Re: need opinions
[Re: buck440]
#1381685
02/04/13 09:38 PM
02/04/13 09:38 PM
Posts: 717 Central TEXAS!!!!
sr4440
Central TEXAS!!!!
If I were you, I would lose the heavy TRW's. you will be much happier in the long run.
Joe
Without Data, you’re just another guy with an opinion.
Re: need opinions
[Re: Mopar-Al]
#1381690
02/05/13 05:59 AM
02/05/13 05:59 AM
Posts: 4,648 aotearoa
rebel
aotearoa
i had good luck with Hughes cams, good strong power on hotted up stock parts. i'd look at a cam thats somewhere near 250@50 in their collection.
Re: need opinions
[Re: buck440]
#1381692
02/05/13 12:42 PM
02/05/13 12:42 PM
Posts: 167 maryland
74yellowduster
maryland
hi guy's just gitn some opinons on what cam you guy's would run ? here's my engine combo so far. std bore 440 with trw 2295 dome pistons. i beleive they are 11.5 comp. stealth heads milled 0.30 mild port work. team g intake 4500 flange port matched to heads. i will be running proparts 2" primary header's 3500 stall 4.10 gear 28" tire in a 3200lb duster. oh would like to run a 1050 dominator carb whatcha think?
with that carb intake compression you could probably go .600 lift easy IF you have the right springs, rockers, etc. and can have the pistons cleared to the valves for that lift.
if using stock rockers and dont want to cut the pistons you should probably not go so big and still should thoroghly check the piston/valve clearances
Re: need opinions
[Re: Dodgem]
#1381693
02/05/13 07:31 PM
02/05/13 07:31 PM
Posts: 295 maryland
buck440
maryland
This the cam your thinking about? http://www.summitracing.com/parts/cca-cl21-229-4/overview/make/chrysler
should work fine degreed in at about 103.
Why only a 3500 stall??
yep that's the cam. 3500 stall is what i have laying round at the moment. race season is almost here just wanna have something throwed together to run that'all. till i build my 451. thanks for the reply ![](/ubbthreads/images/graemlins/thumbs.gif)
Re: need opinions
[Re: Mopar-Al]
#1381694
02/05/13 07:33 PM
02/05/13 07:33 PM
Posts: 295 maryland
buck440
maryland
You may like the MP 590
the 590 is mechanical not hyd. right ?
Re: need opinions
[Re: SG duster]
#1381699
02/07/13 10:05 PM
02/07/13 10:05 PM
Posts: 295 maryland
buck440
maryland
yea, ol 509 will be fine. particuly since you have one already
no im lookin into cams. alway's ran the tried and true 509 but i want a little more. so any advise is apreciated
Re: need opinions
[Re: gregsdart]
#1381702
02/07/13 10:44 PM
02/07/13 10:44 PM
Posts: 295 maryland
buck440
maryland
The 590 will make a lot more power than the 509, and would be my pick. Dial it in very early (102?) due to the tight converter, shift it at 6,000.
thanks what bout the 557 mp shaft? sorry if i keep askin a bunch of questions but i dont have much mechanical cam exp. ![](/ubbthreads/images/graemlins/shruggy.gif)
