13 12:15 AM
02/08/13 12:15 AM
Posts: 10,295 Someplace you aren't
SomeCarGuy
I have used the Dak bearing and cut only 1/8 or 1/4" off the shaft. Be a good idea to measure and not take off moe than you need to. I also chamfered the tip and that might have made mine work.
I want my fair share
[Re: SomeCarGuy]
#1382730
02/08/13 12:04 PM
02/08/13 12:04 PM
Posts: 75,274 A gulag near you.
JohnRR
A gulag near you.
[Re: fourgearsavoy]
#1382734
02/10/13 12:55 AM
02/10/13 12:55 AM
JohnRR
A gulag near you.
I like it when some people whack the input shaft on an 833 That way I can buy it cheaper than one that is still whole Gus
