A fix for those ugly cab lights #1382437
02/06/13 03:13 PM
02/06/13 03:13 PM
Winnipeg, Manitoba, Canada
4dr4x4 Offline OP
mopar addict
4dr4x4  Offline OP
mopar addict
It's been a while since I posted any of things I'm added to my truck but this one I just had to share. I got my 1980 2wd Step side about 10 years ago. I had looked for one for years and it's in great shape but for some reason it came from the factory with those ugly big rig style cab lights. After the first year I took them off and put rubber plugs in the holes but it always bugged me. People would always ask, what's the rubber plugs for.lol I was at a local Big Rig shop and was looking at the LED lights that they had and these very small amber lights caught my eye (they also have red and clear) and the wheels started turning. I picked up one for $15 to see if I could use it for something. I had another idea for them at first but I will tell you about that later.
I pulled one of the plugs out of the roof and tried to cut or drill a round hole in it but it just didn't work so I had to look for a new plug that already had a hole in it. I have lots of parts and it didn't take me to long to find that a speedo cable grommet fits both the hole in the roof and the light.
I could do a post just on how long it took me to run the wires though the roof and down the window pillar but first I want to see if anyone thinks it's any better than the stock lights.
Re: A fix for those ugly cab lights [Re: 4dr4x4] #1382438
02/06/13 03:26 PM
02/06/13 03:26 PM
4dr4x4 Offline OP
mopar addict
4dr4x4  Offline OP
mopar addict
This is the LED light that I used with the plug I tried to cut. These have 3 LED's in each light and a reflective cover. With this light you can have a running light & a brighter signal light. I just used the running light wire, the signal was just to bright.
They are made by United Pacific
www.uapac.com
CHECK THEM OUT
They have accessories & lights for everything from Rat Rods to Big Rigs.
(I may try the round LED 7" headlights next)
Re: A fix for those ugly cab lights [Re: 4dr4x4] #1382439
02/06/13 03:27 PM
02/06/13 03:27 PM
4dr4x4 Offline OP
mopar addict
4dr4x4  Offline OP
mopar addict
With the lights on.
Re: A fix for those ugly cab lights [Re: 4dr4x4] #1382440
02/06/13 03:31 PM
02/06/13 03:31 PM
4dr4x4 Offline OP
mopar addict
4dr4x4  Offline OP
mopar addict
With the lights off you can barely see them.
Re: A fix for those ugly cab lights [Re: 4dr4x4] #1382441
02/06/13 03:42 PM
02/06/13 03:42 PM
4dr4x4 Offline OP
mopar addict
4dr4x4  Offline OP
mopar addict
In total it cost me about $100 and a bit of my time. I wouldn't even want to guess how much a body shop would charge to fill in the holes, It might be cheaper to buy a new cab (and believe me I had thought about it).
Re: A fix for those ugly cab lights [Re: 4dr4x4] #1382442
02/06/13 03:52 PM
02/06/13 03:52 PM
Grand Forks, ND
Hemi_Ram Offline
Hemi_Ram  Offline
Grand Forks, ND
Looks great! Hey what size rims and tires are you running on the burgundy stepside?
Re: A fix for those ugly cab lights [Re: Hemi_Ram] #1382443
02/06/13 03:59 PM
02/06/13 03:59 PM
4dr4x4 Offline OP
mopar addict
4dr4x4  Offline OP
mopar addict
The rims are Super coupe 7's in the front and factory 8's in the back. The back tires are BFG's, I think they are 285-70-15's but I would have to check (I don't think they make them anymore).
Re: A fix for those ugly cab lights [Re: 4dr4x4] #1382444
02/06/13 10:03 PM
02/06/13 10:03 PM
Sunny South Florida
Golden-Arm Offline
Golden-Arm  Offline
Sunny South Florida
looks pretty good, eh!
