Re: color for control arms
[Re: ScottSmith_Harms]
#1382149
02/06/13 01:52 PM
02/06/13 01:52 PM
Posts: 6,005 Reno, Nevada
NV69B7RR
Reno, Nevada
Just don't do the whole control arm in RPM and then try to put the Krylon over it. DAMIK... ![](/ubbthreads/images/graemlins/fan.gif) Acetone will remove RPM so you can spray the Krylon on. My uppers were bare steel.
[Re: NV69B7RR]
#1382151
02/06/13 03:10 PM
02/06/13 03:10 PM
Posts: 8,828 Houston, Tx
hemi68charger
Houston, Tx
FWIW, if you want the cosmoline look, use Krylon battery protectant spray if you can't get cosmoline.
That's what I did, even let the protectent run when held in the vertical position. If you try to apply the protectant while they are laying horizontal, the runs "run" the wrong direction... After it dried, I applied a coat of Krylon satin clear for protection, ease of cleaning and reduce any over gloss appearance it may have...
TroyHouston Mopar Connection Club'69 Charger Daytona 440 - auto - 4.10 Dana (now with 426 hemi) '69 Charger 500 440 - 4speed - 3.54 Dana '70 Road Runner 383 - 4speed - a/c (now with 440)
