Re: Can we talk about blue engines for a second??
[Re: wedgepower]
#1382280
02/06/13 04:24 AM
02/06/13 04:24 AM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
there are two different mopar "blue" colors. Small blocks in the early 70s were actually a light blue color. The older big block color was more of a turqoise, but the rattle cans I've found of it still call it "Chrysler Blue". Someone else will likely chime in with some actual part numbers.
[Re: StealthWedge67]
#1382281
02/06/13 10:36 AM
02/06/13 10:36 AM
Posts: 2,096 mesa,az.
wedgepower
mesa,az.
Yes I know of the turquoise as well, had a late 60s 383 or 2 that were that color. I think the darker blue was like '72 or '73 and up. I have only found one mention of it on the internets and the guy said it's a mystery color. Here is a link and quote. http://www.dippy.org/forum2/index.php?topic=106.0"Blue - (No Mopar number) (Color code never appeared in manuals) Slightly darker than the standard blue used on the 70's LA engines. Paint also turned Turquoise with heat. Even Galen Govier does not have a spec for mixing. This paint was used on a lot of 340' and other LA engines in late 69. Most restorers use Blue Mopar P4349217 (above) to repaint and the judges agree."
[Re: MoparMarq]
#1382287
02/08/13 02:29 PM
02/08/13 02:29 PM
Posts: 4,046 Minnesota
72blubird
Minnesota
Attached is a pic of my motor with rattle trap paint. It is chrysler blue from Plastisol. I believe it looks pretty close to the blue motor i compared it too. It maybe a tad lighter but as it ages they get a bit darker anyway. I would suggest clearing over it. Some will say don't do it it will look to shiny I haven't found that to be the case and cleaning up and spills is much easier. If you look closely at mine you may find a aluminum piece or two as well.
What was I thinking....
[Re: 72blubird]
#1382288
02/08/13 02:39 PM
02/08/13 02:39 PM
72blubird
Minnesota
Here is a pic of the can it was Plastikote not Plastisol and it is number 232
[Re: 72blubird]
#1382290
02/08/13 05:05 PM
02/08/13 05:05 PM
Posts: 15,931 Central Florida
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
I also used Plastikote 232 on my 360 Aspen. It does a nice job.
Facts are stubborn things.