Re: A fix for those ugly cab lights [Re: Golden-Arm] #1382445
02/06/13 11:42 PM
02/06/13 11:42 PM
State of Confusion
hp383 Offline
Just a normal tag again
hp383  Offline
State of Confusion
http://tecniqinc.com/pages/group_clearance.html
Give these guys a look. The trailer shop I worked for buys several of their accent, marker, and other LED products.
You can order direct as well.
I know the shop cost on those little single LED's that fit a 3/4" hole is only around $3.50. And they can be had in many colors.
Join the Penguin Liberation Front!!
Stop the Hippo Occupation!
Re: A fix for those ugly cab lights [Re: hp383] #1382446
02/06/13 11:47 PM
02/06/13 11:47 PM
Near Reading PA USA
pinkduster Offline
pinkduster  Offline
Near Reading PA USA
I think the stock cab lights look good on certain models, but not on little 2 wheel drive short beds. 4 wheel drives, 3/4 ton and up, look fine.
Re: A fix for those ugly cab lights [Re: pinkduster] #1382447
02/07/13 01:25 AM
02/07/13 01:25 AM
east side of Ohio
basketcase Offline
basketcase  Offline
east side of Ohio
I always liked the stockers myself.
1981 Dodge D150 360 auto
Re: A fix for those ugly cab lights [Re: pinkduster] #1382448
02/07/13 04:58 AM
02/07/13 04:58 AM
4dr4x4 Offline OP
mopar addict
4dr4x4  Offline OP
mopar addict
I don't mind the stock cab lights so much on a longbox 4x4 but they just don't look right on my stepside (to me). Like with anything some people will like them and some won't. I would rather have a clean roof or as close to it as I can get.
The reason I got the LED's in the first place was to try and put a signal light on the side of my big truck like some of the new cars have. My truck has 37" tires and it's hard to see small cars when they get in the blind spot so I came up with this idea to let them know when I'm turning. To much snow here right now I have to wait untill spring to install it on my truck. I'm going to install it on my beater first and see if I like the look before I drill a hole in my good truck.
Re: A fix for those ugly cab lights [Re: hp383] #1382449
02/07/13 05:10 AM
02/07/13 05:10 AM
4dr4x4 Offline OP
mopar addict
4dr4x4  Offline OP
mopar addict
Thanks HP383 for that info, that's a good price & the lights they sell maybe even smaller than the ones I used.
This is the truck I'm putting the emblems on.
Re: A fix for those ugly cab lights [Re: 4dr4x4] #1382450
02/07/13 07:45 AM
02/07/13 07:45 AM
Greenville, PA
redraptor Offline
redraptor  Offline
Greenville, PA
That's a great fix. Thanks for sharing!
Re: A fix for those ugly cab lights [Re: 4dr4x4] #1382451
02/07/13 08:27 AM
02/07/13 08:27 AM
Near Reading PA USA
pinkduster Offline
pinkduster  Offline
Near Reading PA USA
Nice truck.
Re: A fix for those ugly cab lights [Re: pinkduster] #1382452
02/10/13 03:17 AM
02/10/13 03:17 AM
dogdays Offline
dogdays  Offline
Yeah, why they are on the roof of my '77F150 I'll never know. A hailstorm wiped them all out. Now I'm looking for decent cheap replacements, good post!
R.
Re: A fix for those ugly cab lights [Re: dogdays] #1382453
02/10/13 06:28 AM
02/10/13 06:28 AM
4dr4x4 Offline OP
mopar addict
4dr4x4  Offline OP
mopar addict
Thanks, there small but you can really see them in the dark. Now I don't mind having cab lights. I also have really cool LED tail lights.
Re: A fix for those ugly cab lights [Re: 4dr4x4] #1382454
09/29/13 09:51 PM
09/29/13 09:51 PM
4dr4x4 Offline OP
mopar addict
4dr4x4  Offline OP
mopar addict
this is what I ended up using for my side signal lights, look in the middle of the Dakota hood emblem. I went with a clear/amber light, you have to look hard to even see it until it comes on.
