Meziere waterpump with front drive distributor #1381561
02/04/13 05:55 PM
02/04/13 05:55 PM
Salt Lake City
camastomcat Offline OP
Salt Lake City
Is there a problem doing this? Can I get some pics please? I am starting my M/C build and would like to re-assure myself.
Re: Meziere waterpump with front drive distributor [Re: camastomcat] #1381562
02/04/13 07:45 PM
02/04/13 07:45 PM
Idabel,Oklahoma
Gary Robbins Offline
Idabel,Oklahoma
I had to use their spacers(.090)...Thought i would only need 1 and ended up having to use 2...Moved the pump closer to the radiator than i like and had to move fan to front of rad...
Re: Meziere waterpump with front drive distributor [Re: camastomcat] #1381563
02/04/13 10:19 PM
02/04/13 10:19 PM
Ohio
3404 Offline
3404  Offline
Ohio
I used Andy F's adapters and a remote Meziere pump
Re: Meziere waterpump with front drive distributor [Re: camastomcat] #1381564
02/05/13 12:13 AM
02/05/13 12:13 AM
AndyF Offline
AndyF  Offline
I have several different ways of making that work. Should be pictures of all of the options on my website. www.arengineering.com
Re: Meziere waterpump with front drive distributor [Re: 3404] #1381565
02/05/13 12:15 AM
02/05/13 12:15 AM
AndyF Offline
AndyF  Offline
That looks good. Those are the AR245 water manifold blocks. You can also plumb that for reverse cooling if you want by just swapping the lines from top to bottom.
Re: Meziere waterpump with front drive distributor [Re: AndyF] #1381566
02/06/13 02:10 AM
02/06/13 02:10 AM
Chowchilla,ca
Chassisman Offline
Chassisman  Offline
Chowchilla,ca
I'll show this post to Dave Meziere himself.....lol....will see him this weekend.
Re: Meziere waterpump with front drive distributor [Re: AndyF] #1381567
02/06/13 10:51 AM
02/06/13 10:51 AM
AndyF Offline
AndyF  Offline
I make a taller bracket for the Jesel distributor so it will clear the Meziere reverse flow water pump. That bracket kit comes with a longer belt. All of this stuff is on my website. www.arengineering.com
Re: Meziere waterpump with front drive distributor [Re: AndyF] #1381568
02/08/13 10:44 PM
02/08/13 10:44 PM
Ohio
3404 Offline
3404  Offline
Ohio
From the Meziere pump
