not enuff to open up the flange.
I have the 3/4" 4 hole wood spacer for the edelbrock 1905 q-jet that I mocked up on the rpm intake. it will work to bolt it on but just needs a little triming for each hole.(1/2 moon shaped) well within the flange area for no leaks.
I also see edelbrock has a spredbore to sqaurebore flange adaptor that moves the q-jet back 5/16" to help distribution on an open plenum intake.
that got me to thinking about the divider mod for the RPM intake. milling the divider down till it is 3/8" off the floor to make it an open plenum area on the duel plane.
from the what I see on most cambos,the 3310 on a rpm intake seems to be the way to go maybe. I just dont have one of those.
