edelbrock RPM intake with spredbore carb? #1381533
02/04/13 05:40 PM
02/04/13 05:40 PM
scratchnfotraction Offline OP
anyone out there running a spredbore carb on the RPM squarebore intake with open adaptor?
I am going to try it myself and was looking up the adaptor part#. I see you can get the universal fit open adaptor and edelbrock has one that moves the spredbore carb back 5/16".
supposed to help with distribution on an open plenum intake. so I was wondering if it would be better than the universal adaptor.
Re: edelbrock RPM intake with spredbore carb? [Re: scratchnfotraction] #1381534
02/04/13 05:54 PM
02/04/13 05:54 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
Which 1 cost more ??
I am truckless..
Re: edelbrock RPM intake with spredbore carb? [Re: scratchnfotraction] #1381535
02/04/13 07:49 PM
02/04/13 07:49 PM
Southern CA
Colin Frolick Offline
Southern CA
i was wondering this but on a different manifold. i haven't done it yet but i'm going to try the dual plane indy and maybe some n2o in my car's future.
https://board.moparts.org/ubbthreads/showflat.php?Number=5435587&page=0
Re: edelbrock RPM intake with spredbore carb? [Re: Colin Frolick] #1381536
02/05/13 12:01 AM
02/05/13 12:01 AM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
I used a direct fit adapter that was made by BG Carb & was made of laminated wood
Re: edelbrock RPM intake with spredbore carb? [Re: BulletBob] #1381537
02/05/13 10:06 AM
02/05/13 10:06 AM
thanks Bob. I will look for it.
I have the 3/4" 4-hole spredbore spacer and laying it on the top of the rpm intake I could trim the 1/2 moon looking part matching the spacer, but no way would you be able to make a stock spredbore gasket fit. not enuff meat on the sides.
wonder how much effect it would have if I cut the 1/2 moons in the flange and then go back to a squarebore carb? I guess a 4-hole spacer would cover the notches up ok.
now...do i want to hack up a new rpm intake just so i know???
Re: edelbrock RPM intake with spredbore carb? [Re: scratchnfotraction] #1381538
02/06/13 02:06 AM
02/06/13 02:06 AM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
Didn't you ask me in a post a while back if the was enough meat in the flange for a Qjet? We were talking Mag intakes.
Well so everyone knows The Performer RPM,Crosswinds & other intakes with a squareflange (standard Holley)that I have laying around here.
There is not enough meat around the flange or corresponding bolt hole material for drilling & tapping such
Sorry it took me so long I just found the gasket to make the match with yesterday.
Re: edelbrock RPM intake with spredbore carb? [Re: BulletBob] #1381539
02/06/13 10:29 AM
02/06/13 10:29 AM
not enuff to open up the flange.
I have the 3/4" 4 hole wood spacer for the edelbrock 1905 q-jet that I mocked up on the rpm intake. it will work to bolt it on but just needs a little triming for each hole.(1/2 moon shaped) well within the flange area for no leaks.
I also see edelbrock has a spredbore to sqaurebore flange adaptor that moves the q-jet back 5/16" to help distribution on an open plenum intake.
that got me to thinking about the divider mod for the RPM intake. milling the divider down till it is 3/8" off the floor to make it an open plenum area on the duel plane.
from the what I see on most cambos,the 3310 on a rpm intake seems to be the way to go maybe. I just dont have one of those.
Re: edelbrock RPM intake with spredbore carb? [Re: scratchnfotraction] #1381540
02/06/13 08:50 PM
02/06/13 08:50 PM
Missouri
MY340 Offline
MY340  Offline
Missouri
I ran a 850cfm TQ with a Edelbrock RPM manifold on my old 340-4spd Duster. Used the Mr. Gasket open spreadbore to squarebore adaptor.
1970 FE5 Duster 360/904/3.91's SOLD 1973 TB3 SpaceDuster 340/4spd/4.10's SOLD Moparless for now but when the opportunity is right I'll have another one.
Re: edelbrock RPM intake with spredbore carb? [Re: MY340] #1381541
02/07/13 10:29 AM
02/07/13 10:29 AM
I am picking up a open adaptor this weekend. I have a 650DP spredbore holley,850DP spredbore annular booster holley,750 q-jet to try out on it.
Re: edelbrock RPM intake with spredbore carb? [Re: scratchnfotraction] #1381542
02/08/13 05:53 AM
02/08/13 05:53 AM
Australia
big_wedge Offline
big_wedge  Offline
Australia
this might sound drunk but Im tempted to use a Quadrajet on a 440 with a holley st dom, should move the white paint line off the traffic light
Re: edelbrock RPM intake with spredbore carb? [Re: big_wedge] #1381543
02/08/13 08:14 AM
02/08/13 08:14 AM
sound drunk? not really,i have been looking to find a holley SD to run my q-jet on my 440.
Re: edelbrock RPM intake with spredbore carb? [Re: scratchnfotraction] #1381544
02/11/13 01:08 AM
02/11/13 01:08 AM
Windsor, ON, Canada
Diplomat360 Offline
Diplomat360  Offline
Windsor, ON, Canada
I'm running one right now...using the Mr. Gasket open adapter...3/4" height. Did some fine-matching before I had actually installed it..contoured it to make for a smooth transition between the carb-adapter and adapter-intake mating lines.
Here are a few pics:
...but because of all the growth in height I ended up completely switching away to the Lokar based cabling :
Re: edelbrock RPM intake with spredbore carb? [Re: Diplomat360] #1381545
02/11/13 10:23 AM
02/11/13 10:23 AM
I got it bolted on and did the same thing with the MrGasket adaptor blending/matching the contures from adaptor to intake flange.
run a wire for the elect.choke and man does it work nice.
good throttle responce like the stock intake with q-jet but the HP/torque the RPM intake has.
I am very happy with it and it even picked up from 10 to 13.7 mpg running the 3.23 gear.
I am not used to a choke here in FL though, the waiting for 2.5 mins at cold start up is kinda new to me.
