So many vendors....so many disappointments!
#1381960
02/05/13 03:40 PM
02/05/13 03:40 PM
Posts: 3,456 Out West
408strokerdart
Out West
I have lowered the boom on vendors in the past, but this one takes the cake. With the re-build of my R3/W8 engine I changed over to a Jesel belt drive. When I was installing it, I found out that the balancer would not tighten up against the lower pulley. After comparing parts, the throat of the pulley was significantly shorter than the gear I pulled off. Called Jesel and talked to their "belt drive engineer". He looked thru his stash of information and found an early revision of the lower pulley drawing that removed almost exactly the amount I was lacking to be able to tighten the balancer up. They seen what happened and promptly made me a spacer to go between the lower pulley and the nose of my balancer hub. I explained to them that the early high end (read Pro Stock Truck) Bryant cranks that the system was initially designed for had a shorter register and is likely why the pulley was shortened. I suggested adding the spacer to the kit and some instructions on when it is needed. Now, on to the upper pulley/cam adapter. When degreeing the camshaft, I kept coming up with 183 degrees (shooting for 104). I ended up having to move the upper pulley 6 teeth and had to use up 5 degrees of the adjustment to get it dialed in. Come to find out, the cam key location was also different on the early pro stock truck stuff. This should make it easy to re-assemble when the time comes. ![](/ubbthreads/images/graemlins/hammer.gif) Don't know why anyone would be disgusted after spending $1500 for "premium" parts right? Now, I'm changing over to a Jesel belt driven distributor. This should be easy right... Well, I guess they expected everyone to suspend their engines using sky hooks or the factory motor mounts (because most people that would use a belt drive and front mounted distributor would also use the stock mounts and not an engine plate). Their distributor bracket is designed to mount right to the front of their cam belt drive cover using the upper two holes (where the water pump would mount). Since their cam drive cover doesn't cover the water inlet holes and the distributor bracket doesn't cover them.....how is anyone supposed to make this work? I would expect most users of this system to be using some type of engine mounting plate of 1/4" or 3/8" and that would fit in front of the Jesel cam drive cover and space the distributor bracket to far forward by the same amount. The distributor bracket has lugs on it that can be machined down to work with most applications. I suggested this as a fix as it would make the bracket much cheaper to manufacture since they would be starting with a 1/2" thick aluminum chunk rather than a 1" thick piece (which mostly gets machined away). Then they could package the spacers to get what ever combo is desired to align the belt. I have been doing design and engineering work for 24 years and making products more manufactureable (lean manufacturing) is one of my strengths. I offered this "constructive" advice free of charge to Jesel and also offer it as another reason they don't sell more of these kits (and Mopar guys are cheap for the most part). For $2K I expect this stuff to work out of the box. When I asked about having the bracket modified so it would actually fit.....they said it was a custom part and they would have to charge me an additional $225. This modification should take about 15 minutes to perform on their existing bracket? So, I uess they are not offering to actually "fix" any of the issues with their SB mopar kits. I can only say, spend your money accordingly folks. I guess I will just modify the bracket myself since I have access to a mill, but then again doesn't everyone? I know it is a long winded rant, but what do you guys think? I have several hours invested in figuring out what the issues are and describing not only the problems, but also offering "fixes". I never asked to be paid for my time..... Makes me want to tool up and produce my own just for spite. ![](/ubbthreads/images/graemlins/flame.gif)
Re: So many vendors....so many disappointments!
[Re: AndyF]
#1381965
02/05/13 05:46 PM
02/05/13 05:46 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
I bought a tach from Brian Smith, it was shipped promptly, packaged well and works great ![](/ubbthreads/images/graemlins/laugh2.gif) It sounds like there is some markup on these parts there to compete, I say go for it ![](/ubbthreads/images/graemlins/thumbs.gif)
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: sixpackgut]
#1381966
02/05/13 06:22 PM
02/05/13 06:22 PM
408strokerdart
Out West
I would like to believe I keep a very good reputation among those people I do business with. I wouldn't have it any other way. ![](/ubbthreads/images/graemlins/thumbs.gif)
There is more than reasonable and customary mark up on Jesel products. They make a fortune on their stuff. I want to have nice equipment, but there is something to be said for "paid for" equimment that keeps overhead down.
[Re: AndyF]
#1381967
02/05/13 06:28 PM
02/05/13 06:28 PM
408strokerdart
Out West
That was how my business started. I found so many problems with Mopar Performance parts that I started to build my own stuff. Then it just took off from there.
As for Jesel, they make killer products but they do not worry too much about the lower end bracket type engines. They assume that their customers are pro engine builders with fab capability. That is why I make things such as TDC pointers for Jesel belt drives as well as motor plate brackets for Jesel belt drive distributors. I also make spacers and brackets to run the belt drive stuff with electric water pumps and other such parts. Jesel just doesn't spend time trying to design all of those related parts. They are good guys to work with, but they don't try to do everything for everybody.
I can certainly appreciate the origins of your business if this is why you started.
I also don't think $15k-$20k engines are low class. They deserve quality parts for the price. The masses aren't popping for $40K and up engines. I think the top shelf stuff drives development, but that doesn't mean the rest of us should suffer from old designs that haven't been maintained. It is a major PITA for most of us to find a machine shop to modify stuff that doesn't scrap our parts. ![](/ubbthreads/images/graemlins/Twocents.gif)
[Re: 408strokerdart]
#1381968
02/05/13 07:00 PM
02/05/13 07:00 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I had one cam from MP that was 26* off... the key way was ground off... I set that at the so called dot to dot to get a base then degree it... but the valves crashed on the first turn.... I changed to setting the crank at the 108* and set the intake lobe at top then checked all the lobes once I had it at the proper 108... then I advanced it 4*.... that box the cam came in was already open so I think someone bought it and gave it back... other than the key way being off the cam was fine... it was a roller cam ![](/ubbthreads/images/graemlins/wave.gif)
#1381970
02/05/13 08:13 PM
02/05/13 08:13 PM
Posts: 3,036 bean town ....Ca
WHITEDART
bean town ....Ca
lets see here.. one after market part.. and another after market part.. then some after market nuts and bolts.. then try to bolt it to the other after market part what could go wrong.. I feel your pain going through the same stuff here but different parts
In the 8s N/A.with Brett miller W8's 5.07 at 133 at 2700lb
[Re: quickd100]
#1381977
02/05/13 11:29 PM
02/05/13 11:29 PM
408strokerdart
Out West
If it comes out of a box it needs to be modified to fit. Remember that and you won't be disapointed. There are vendors here and out there that do make/sell qualitiy stuff. John Cope and Bob George come to mind. Dave
There are definately vendors out there that are the exceptions that restore our faith. This particuar one did nothing for my faith in them today. Giving them solutions to their problems for free and then watching them turn their heads the other way is very telling. I will definately spend into the future with this knowledge.
[Re: quickd100]
#1381978
02/06/13 12:58 AM
02/06/13 12:58 AM
Posts: 6,570 Downtown Roebuck Ont
Twostick
Still wishing...
Still wishing...
You and my machinist are of a like mind.... Except the part about after it comes out of the box isn't nearly as polite. ![](/ubbthreads/images/graemlins/laugh2.gif)
Kevin
