1971-72 Air Grabber Bubble & Door - PG Classic #1382130
02/05/13 07:57 PM
02/05/13 07:57 PM
Columbus, Ohio
rarbird Offline OP
rarbird  Offline OP
Columbus, Ohio
I purchased a PG Classic Air Grabber Bubble & Door and it was a total piece of junk. The bubble was not even close to the original part. The air box door has stress cracks out of the box. The fiberglass in the middle of the bubble sags down 3/4 of an inch from where it should be. The contour of the bubble is incorrect as it dips down instead of arching up. The bubble weighs over 30 lbs by itself and adding filler to try and correct the defects would only make it heavier. I doubt the stock hood hinges would even support the weight.
Further it cost $150 USPS to ship from Canada to US. Then upon the return, it cost $125 USPS to ship back. PG Classic would only accept returns via USPS which to Canada means you have to ship it priority $$$$.
Re: 1971-72 Air Grabber Bubble & Door - PG Classic [Re: rarbird] #1382131
02/06/13 09:17 AM
02/06/13 09:17 AM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
I'd demand refund plus shipping refund.
Re: 1971-72 Air Grabber Bubble & Door - PG Classic [Re: rarbird] #1382132
02/07/13 09:22 PM
02/07/13 09:22 PM
SE PA.
Q
QuickBpBp Offline
QuickBpBp  Offline
Q
SE PA.
They have been like that for years but people keep buying them...Sorry that it costs so much for nothing. Alot of these chinese parts are just close enough to be wrong but yet most brag about them. Just an FYI it is also the same one BE and A has and many other dealers that sell PG's parts so do not think they get better from someone else. For what it is worth that is the best of the worst ones made....
Re: 1971-72 Air Grabber Bubble & Door - PG Classic [Re: QuickBpBp] #1382133
02/07/13 09:56 PM
02/07/13 09:56 PM
jersey shore
flypaper Offline
I hate Texas
flypaper  Offline
I hate Texas
jersey shore
i only got as far as a flat hood.
i noticed at carlisle that i could pick them out from across the show field
so i still have the flat hood and i went out and bought a real one
Re: 1971-72 Air Grabber Bubble & Door - PG Classic [Re: flypaper] #1382134
02/07/13 10:08 PM
02/07/13 10:08 PM
Near Reading PA USA
pinkduster Offline
pinkduster  Offline
Near Reading PA USA
Wow! That's awful!
Re: 1971-72 Air Grabber Bubble & Door - PG Classic [Re: rarbird] #1382135
02/08/13 01:08 AM
02/08/13 01:08 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Only other source for a repro 71 airgrabber set up is from AAR fiberglass,....they are now called www.americansportscar.com after merging with Stinger fiberglass
Mike
Re: 1971-72 Air Grabber Bubble & Door - PG Classic [Re: DAYCLONA] #1382136
02/08/13 04:50 PM
02/08/13 04:50 PM
SE PA.
Q
QuickBpBp Offline
QuickBpBp  Offline
Q
SE PA.
Mike has the quality of the stinger piece gotten better? I know the one I saw a few years back it was not even as good as the PG - BE & A one..Thanks.
